اذاى الصور مش بينة ؟؟؟ انا اعد اكتر من ساعتين بعمل التقرير ده. ماينفعش يتصلح. ياريت حد يساعدنى
رقم العضوية : 25221
الاقامة : alexanderia
السيارة: proton gen2
السيارة[2]: vw golf 3
JAC B15
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/112396046.jpg[/mn7ot2]
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/154234363.jpg[/mn7ot2]
http://www12.0zz0.com/2010/03/08/00/232351606.jpg
[mtohg=undefined]http://www12.0zz0.com/2010/03/08/00/131009099.jpg[/mtohg]
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/749121098.jpg[/mn7ot2]
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/197951573.jpg[/mn7ot2]
http://www12.0zz0.com/2010/03/08/00/144443856.jpg
الوكيل: هورس موتمورز
السعر: 70,000 حتى يوم 20/3/2010 , 74,000بعد 20/3/2010
المواصفات:
1-Dimensional parameter
Overall dimension (L×W×H): 4595×1765×1465
Wheelbase(mm): 2710
Tread (front/rear) (mm): 1505/1495
Min turning radius(mm): 5.5
Min ground clearance(mm): ≥160(no-load)
Front/rear overhang: 925.5/958.5
Curb weight(kg): 1385
Seating capacity: 5
Trunk volume(L): 415
Fuel tank capacity(L): 55
2-Power supply system
Engine Model: 4G15
Displacement(cc): 1488
Bore(mm): 76
Stroke(mm): 82
Rated power (kw/r/min): 76/6000
Rated power (HP/r/min): 102/6000
Rated torque (Nm/r/min): 130/4500
Emission Standard: Euro Ⅳ(With OBD)
Transmission model: 5MT F5M41
Max speed(km/h): >175
90kilometers per hour invariablenes speed fuel wastage(L): < 6.7
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/149159697.jpg[/mn7ot2]
[mn7ot2]http://www12.0zz0.com/thumbs/2010/03/08/00/207028449.jpg[/mn7ot2]
http://www12.0zz0.com/2010/03/08/00/672937432.jpg
http://www12.0zz0.com/2010/03/08/00/884407614.jpg
3-Suspension system
Front suspension: MacPherson spiral spring front independent suspension
Rear suspension: Two-link spiral spring independent rear suspension
http://www12.0zz0.com/2010/03/08/00/811893843.jpg
http://www12.0zz0.com/2010/03/08/00/900666195.jpg
http://www12.0zz0.com/2010/03/08/00/640219949.jpg
http://www12.0zz0.com/2010/03/08/00/345607446.jpg
http://www12.0zz0.com/2010/03/08/00/351597539.jpg
http://www12.0zz0.com/2010/03/08/00/539110406.jpg
http://www12.0zz0.com/2010/03/08/00/412262010.jpg
4-Brake
Break model: Front&rear disc braking device
Break circuit: Vacuum assisted hydraulic brake system(Double circuits)
Tyre: 205/55 R16
http://www12.0zz0.com/2010/03/08/00/448648891.jpg
-التجهيزات
فرامل abs+ebd
باور ستيرنج
4 زجاج كهرباء
http://www12.0zz0.com/2010/03/08/00/968706312.jpg
مرايات خارجية تضبيط كهرباء + مراية ذاتية التعتيم للصالون
http://www12.0zz0.com/2010/03/08/00/244854909.jpg
http://www12.0zz0.com/2010/03/08/00/112851466.jpg
http://www12.0zz0.com/2010/03/08/00/134485043.jpg
فوانيس lenses امامية و led خلفية + فوانيس شبورة امامية و خلفية + حساس نور auto light
http://www12.0zz0.com/2010/03/08/00/992061874.jpg
http://www12.0zz0.com/2010/03/08/00/615694132.jpg
http://www12.0zz0.com/2010/03/08/00/544806673.jpg
http://www12.0zz0.com/2010/03/08/00/242070895.jpg
http://www12.0zz0.com/2010/03/08/00/406121360.jpg
