Honda Motorcycles (Racing) In Egypt
  • Honda Motorcycles (Racing) In Egypt
    الصور, الموديلات دى منقولة من موقع هوندا ايجيبت يعنى انا مش جايب حاجة من دماغى
    ويارب الموضوع يعجبكوا
    CBR 1000RR
    RepsoL
    Engine Type Liquid-cooled inline-four
    Displacement 998cc
    Bore & Stroke 75mm x 56.5mm
    Compression Ratio 12.2:1
    Valve Train
    Chain-driven DOHC, 4 valves per cylinder
    Fuel Delivery Dual Stage Fuel Injection
    Transmission
    Close-ratio six-speed
    Final Drive O-ring-sealed chain
    Front Suspension
    43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel
    Rear Suspension
    Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
    Brakes
    Front dual 320mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
    Seat Height
    820mm (32.3 inches)
    Wheelbase
    1,402mm (55.2 inches)
    Dry Weight
    tba
    Fuel Capacity 18.2 litres
    ColourRed/Black, Light Silver ....llic
    ده الملك اللى شفته موجود لحد دلوقتى,
    ياجماعة انا شوفت الrace دة وكان منقول على عربية نقل فى طريق مصر اسماعلية ,حاجة فوق الخيال وحجمه كبير عامل زى الحصان
    بس كنت هاموت واسمع صوته فى التزويد
    وبتمنى اشتريه
    CBR 1000 RR
    Displacement 998cc
    Valve Train
    Transmission
    Front Suspension 43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
    Brakes
    Seat Height 820mm (32.3 inches)
    Wheelbase
    Dry Weight tba
    Fuel Capacity
    18.2 litres
    CBR 600RR
    Displacement 599cc
    Bore & Stroke
    67mm x 42.5mm
    Valve Train Chain-driven DOHC, 4 valves per cylinder
    Transmission
    Front Suspension
    41mm inverted HMAS cartridge fork with full adjustability; 119mm (4.7 inches) travel Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 130mm (5.1 inches) travel Tires 120/70ZR - 17 radial front; 180/55ZR - 17 radial rear
    Brakes
    Front dual 310mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
    Wheelbase
    1,368mm (53.8 inches)
    Dry Weight
    156.5 kg (345 pounds)
    Fuel Capacity
    18.1 litres
    Colour
    Black, Red/Black, Ultra Blue ....llic/Silver
    Contact Them At
    للاستفسار عن الاسعار
    Motorcycles :
    26th July st., Tersana shopping center ,
    Mohandesseen , P.O.BOX 59(11511)
    tel:
    33448340
    +(202)
    Motorcycles:
    19 Sultan Hussiesn St., Mahatit El Raml Alexandria
    tel:+(203)
    4851317 -4813743
    Honda Hot Line:
    19811
    تشكيلة حلوة خصوصا الريبسول
    إِن يَنصُرْ‌كُمُ اللَّـهُ فَلَا غَالِبَ لَكُمْ ۖ وَإِن يَخْذُلْكُمْ فَمَن ذَا الَّذِي يَنصُرُ‌كُم مِّن بَعْدِهِ ۗ وَعَلَى اللَّـهِ فَلْيَتَوَكَّلِ الْمُؤْمِنُونَ ﴿[U]160)[/U]
    م/محمد
      و الله جمدييييييييييييييييييييين مووووووووووووووووووووووووووووووووووت
      تشكر علي التشكيله
      [SIZE=1][B]مش كل اللي بنحلم بيه بيكون معانا بس اللي احنا نقدر عليه انه يكون في خيالنا
      [/B][/SIZE]
        والله حجات جميلة ربنا يكتبهالنا بس انا عاوز اعرف انتا معجب بال rr اوى كدة ليه مع ان فى موديلات fireblade شكلها جاحد انا معايا 2004 و ماشاءالله صوت انقلاع طيارة فعلا
        بس للامانة انا مجربتش ال ارار عشان احكم عليها بس احسن حاجة شايفها فى ال ارار ان الشكمان ورا عشان بعيد عنك فى الوقعة اللى فى الجناب بيكوى الرجلين و شكرا على المجهود
          ده موتوسيكلي
          م/محمد
            المشاركة الأصلية كتبت بواسطة volkswagen مشاهدة المشاركة
            بس ياباشا استحمل بقي الحرارة الي جيالك من تحت الكرسي ده غير انه بيكل الدرج الي تحت الكرسي
            وعلي فكرة في موديلات 2008 رجعو تاني خلوه شكمان صغير في الجنب
            م/محمد
              تمام الجكمان اللى ورا فيه عيوب كتير
              وانا جربت الاتنين
              ومعايا الشكل الجديد
              بايك مجنوووووووووووووووووووووون
                الف شكر يا برنس على المجموعة الرائعة دى وعلى فكرة انا شفت لل cbr 1000 كذا فيديو حقيقى وهممممممممممممم .
                  شكرا يا جماعة انا لسة 18 سنه ولسة ربنا مكتبليش اسوق ريس لحد النهاردة وبأذن الله اول ما هاركب هاركب 600rr لانه وهمى بس احل مشاكلى مع اهلى
                    المشاركة الأصلية كتبت بواسطة yascro مشاهدة المشاركة
                    وانا جربت الاتنين
                    ومعايا الشكل الجديد
                    ممكن تقولي ايه عيوب الشكمان لما يكون تحت الكرسي انا سألت اكتر من شخص وقالو مافيهوش اي مشكله والاخ otefa بيقول انه الموديلات الجديده اتغير وبقي الشكمان صغير وتحت وده غير صحيح متغير في الالف cc بس ولكن ال 600 c c زي ماهو من 2004 لغايه دلوقتي واكيد لو في حراره او بيعمل مشاكل كان غيرو مكانه
                    [url=http://nileup.com/up/][img]http://nileup.com/up/uploads/nilemotors_13793320201.jpg[/img][/url]
                      انا كنت فعلا بتكلم علي 1000
                      الموضوع ببساطة ان ال1000 بيولد حرارة اعلي بكثير من 600 فالشكمان مابيكون تحت الكرسي استحمل بقه ياباشا
                      فيه تحت الكرسي االثاني الخلفي مكان للتخزين (شنطة عدة+قفل وسلسلة+جوانتي+ممكن جاكيت للمطر)يعني مساحة حلوة
                      بتتاكل لما بيجي الشكمان تحت الكرسي
                      وال600 من 2003 مش 2004
                      م/محمد
                        المشاركة الأصلية كتبت بواسطة otefa مشاهدة المشاركة
                        كلامك مضبوط والمشكله بتكون في المساحه الي تحت الكرسي هي الي بتروح ولكن كحراره ما اعتقدش في مشكله بس الصراحه شكل الشكمان الصغير في الالف تحفه بجد ياريت كانو عملوه في ال 600 كمان
                          وده ال 1000 2005
                          م/محمد
                            طيب وايه رأيك في التحفه ده ولا بلاش تحفه ده اسطوره
                              رائع ياباشا بيعجبني شكله قوي وده يا 2008 يا 2009 1000
                              وبيعجبني قوي الياماها
                              م/محمد
