رقم العضوية : 30589
الاقامة : Giza
السيارة: Hyundai accent sport 2011 A/T
السيارة[2]: Punto MK2b 2009
Here's all the steps I've done, and still having the sam problem:
1- I went to the BURQAN "Certified Agency for OMATRA": They told me the throttle body needs to be cleaned and that's what they have done!.
2- The car wasn't vibrating or stopping again, but the RPM was getting high in a crazy way with the AC compressor on.
3- I went to the BURQAN "Certified Agency for OMATRA": They cleaned the throttle body again, and they checked the car on the comupter.
4- The car is again, vibrating, stopping, with high RPM conditioned by having the AC working.
5- I went to the ACSA "Certified Agency for OMATRA": They told me that they didn't see the problem!
6- I went to the BURQAN "Certified Agency for OMATRA": They cleaned the throttle body again, and asked me to go to the main center for OMATRA.
Note: I paid in the 1st visit to BURQAN, and to ACSA…. While the car is still under warranty.
7- I went to the main center of OMATRA last Saturday "7th of August, 2010".
8- The main center of OMATRA has changed the throttle body, the manifold. They tried even changing the control unit!
9- The last infromation I got from OMATRA is that it's a problem with the injectors "2 of them" are leaking and not spraying.
11- Tuesday "10th of August", OMATRA called me and told me that the car has been fixed and ready "after changing the injectors". I went to them to find the car is so dirty "interior and exterior", the fuel empty indicator was "on", the same problem is still there "the RPM was getting higher and didn't go to the steady state", and I started to hear sounds from the "front" in bumpy roads.
12- Wednesday "11th of August", OMATRA changed the MAP sensor and the car is still under testing.
Thanks,
رقم العضوية : 64559
الاقامة : Egypt- Mansoura
السيارة: Hyundai accent 1500cc
السيارة[2]: Suzuki Swift 1992
