متوقعش .. انا اللي اعرفه ان ال ecu هو اللي بيظبط نفسه على سواقه حضرتك ...
رقم العضوية : 70832
الاقامة : Sharkia
السيارة: Daewoo Lanos 1
السيارة[2]: Toyota Yaris 2008 M/T
رقم العضوية : 47706
الاقامة : Alexandria , Egypt
السيارة: ياريس 2009
السيارة[2]: كابريس 1992
دراجة بخارية: لا طبعا .. نار بقى و حرايق
[img2]http://i945.photobucket.com/albums/ad291/BLOODY_STONE_2010/isamuIsamu.jpg[/img2]
رقم العضوية : 70832
الاقامة : Sharkia
انا شاكر جدا على ردك
Aurion , Only for the ambitious
رقم العضوية : 28931
الاقامة : mansoura
السيارة: mafe4
السيارة[2]: بدور
مش عارف و الله ..... بس اكيد هتلاقى ناس كتير فى المنتدى هتفيدك ...
حضرتك ممكن تعيد الموضوع للقسم التعليمى مثلا , علشان الناس كلها تشوفه ...
رقم العضوية : 47706
السيارة: ياريس 2009
A special category of ECUs are those which are programmable. These units do not have a fixed behavior, but can be reprogrammed by the user.
Programmable ECUs are required where significant aftermarket modifications have been made to a vehicle's engine. Examples include adding or changing of a turbocharger, adding or changing of an intercooler, changing of the exhaust system, and conversion to run on alternative fuel. As a consequence of these changes, the old ECU may not provide appropriate control for the new configuration. In these situations, a programmable ECU can be wired in. These can be programmed/mapped with a laptop connected using a serial or USB cable, while the engine is running.
The programmable ECU may control the amount of fuel to be injected into each cylinder. This varies depending on the engine's RPM and the position of the accelerator pedal (or the manifold air pressure). The engine tuner can adjust this by bringing up a spreadsheet-like page on the laptop where each cell represents an intersection between a specific RPM value and an accelerator pedal position (or the throttle position, as it is called). In this cell a number corresponding to the amount of fuel to be injected is entered. This spreadsheet is often referred to as a fuel table or fuel map.
By modifying these values while monitoring the exhausts using a wide band lambda probe to see if the engine runs rich or lean, the tuner can find the optimal amount of fuel to inject to the engine at every different combination of RPM and throttle position. This process is often carried out at a dynamometer, giving the tuner a controlled environment to work in. An engine dynamometer gives a more precise calibration for racing applications. Tuners often utilize a chassis dynamometer for street and other high performance applications.
Other parameters that are often mappable are:
Ignition: Defines when the spark plug should fire for a cylinder.
Rev. limit: Defines the maximum RPM that the engine is allowed to reach. After this fuel and/or ignition is cut. Some vehicle have a "soft" cut-off before the "hard" cut-off.
Water temperature correction: Allows for additional fuel to be added when the engine is cold (choke) or dangerously hot.
Transient fueling: Tells the ECU to add a specific amount of fuel when throttle is applied. The term is "acceleration enrichment"
Low fuel pressure modifier: Tells the ECU to increase the injector fire time to compensate for a loss of fuel pressure.
Closed loop lambda: Lets the ECU monitor a permanently installed lambda probe and modify the fueling to achieve stoichiometric (ideal) combustion. On traditional petrol powered vehicles this air:fuel ratio is 14.7:1.
Some of the more advanced race ECUs include functionality such as launch control, limiting the power of the engine in first gear to avoid burnouts. Other examples of advanced functions are:
Wastegate control: Sets up the behavior of a turbocharger's wastegate, controlling boost.
Banked injection: Sets up the behavior of double injectors per cylinder, used to get a finer fuel injection control and atomization over a wide RPM range.
Variable cam timing: Tells the ECU how to control variable intake and exhaust cams.
Gear control: Tells the ECU to cut ignition during (sequential gearbox) upshifts or blip the throttle during downshifts.
A race ECU is often equipped with a data logger recording all sensors for later analysis using special software in a PC. This can be useful to track down engine stalls, misfires or other undesired behaviors during a race by downloading the log data and looking for anomalies after the event. The data logger usually has a capacity between 0.5 and 16 megabytes.
In order to communicate with the driver, a race ECU can often be connected to a "data stack", which is a simple dash board presenting the driver with the current RPM, speed and other basic engine data. These race stacks, which are almost always digital, talk to the ECU using one of several proprietary protocols running over RS232 or CANbus, connecting to the DLC connector (Data Link Connector) usually located on the underside of the dash, inline with the steering wheel
رقم العضوية : 47706
السيارة: ياريس 2009
دي شوية حاجات لاقيتها عالنت ...
