طيب ما كده المكثف احلي ولا ايه
بس انا بدأت اقتنع اكتر انه فى حاجه زي التايمر ده او auto Deming
بس السؤال شكلها ايه وبتتركب فى اللمبة نفسها ولا فى علبة الفيوزات
العربية نوبيرا 2 :11:
يا شباب من فضلكم كملو الموضوع علشان يبان ايه المطلوب و نعرف نعمله ازاى
مينفعش كويل لان التيار دي سي ف هيبقى كانه سلك عادي وممكن دايرة الكترونيك ومش مكلفة بس الدايرة نوعا ما متعبة بس مش اوي
مينفعش مكثف لانه بيقفل ال دي سي وال العربية دي سي
مينفعش كويل ولا مكثف امال نحط مقاومه :shyy:
شوفو الدايره دي كده انا لقيتها على النت
[sor2]http://www.mp3car.com/vbulletin/attachments/hardware-development/21726d1131841830-dome-light-dimmer-delay-dome_light_dimmer.png[/sor2]
[sor2]http://www.mp3car.com/vbulletin/attachments/hardware-development/21727d1131841850-dome-light-dimmer-delay-board.jpg[/sor2]
[sor2]http://www.mp3car.com/vbulletin/attachments/hardware-development/21264d1130896979-dome-light-dimmer-delay-board-back.jpg[/sor2]
اقتباس:
Intro & disclaimer
For all you guys out there that want a fading dome light (aka courtesy light aka theatre lighting) without having to pay for one, you can build your own. I have attached the schematics and you can build it for a few bucks given that you don't have any spare components lying around otherwise it can cost you absolutely nothing. Of course you can rip some parts from your TV, CD player, radio, etc., but I'm not responsible for the damage you cause this way http://www.mp3car.com/vbulletin/images/smilies/wink.gif
The way it works
I won't bother you with technical details, but if someone is interested just let me know and I'll explain in detail. For now just the basics. There are two stages: first one is delaying and the second one is fading. When you open the door the light turns on. You get inside and close the door, but the light stays on (delay stage) for an adjustable period of time (0-40 sec. for the values in the scheme, but you can easily modify that i.e. put a bigger capacitor) so you can see where to insert the key or do whatever you do when you get in the car, then fades away (fading stage) with an adjustable speed. If you connect the ACC wire (which is entirely optional) when you turn the key to ACC position the light turns off (actually fades) even if the delaying stage is not over (it cancels the delay stage).
Setup
The SR1 trimmer pot adjusts the delaying time (the period that the bulb is at full intensity) and you have a "witness" LED that is lit during the delaying stage; that way you can set it visually to whatever duration you like. When the first stage ends (marked by the LED not being lit anymore) enters the second stage - fading. The SR2 trimmer pot adjusts the fading time (or speed if you prefer)
The first image depicts how the dome light switch is usually connected (depending on the make and model of your car the connection may be different in which case you'll have to figure it out).
The second - the schematic and the connections to the dome light switch.
The third (and last) is an actual image of the finished product made on a PC board (you can get those from radio shack or your local electronics store)
كلام رائع يا محمد بس عايزين
كيفيه التركيب علي العربيه و فين ؟؟؟
طبعاً واضح من الدائره انها بسيطه التصميم يعني ليجراتور و مكثف حوالي 100 ميكروفراد و التاني 47 ميكوفراد و 2 امبلافير منهم واحد فيد باك ...
بس عايزين نعرف التثبيت في العربيه حيكون فين و ازاي يا حماده
و حاجة كمان عايز اقولهالك البورده دي واضح طبعاً انها معموله يدوي و اللحام قصدير يعني لو الدايره دي متوفره جاهزه تكون طبعاً افضل فاهمني .....
لان اليدوي دا طبعاً ممكن يحصل في التصميم تداخل ما بين شريط اللحام و يؤدي الي عمل شورت فعلشان كدا افضل انها تكون دايره مطبوعه ( جاهزه يعني )
تحياتي
مينفعش مكثثثثثثثثثثثثثثثثثثثثثثث ثثثف ولا كويل
بصو يا جدعان بالراحة المكثف بيتشغل ازاي
بيمشي تيار يولد جهد بين طرفين المكثف عكس الجهد الاصلي"مش مشكلة الاتجاه" ولما يبدا الجهد الاصلي يقفل يبدا المكثف يفرغ ودا في حالة التيار المتردد لانه بيقل ويزيد
انما التيار الثابت بتاع البطاريات والعربية مينفعش فيه مكثف لانه ثابت ف المكثف بيشحن لحظي وبعدين يفصل التيار خالص لانه بيبقى عليه جهد نفس الاصلي وعكسه ف بيلاشو بعض
الدايرة
واعتقد الدايرة ال حضرتك جايب رسمتها دية تمام بس لو تكتب المصدر برضو عشان نعرف دي معمولة لايه
وسهل جدا ننفذها
