رقم العضوية : 26401
الاقامة : Benha-Egypt
السيارة: NA
السيارة[2]: Chevy Lanos
دراجة بخارية: NA
رقم العضوية : 33656
الاقامة : مصر الجديدة
السيارة: Fiat 128
السيارة[2]: Fiat Linea
رقم العضوية : 26401
السيارة: NA
دراجة بخارية: NA
دي البيانات بتاعتها
وال Seller يتاعها Top-Rated يعني موثوق فيه
بس فعلا المروحة دي اكيد مش اقوى من العربية
Introducing the Surge Intake SuperCharger, it revolutionized the Japanese tuner performance market and is now for the first time available to the US market in limited supply. This product will allow you to burn fuel more efficiently resulting in better MPG. This SuperCharger will increase air flow and provide additional horse power and torque by 5-7% to the wheels.
Made entirely of aircraft grade aluminum-titanium alloy, the Surge SuperCharger is machined to perfection! The blades spin freely and smoothly its shaft being supported by a space grade zero friction ball bearing.
Save Up To 28% On Fuel! Increase Horsepower Up To 7% more hp! Easy to install - Takes Less Than 5 Minutes! Fits Virtually All Makes And Models Of Cars And Trucks! Works On Carbureted And Fuel Injected Engines! For Gasoline And Diesel Engines!
The Surge SuperCharger has a 2.5 inch diameter for easy mounting. The product installs inside the intake hose going to the throttle body from air filter. A clamp is included to secure the Surge SuperCharger inside the intake hose. It also includes a rubber coupler that will create a vacuum seal inside the intake chamber. If your hose has a diameter greater then 2.5” you must custom fit it therefore please ask your qualified mechanic to install it.
ودا اللينك
Daewoo Lanos Intake Supercharger Turbo Performance Chip: eBay Motors (item 170397594480 end time Jul-18-10 17:47:30 PDT)
رقم العضوية : 19543
الاقامة : ismailia/Egypt
السيارة: لايوجد حاليا
السيارة[2]: نوبيرا 2007
رقم العضوية : 33656
السيارة: Fiat 128
رقم العضوية : 14603
الاقامة : Egypt, Cairo, Heliopolis
السيارة: Honda Civic EL 1992
السيارة[2]: Honda Civic VTi 1996
أول مرة أشوفة بس ده اى كلام
HONDA THE POWER OF DREAMS
