4WD rules!
4WD rules!
4wd =more torque
more streamline
but poorest first impulsion than rwd or fwd
طبعا ال Rear Wheel Drive اكتر حاجة بحبها من كتر ما بشوف الدريفتات بقيت بحب اوى الدفع الخلفى بس فى حالتك فعلا من المنتقى انك تخليها 4wd لأن غير كدة لازم يكون عندك Tc و Esp علشان متفقدش السيطرة على العربية مع اى دوسة بنزين بنزين جامدة على سرعة منخفضة :) او فى ملف
+1111111
4wd is slwoest but firmest
i don't understand the "slow" part of your post
search on youtube for best motoring vids and look at the video of the supra vs evo 8 and some other RWD car... the race was during rain and at the start the evo jumped on both cars like they were driving in reverse
ok i agree RWD is more fun during drifting and so... on a tight bendy course though AWS rules and will eat any FWD and RWD
check the WRC rally footage on youtube as well... you can put the pedal to the metal when the car is going totally sideways and you still have it controlled... hell it will even correct itself when the front gains traction and you won't lose any of your speed
the best thing about your car is light weight
4wd increase weight ,increase fuel consumption more maintenance costs and not so much fun also if you watch the autoX did you see what happend to the 4wd mira not reliable with high power engines
but of course it will handle the power better than the fwd and infinite levels of grip
i didn't see the mira but a high powered mira on egyptian autox is not the bench mark for AWD... check the WRC cars and what they can do
300HP and 60 Kgs of torque yet the ultimate power control
... just watch what a driving legend can do with a WRC car on an icy race circuit... cna you go that fast with a RWD and have 1/10 of that control???
http://www.youtube.com/watch?v=tQTtopeHWqY
yes you are right in rallying it is a different story but here in egypt there is no gravel or sand it is just too much cost and unreliable but sure better than fwd
i didn't mean a high powered mira i meant that powerfull engines must have a powerfull drive train to cope with it
the mira wasn't powerful but the drive shafts failed
ouch... i haate it when this happens