http://www12.0zz0.com/2010/03/08/00/352299695.jpg
تكييف تاتش+ اتوماتيك + فلتر+ فتحة تكييف خلفية
http://www12.0zz0.com/2010/03/08/00/468737471.jpg
http://www12.0zz0.com/2010/03/08/00/416540955.jpg
طابلوه + فرش ابواب جلد
http://www12.0zz0.com/2010/03/08/00/847674545.jpg
http://www12.0zz0.com/2010/03/08/00/979635610.jpg
اضاءة لدرج الامتعة+ الكنتاكت+ الشماسات
http://www12.0zz0.com/2010/03/08/00/438655655.jpg
http://www12.0zz0.com/2010/03/08/01/148183246.jpg
http://www12.0zz0.com/2010/03/08/01/114226489.jpg
http://www12.0zz0.com/2010/03/08/01/247116609.jpg
تعديل كرسى السائق فى 6اتجاهات
http://www12.0zz0.com/2010/03/08/01/327433217.jpg
http://www12.0zz0.com/2010/03/08/01/659774791.jpg
4 حامل اكواب
http://www12.0zz0.com/2010/03/08/01/943271465.jpg
http://www12.0zz0.com/2010/03/08/01/568998709.jpg
مخرج كهرباء اضافى خلفى
http://www12.0zz0.com/2010/03/08/01/351923308.jpg
كاسيت مدمج cd MP3+ USB + 4سماعات
http://www12.0zz0.com/2010/03/08/01/309844618.jpg
http://www12.0zz0.com/2010/03/08/01/354554547.jpg
http://www12.0zz0.com/2010/03/08/01/584130951.jpg
2 وحدات نور للصالون + جراب نظارة
http://www12.0zz0.com/2010/03/08/01/159438789.jpg
مفتاح ايمبوليزر + ريموت+ جهاز انذار+ سنتر
http://www12.0zz0.com/2010/03/08/01/720209783.jpg
عجلة القيادة مكسوة بجلد + تعديل
http://www12.0zz0.com/2010/03/08/01/395459134.jpg
http://www12.0zz0.com/2010/03/08/01/942658449.jpg
http://www12.0zz0.com/2010/03/08/01/544407178.jpg
http://www12.0zz0.com/2010/03/08/01/843221231.jpg
parking sensor
http://www7.0zz0.com/2010/03/08/01/952124319.jpg
2 وسائد هوائية air bag
http://www12.0zz0.com/2010/03/08/01/875132247.jpg
http://www12.0zz0.com/2010/03/08/01/520499165.jpg
http://www12.0zz0.com/2010/03/08/01/344543552.jpg
http://www12.0zz0.com/2010/03/08/01/630424844.jpg
http://www12.0zz0.com/2010/03/08/01/728543054.jpg
http://www12.0zz0.com/2010/03/08/01/598485515.jpg
http://www12.0zz0.com/2010/03/08/01/693100804.jpg
http://www12.0zz0.com/2010/03/08/01/972445399.jpg
http://www12.0zz0.com/2010/03/08/01/220206075.jpg
http://www14.0zz0.com/2010/03/08/01/177132684.jpg
http://www12.0zz0.com/2010/03/08/01/402391122.jpg
http://www7.0zz0.com/2010/03/08/01/905969031.jpg
رقم العضوية : 25221
رقم العضوية : 32193
الاقامة : alex
السيارة: -
السيارة[2]: B class
شكرا على التقرير وعلى مجهودك
وعلى فكره انا بتقابلني مشكلة رفع الصور مثلك
وبخصوص التقرير وافي جدا ولكن احب اعدل شئ ان الموتور 104 حصان وذلك نقلا عن كونتكت كار
وطبعا ياريت من الادارة تثبيت الموضوع
رقم العضوية : 25221
العفو يا temo باشا
العربية تستحق بجد انا الى معتلنى عليها شوية ظروف و ان شاء الله اول ما تخلص هاجبها
الموتور اللى نازل مصر 102حصان ده من موقع jac و فى الصين بتنزل بموتور تانى vvt 111حصان. الموتورين mitsubishi technology
سيبك من contact ده ذى الصحافة بتاعتنا فى حجات غربية بتحصل عليه
رقم العضوية : 25221
تكملة التقرير:
jac b15 تصميم ايطالى من تصميم Pininfarina
العربية هتنزل مصر على 20/3 لسة مافيش منها غير للعرض بس عاشان اللى ماشفهاش ماشية
بالنسبة للعفشة النظام بوصلتين بيدى ثبات اكتر مع راحة فى الركوب ( عفشة ناعمة + ثبات عالى) الكلام ده من مواقع صينى اختبروا العربية و فى مقارنة بعربيات تانية.
