JAC B15
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/112396046.jpg[/mn7ot2]
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/154234363.jpg[/mn7ot2]
http://www12.0zz0.com/2010/03/08/00/232351606.jpg
[mtohg=undefined]http://www12.0zz0.com/2010/03/08/00/131009099.jpg[/mtohg]
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/749121098.jpg[/mn7ot2]
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/197951573.jpg[/mn7ot2]
http://www12.0zz0.com/2010/03/08/00/144443856.jpg
الوكيل: هورس موتمورز
السعر: 70,000 حتى يوم 20/3/2010 , 74,000بعد 20/3/2010
المواصفات:
1-Dimensional parameter
Overall dimension (L×W×H): 4595×1765×1465
Wheelbase(mm): 2710
Tread (front/rear) (mm): 1505/1495
Min turning radiusmm): 5.5
Min ground clearancemm: ≥160(no-load)
Front/rear overhang: 925.5/958.5
Curb weight(kg): 1385
Seating capacity: 5
Trunk volumeL: 415
Fuel tank capacityL: 55
2-Power supply system
Engine Model: 4G15
Displacementcc: 1488
Boremm: 76
Strokemm: 82
Rated power kw/r/min: 76/6000
Rated power HP/r/min: 102/6000
Rated torque Nm/r/min: 130/4500
Emission Standard: Euro (With OBD)
Transmission model: 5MT F5M41
Max speedkm/h: >175
90kilometers per hour invariablenes speed fuel wastageL: < 6.7
[mn7ot2]http://www12.0zz0.com/2010/03/08/00/149159697.jpg[/mn7ot2]
[mn7ot2]http://www12.0zz0.com/thumbs/2010/03/08/00/207028449.jpg[/mn7ot2]
http://www12.0zz0.com/2010/03/08/00/672937432.jpg
http://www12.0zz0.com/2010/03/08/00/884407614.jpg
3-Suspension system
Front suspension: MacPherson spiral spring front independent suspension
Rear suspension: Two-link spiral spring independent rear suspension
http://www12.0zz0.com/2010/03/08/00/811893843.jpg
http://www12.0zz0.com/2010/03/08/00/900666195.jpg
http://www12.0zz0.com/2010/03/08/00/640219949.jpg
http://www12.0zz0.com/2010/03/08/00/345607446.jpg
http://www12.0zz0.com/2010/03/08/00/351597539.jpg
http://www12.0zz0.com/2010/03/08/00/539110406.jpg
http://www12.0zz0.com/2010/03/08/00/412262010.jpg
4-Brake
Break model: Front&rear disc braking device
Break circuit: Vacuum assisted hydraulic brake system(Double circuits)
Tyre: 205/55 R16
http://www12.0zz0.com/2010/03/08/00/448648891.jpg
-التجهيزات
فرامل abs+ebd
باور ستيرنج
4 زجاج كهرباء
http://www12.0zz0.com/2010/03/08/00/968706312.jpg
مرايات خارجية تضبيط كهرباء + مراية ذاتية التعتيم للصالون
http://www12.0zz0.com/2010/03/08/00/244854909.jpg
http://www12.0zz0.com/2010/03/08/00/112851466.jpg
http://www12.0zz0.com/2010/03/08/00/134485043.jpg
فوانيس lenses امامية و led خلفية + فوانيس شبورة امامية و خلفية + حساس نور auto light
http://www12.0zz0.com/2010/03/08/00/992061874.jpg
http://www12.0zz0.com/2010/03/08/00/615694132.jpg
http://www12.0zz0.com/2010/03/08/00/544806673.jpg
http://www12.0zz0.com/2010/03/08/00/242070895.jpg
http://www12.0zz0.com/2010/03/08/00/406121360.jpg
http://www12.0zz0.com/2010/03/08/00/352299695.jpg
تكييف تاتش+ اتوماتيك + فلتر+ فتحة تكييف خلفية
http://www12.0zz0.com/2010/03/08/00/468737471.jpg
http://www12.0zz0.com/2010/03/08/00/416540955.jpg
طابلوه + فرش ابواب جلد
http://www12.0zz0.com/2010/03/08/00/847674545.jpg
http://www12.0zz0.com/2010/03/08/00/979635610.jpg
اضاءة لدرج الامتعة+ الكنتاكت+ الشماسات
http://www12.0zz0.com/2010/03/08/00/438655655.jpg
http://www12.0zz0.com/2010/03/08/01/148183246.jpg
http://www12.0zz0.com/2010/03/08/01/114226489.jpg
http://www12.0zz0.com/2010/03/08/01/247116609.jpg
تعديل كرسى السائق فى 6اتجاهات
http://www12.0zz0.com/2010/03/08/01/327433217.jpg
http://www12.0zz0.com/2010/03/08/01/659774791.jpg
4 حامل اكواب
http://www12.0zz0.com/2010/03/08/01/943271465.jpg
http://www12.0zz0.com/2010/03/08/01/568998709.jpg
مخرج كهرباء اضافى خلفى
http://www12.0zz0.com/2010/03/08/01/351923308.jpg
كاسيت مدمج cd MP3+ USB + 4سماعات
http://www12.0zz0.com/2010/03/08/01/309844618.jpg
http://www12.0zz0.com/2010/03/08/01/354554547.jpg
http://www12.0zz0.com/2010/03/08/01/584130951.jpg
2 وحدات نور للصالون + جراب نظارة
http://www12.0zz0.com/2010/03/08/01/159438789.jpg
مفتاح ايمبوليزر + ريموت+ جهاز انذار+ سنتر
http://www12.0zz0.com/2010/03/08/01/720209783.jpg
عجلة القيادة مكسوة بجلد + تعديل
http://www12.0zz0.com/2010/03/08/01/395459134.jpg
http://www12.0zz0.com/2010/03/08/01/942658449.jpg
http://www12.0zz0.com/2010/03/08/01/544407178.jpg
http://www12.0zz0.com/2010/03/08/01/843221231.jpg
parking sensor
http://www7.0zz0.com/2010/03/08/01/952124319.jpg
2 وسائد هوائية air bag
http://www12.0zz0.com/2010/03/08/01/875132247.jpg
http://www12.0zz0.com/2010/03/08/01/520499165.jpg
http://www12.0zz0.com/2010/03/08/01/344543552.jpg
http://www12.0zz0.com/2010/03/08/01/630424844.jpg
http://www12.0zz0.com/2010/03/08/01/728543054.jpg
http://www12.0zz0.com/2010/03/08/01/598485515.jpg
http://www12.0zz0.com/2010/03/08/01/693100804.jpg
http://www12.0zz0.com/2010/03/08/01/972445399.jpg
http://www12.0zz0.com/2010/03/08/01/220206075.jpg
http://www14.0zz0.com/2010/03/08/01/177132684.jpg
http://www12.0zz0.com/2010/03/08/01/402391122.jpg
http://www7.0zz0.com/2010/03/08/01/905969031.jpg
