2015 Volkswagen XL1
The XL1 car was designed to be able to travel 100 km on 1 litre of diesel fuel ,280 mpg
mif
رقم العضوية : 44546
الاقامة : Egypt
السيارة: كورولا 1995
السيارة[2]: fiat 125
Mitsubishi's will use 3-cylinder MIVEC engine new 660cc.
In addition to the control valve timing and a block of aluminum (which gives 10% weight reduction), the new engine also uses the following to reduce the weight, size and cost, and to provide more power and fuel economy better:
4-valve direct-drive valvetrain
Timing chain
Resin components (including the intake manifold, headgear)
Rear exhaust engine mounting layout
New 3-cylinder, 660cc turbocharged engine provides 47kW (63 hp) of power. With variable valve timing, fuel is expected to increase by 15% eceonomy the mini-car unit today, and to obtain a 3-star LEV rating for emission levels 50% cleaner than Japanese 2005 Low-Emission Vehicle requirements.
With the midship location and 45 degrees tilted back, the new engine allows a greater flexibility in developing the front end and also a longer wheelbase.
BMW Has A Nice Little Spot Set Aside For A 2 Cylinder Engine In The i3
Mahle three-cylinder, 1.2-liter engine develops 193 horsepower
ahmed_eng2001
