طبعا كلكوا شفتوها في الجرنال .
للأسف مطلعتش الهوفر زي ما كنت متوقع بس برده مطلعطش سيئة اوي يعني .
المهم .
اسم المصنع : Zhongxing Auto.
اسم السيارة الاصلي : Land Mark
مكان المصنع : جمهورية الصين الشعبية .
الشكل الخارجي :
العفشة و الشاسيه :
الصور الداخلية :
معلومات عن السيارة :
CBU Parameter
Length X Width X Height(mm) 4750 * 1760 * 1830,1775
Wheel base(mm) 2850
Wheel tracks front/rear(mm) 1472/1477
Gross weight(kg) 1670(manual 2WD)/1710(automatic)/1780 (4WD)
Min. turning radius(m) 6.4
Inner dimension(L) 1310/1912
Oil tank capacity(L) 73
Engine parameter
Engine model 4G64
Engine type L4 SOHC 16V MPI
Displacement(cc) 2351
Max. power(KW/rpm) 94/5250
Max. torque(N.m/rpm) 196/2500~3000
Max. speed(Km/h) 160
Emission standard EURO III
Fuel type gasoline above 93#
Chassis parameter
Engine suspension engine liquid suspension fixation
Passing parameter approach angle32°,departure angle25°.portrait passing 23°(fully loaded)
Max. gradient 2、4WD
Exhaust system 2 Catalyzes, with stainless tail pipe
Min. ground clearance
Suspension mode(front/rear)
double-arm independent torsion bar suspension bracket/multipoint(5) connecting rod suspension bracket
نبذة سريعة عن الشركة :
Zhongxing, also known as ZX Auto, is a Chinese producer of SUV's and pick-ups co-owned by Brilliance China and Taiwan Unite Leading Co. The firm also produces a version of the Admiral SUV in Russia, in a deal with the FAW firm. In 2007, Zhongxing Automobile was the second largest pickup truck manufacturer in China, after Great Wall.
Zhongxing Automobile awarded a contract to ZX Automobile Company of North America, Inc. (ZXNA) to sell rebadged and upgraded versions of its Grand Tiger pickup trucks and Landmark SUVs in the U.S., Canada, and Mexico in the fourth quarter of 2008.[1] ZXNA is a wholly owned subsidiary of China America Cooperative Automotive, Inc. (CHAMCO AUTO), a holding management company incorporated in New Jersey.
سعر السيارة في مصر مابين
124 الف جنيه ( 4 راكب ) و 154 الف جنيه ( 7 راكب )
و في موديل مانوال - اتوماتيك 4 راكب
و مانوال - اوتوماتيك 7 راكب .
اعتقد السيارة حتعمل ضجة كويسة خصوصا لراغبين سيارات ال SUV و لكن موتورها مش مقنع خالص
2400 سي سي ميتسوبيشي قديم جدا !ٍ SOHC بيولد 125 حصان فقط علي سيارة بهذا الحجم ! مافيش عجب ان عدادها 160 فقط
السيارة طبعا قفلت علي موضوع " الماهيندر " دي نهائي !
بس العجيب و المفارقة ان Brilliance و هي احد السيارات التابعة للمجموعة البافارية ! تمتلك جزء كبير من الشركة المصنعة للاندمارك .
نرجع للسيارة . اعقتد انها كويسة جدا بالنسبة لتمنها بس هي برده مع انها سعرها كويس الا انها حطت نفسها قدام الجراند فيتارا .
برغم صغر الفيتارا ! الا انها تمتلك محرك 1600 يولد تقريبا نفس القوة الحصانية او قريبة منها !
بس قرار تجميعها في مصر حيتحيلها سوق اكبر عن استيرادها فقط !
ياريت تكون بداية طيبة لسيارات SUV " شبه " مصرية :)