تم اختبار العربية امسافة 200000 كيلو متر بدون اعطال و بعمل صيانات الدورية و اخدت جائزة على ذلك
التقفيل نضيف جدا
الخامات المستخدمة ذات جودة عليا ماشفتلهاش فى اى عربية صيني قبل كدة
الوان العربية حاوة جدا و البوية بتاعتها نضيفة و ده باين عليها
المنظر الخارجى دى اذواق انا عن نفسى شايفها روعة
الضمان 5سنوات او 100الف كيلو دى حاجة تطمن
التوكيل محترم و سائلت عليه ناس مجرباه فى الجلى اسعاره مش عالية و بيفر قطع الغيار بيحل مشاكلهم بس ينقصه الدعاية مافيش غير اعلان فى الاهرام و سكت و الهورس ده موزع mitsubishi, ford, skoda, hyndai
فى الصين بتنزل بموتور 111حصان vvt و auto
انا حاولت انقل كل الى اعرفه عن العربية على قد ماقدر و اى استفسار عنها انا موجود
الكلام ده بحث عن اى معلومة نزلت عن العربية من اول الاعلان عنها و links كلها عندى لو اى حد حابب انه يعرف اكتر عنها+ كذا زيارة للتوكيل و تفصيص العربية هناك و سابونى براحتى
انا بعتذر عن الصور الى مش باينة فى التقرير و مش عارف اعمل ايه
رقم العضوية : 11020
الاقامة : Kuala Lumpur-Malaysia
السيارة: -
السيارة[2]: Audi A6
دراجة بخارية: -
الصينيون قادمون
رقم العضوية : 26513
الاقامة : Cairo.
السيارة: JAC B Class B15
السيارة[2]: brilliance Galina
good work ya man what color you like for b15?
The Pretty Powerسبحان الله و بحمده سبحان الله العظيمربى أغفر لى و لوالدى و المؤمنين يوم يقوم الحساب
رقم العضوية : 37774
الاقامة : عين شمس
السيارة: شيفورلية لانوس
السيارة[2]: 128 فيات
تقرير جميل فعلا
والعربية دى شكلها هتسبت نفسها بس محتاجة شوية دعاية
بس تطلع فعلا كويسة ومتكونش مقلب
رقم العضوية : 25221
معلش انا نسيت الالوان الى هتنزل مصر: اسود, فضى, كحلى, نبيتى
انا عاجنى اوى النبيتى
يارب العربية تطلع عند حسن ظننا ان شاء االه
رقم العضوية : 47995
الاقامة : Assuit
السيارة: Renault Logan سابقا
السيارة[2]: Opel Vectra _B
دراجة بخارية: FE TI XX
3-Suspension system
4-Brake
Tyre: 205/55 R16
-التجهيزات
فرامل abs+ebd
باور ستيرنج
4 زجاج كهرباء
فوانيس lenses امامية و led خلفية + فوانيس شبورة امامية و خلفية + حساس نور auto lig[/img][img]ht
4 حامل اكواب
parking sensor
[mshosh4]http://data.motor-talk.de/data/galleries/0/2/8693/18007759/opel-banner-4832.jpg[/mshosh4]
