النتائج 1 إلى 3 من 3
    الصورة الرمزية paladin
    رقم العضوية : 900
    السيارة: 2car
    السيارة[2]: 1car
    الحالة : paladin غير متواجد حالياً
    افتراضي Tips to reduce fuel consumption - Facebook Twitter whatsapp انشر الموضوع فى :
    -Drive Gently and Avoid harsh acceleration and heavy breaking. Pulling away too fast uses up to 60% more fuel
    -check tyre pressure and over in-flat the tyres if possible
    -change gears as early as possible
    -Start Up & Drive off slowly immediatley (or after a very short while) when starting from cold. Idling to heat the engine wastes fuel and causes rapid engine wear
    - When stuck in a jam Turning off the engine after two minutes will save fuel and cut all emissions
    -Close the windows and donot turn the AC ON
    -Remove any unnecessary weight from the car
    -Avoid excessive idling
    -Reduce the car drag factor by
    remove front and rear spoilers
    use thinner tyres and smaller rims
    Lower the car
    Clean up the underside of the car
    Remove the side view mirrors instead use a bigger inside mirror
    Replace large whip antennas with smaller powered antennas
    install side skirts to reduce tyres drag
    use convex and smooth wheel covers
    -Increase engine efficiency by
    checking and clean or replace the air filter more frequently
    check and replace spark plugs when necessary
    replace mufflers with a straight through type
    install a cold air intake and a high flow air filter
    replace belt driven radiator fans with electric fans
    use thinner motor oil if poissible
    install a smaller battery if possible and donot use electrical accessories
    i cant think of anyhting else now
    الصورة الرمزية marsguy
    رقم العضوية : 1432
    الاقامة : Egypt
    السيارة: none
    السيارة[2]: Renault Fuence
    دراجة بخارية: none
    الحالة : marsguy غير متواجد حالياً
    جزاك الله خيرا
    معلومات مفيده جدا
    الصورة الرمزية ahmedsrs
    رقم العضوية : 2401
    الاقامة : الكوكب الازرق
    السيارة[2]: كيا بيكانتو 2011
    الحالة : ahmedsrs غير متواجد حالياً
    جزاك الله خيرا
    معلومات مفيده جدا
    ونرجو المزيد
    http://imageshack.us/photo/my-images/545/6c6d1551112s.gif/
  1. Fuel consumption for bmw e36 1600 AT 1996
    بواسطة Ahmedabdelmawgoud في المنتدى بـى إم دابـــليو
    آخر مشاركة: 22-07-2011, 11:03 PM
  2. بعض أسباب زيادة إستهلاك البنزين=========Fuel consumption reasons
    بواسطة ahmed1981 في المنتدى القــــسم التعلــــيمى
    مشاركات: 50
    آخر مشاركة: 12-04-2011, 02:24 PM
  3. Tiida's Fuel consumption
    بواسطة AhmadKamal في المنتدى نيـــــــــسان
    مشاركات: 28
    آخر مشاركة: 09-03-2010, 05:23 PM
  4. fuel consumption
    بواسطة mms في المنتدى بــروتـــون
    مشاركات: 6
    آخر مشاركة: 30-03-2009, 11:32 PM
  5. Ford Focus 2009 fuel consumption
    بواسطة hosam2010 في المنتدى فـــــورد
    آخر مشاركة: 25-02-2009, 04:56 PM
