رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
Air Intake research mods
بصو يا جماعه الراجل ده يقول اه و جربوه بنفسكوا بردو ملاحظه جديده جامده
After driving for a while with a Drop in K&N filter I noticed the throttle response improved slightly but not a whole lot. I decided to go looking for air intake obstructions and I found a few interesting items.
First, to my disbelief there was a pre-filter on the upper air box lid with a plastic support system that has to screw up the flow. I am betting this has to do with the SULEV rating of my car as it looks like a carbon/charcoal type filter. Does anyone else have this on their 2.4? Who in the world would put a non-removeable prefilter on a car??? This makes no sense breathing through two filters.
This image has been resized. Click this bar to view the full image.
I removed it carefully not to break the structure which was plastic riveted to the lid. Here is the bottom of the prefilter (that waffle design has to hurt flow!)
Removing it produces a higher flowing cavity!
Also interesting is that the ECU is cooled by incoming Air! Yes, that's right a hot ECU is in your airbox. I am puzzled on this design as well--I wonder how it stacks up against the hyundai version of the airbox.
I will ultimately go with a self-fabricated intake which will go down to the area behind the driver's fog lamp. There is plenty of area for the tubing and filter. The air down there would certainly be cold. I plan to do a remote thermoprobe to prove that out before I make the intake.
If you have an SX please let me know if you have this crappy pre-filter.
Well after some research this is part of the SULEV spec. This is most likely what is robbing a majority of the HP in CA models (it's rated at 8hp less). There is no mention of ECU retune so it's all about flow and keeping HC's in and burning them.
HC block in the air intake system:
Hydrocarbon escape via the intake system is prevented due to the use of an additional carbon filter (1) incorporated in the air filter housing and a "closed" throttle valve actuator (2).
Fuel system components:
All ....l fuel system components (fuel rail (1), injectors (2), tank ventilation valve (3), etc.) are made of stainless steel and are fastened together using coupling type connectors (4).
Fuel tank and tank ventilation system:
The fuel tank (1), tank filler neck (2) and evaporative canister (3) are made of stainless steel.
Crankcase ventilation system:
The crankcase ventilation valve (1) is incorporated in the aluminum cylinder head cover (2).
System components used to achieve SULEV tailpipe emission requirements:
- "Warm up" catalytic converter(s) – high cell density technology
- Upstream oxygen sensors – wide band technology
I doubt that the CAT is responsible for a large portion of the 8HP. I want my ponies back and will get them!
رقم العضوية : 17999
الاقامة : El-Haram, Giza
السيارة: Mercedes C200 K 09
السيارة[2]: Kia Cerato High Line 09
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
الصوره دى ملعاش دعوه بالبرفورمانس بس شكل الموتور احلى
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
دى بقى دعامات غريبه جدا اول مره اشوفها بس شديده ,بتدى ثبات للعربيه فى الملفات و تعمل توازن و كمان بتقوى البودى و الشاسيه و بطن العربيه كمان و بتخلى العربيه مسكه نفسها جامد , و الموقع كمان بيقول انها بتعلى نسبه الامان فى الحوادث الشديده موت يعنى تطلع جسمك سليم باذن
الله مع ان لكل اجل كتاب
مع الصور
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
دى صور حوادث عربيات مركبه التعديل ده بس دى حوادث موتتتتتت
Testimonials from Singapore 2009
Case Study : Hyundai Atos real-world crash impact picturesUltra Racing Bar crumpled from absorbing the impact minimize damage to car,extensive R&D taken to the test in the real world ! Our Hyundai Atos 4 point bar helped absorbed the crash impact & prevent further damage to the car. The same cannot be said of the other car !
Case Study : Horrific Proton Iswara Accident but the driver survivedThe driver survived this horrific crash that totaled his car. Our bars deflected the crash impact and it did'nt even affect the other / left side ! Our bars are designed to absorb energy and crumple in a severe crash, maximizing your chances of survival.
Case Study : Lower Arm Bar is bent but did'nt compromise the chassisThe is a real example of our Proton Wira LAB before & after a severe crash that bent the LAB. As you can see from the comparison photo, the geometry of the brackets hasn't compromised chassis as many sceptics thought it would. This is a result of extensive R&D with materials & design by our technical team.
Case Study : Perodua Myvi front Bar before and after accident but did'nt affect the other side / left sideThis MyVi crashed into a cow and was badly damaged and the unfortunate cow became beef! Despite the extensive damage to the car, the driver wasn't hurt and our bar absorbed the crash, yet not even affecting the other side. After repairs, the owner fitted a new UltraRacing strut bar, and it fitted perfectly! Showing the chassis is still intact.
Case Study : Others Strut bar Protection in the event of accidents
Proton Wira
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
و ده رابط صفحة الموقع فيه شرح طريقه عمل التعديل بالفلاش
Malaysia strut bar manufacturer,sway bar,anti roll bar,distributor,Performance Part,Car Accessory Supply,Automotive spare parts Manufacturers
رقم العضوية : 54071
الاقامة : nasr city & 3`amra
السيارة: skoda a4
السيارة[2]: kia new cerato high line
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
دى صور التربو وهو ده الصح السستم كامل انما باقى الصور فلاتر فقط فقط مينفعش نسيب النظام الكامل الجامد و نعلق على صورتين فلتر فقط و كمان انا حطيط شوية صور لاماكن فلاتر مختلفه و ممكن تتاكد من حراره الهوا اللى داخل من مؤشر درجة حرارة الموتور
.هذه الصورة بحجم اخر انقر هنا لعرض الصورة بالشكل الصحيح ابعاد الصورة هي 700x525.
This image has been resized. Click this bar to view the full image.هذه الصورة بحجم اخر انقر هنا لعرض الصورة بالشكل الصحيح ابعاد الصورة هي 700x525.
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
يا باشا انت حبيبى من زمان من ايام ما فكيت اشتباك الفيات لينا تربو و كيداهم.متشكر على مداخلتك و ردودك الجميله و انا بجيب الصور دى من منتديات امريكيه و كوريه و غيرها دول مليين النت .كيداهم جننت الناس بره دول كمان بيجربوا يركبوا على الكوبيه نيتروس بس تحت الدراسه عشان يطلع مظبوط من اول مره و هما بيجيبوا الجحات جهزه و بيركبوها عند متخصصين و بيراقبوها و يعدلوها بالكمبيوتر زى ما شوفت فى الفيديو .
