صفحة 3 من 3 الأولىالأولى 1 2 3
النتائج 21 إلى 29 من 29
  1. #21
    الصورة الرمزية coco2003
    رقم العضوية : 54453
    الاقامة : Egypt
    السيارة: دايو نوبيرا
    السيارة[2]: سكودا اوكتافيا
    الحالة : coco2003 غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة abdelrahman.h مشاهدة المشاركة
    الجهاز ده لو طلبته أون لاين حيوصل لحد بيتك بالشحن ب 142 دولار يعني حوالي 815 جنيه و 10%جمارك و 10%ضريبة يعني يعمل 990 جنيه
    ودي صورته في اللينك ده
    convenient, useful, safe : Buy gps,gsm 850/900/1800/1900 car alarm and tracker - gzhe103k - from ipmart.com
    ودي مواصفات الجهاز
    working based on existing gsm/gprs 850/900/1800/1900mhznetwork and gps satellites
    personnel management.
    Build-in gps personal locator.
    Sos and monitoring functions.
    Provide peace of mind for businessman.
    Anti-theft of the vehicle/ heavy equipment etc.
    Protection of the child / elderly / disabled / pets etc.
    Control the trace of anything that is important to you.
    High sensitivity, high-end technology and latest gps chipset.
    Auto report position.
    Built in tf card slot. Support storing data in tf card, the gps data will be stored into the tf card automatically when there
    support usb connector and gsm/gps antenna connector.
    Built in sim card slot. Support two gsm sim cards, the unit works with the other card automatically when one card has no gsm signal or no phone charge.
    Key features
    bands ( gsm 850mhz/900mhz/1800mhz/1900mhz )
    in dc: 12-24v
    out dc: 5v/1a
    auto report position.
    Support gprs data transmission.
    Support sending commands by computer.
    Remote sending commands by gprs server and sms.
    Get the target\'s latitude and longitude by sms or gprs, and check position on google earth/maps.
    Support storing data in tf card, the gps data will be stored into the tf card automatically when there\'s no gprs signal.
    Send the last location if the target enters into the blind area.
    Add or change username and password and authorized number.
    Remote monitoring and sos function, and two-way communication.
    Send a geo fence ..... To the user when it breaches the restricted area.
    Send a movement ..... To the user when it begins to move.
    Send an over speed ..... To the user when it moves exceed of the restricted speed.
    Send a low battery ..... To the user if the battery is low.
    Send an ..... Of theft to the user automatically if the power be cut off or the vehicle be startup illegally.
    Send sms to the unit to cut off the vehicle engine and circuit when someone startup the vehicle illegally in anywhere and anytime.
    Applications
    manage vehicle rental or outside equipment, etc.
    Fleet management.
    Protect the child / elderly / disabled / pets etc.
    Track criminals secretly.
    Package contains :
    1 x gps/gsm main box
    1 x gps antenna
    1 x gsm antenna
    1 x manual
    1 x tracker
    1 x sim card
    1 x compact disc
    1 x connect wire
    product specification
    size
    80(l)x60(w)x25(h) mm
    weight
    100g
    network
    gsm/gprs
    band
    gsm sensitivity
    less than—102dbm
    gps chipset
    sirf iii chipset
    gps sensitivity
    -159dbm
    gps accuracy
    5m
    cold/ hot ttff
    35/2s
    car charger
    12-24v input, 5v output
    battery power
    3.7v dc li-ion battery,1100ma
    battery life
    about 48hours
    operating temperature
    -10degrees celsius to 65degrees celsius
    storage temperature
    -20degrees celsius to 70degrees celsius
    relative humidity
    5% to 95 %, non-condensing
    يا باشا واحد صحبى بعت جابه ووقف فى الجمارك وكان عاوز تصريح من المرفق القومى للاتصالات
    وطبعا المرفق موفقش بالجهاز
  2. #22
    الصورة الرمزية Abdelrahman.H
    رقم العضوية : 15145
    الاقامة : Jeddah - KSA
    السيارة: Proton SAGA A\T 10
    السيارة[2]: Proton GEN-2 A\T 06
    دراجة بخارية: CF-Moto Jetmax 250
    الحالة : Abdelrahman.H غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة coco2003 مشاهدة المشاركة
    ماهو لو أي حد عايز يجيبه يكتب في مكان عنوان الشحن عنوان أي حد قريبه أو صاحبه في الخليج او أوروبا و صاحبه يجيبه معاه وهو نازل أجازة ... دلوقتي في المطار ما بقاش حد يفتش
    [aldl]http://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/168147_1550165198896_1378080268_31320378_1917853_n .jpg[/aldl]
  3. #23
    الصورة الرمزية aymanay32
    رقم العضوية : 46168
    الاقامة : الهرم
    السيارة: ماروتى 2009 الاصيلة
    السيارة[2]: فيورا- فولكس واجن-ميتسوبيشى لانسر بطة
    الحالة : aymanay32 غير متواجد حالياً
    و افرض الطوبة حت فى المعطوبة و راح الجهاز فى الجمارك فى المطار
    و بعدين انا لاقيت من مواصفات شريحة موبايل سيم كارت
    يعنى بردوا مش هينفع فى مصر
    السلام لكل الماروتى
  4. #24
    رقم العضوية : 54453
    الاقامة : Egypt
    اقتباس المشاركة الأصلية كتبت بواسطة aymanay32 مشاهدة المشاركة
    الجهاز فعلا هيقف فى الجمارك
    بس عاوز اوصلك ان الجهاز شغال كويس جدا وانا جربته بنفسى وشوفت امكانياته كلها
  5. #25
    الصورة الرمزية Tayer
    رقم العضوية : 47068
    الاقامة : EL SHEK ZAYED 6 OCTOBER
    السيارة: يا رييييييييت
    السيارة[2]: GEN 2 -2010
    الحالة : Tayer غير متواجد حالياً
    ممكن شرح فكره عمله ؟
    أعرف حاجه عن كل حاجه أحسن متعرف كل حاجه عن حاجه.
    FOR BEAUTIFULL MIND ONLY
  6. #26
    الصورة الرمزية أبو_يوسف
    رقم العضوية : 41767
    السيارة: ___
    السيارة[2]: Cerato 2006
    دراجة بخارية: !!
    الحالة : أبو_يوسف غير متواجد حالياً
    نظرا لان الجهاز دا ممنوع دخوله مصر
    كنت طرحت فكرة بديلة في هذا الموضوع
    http://www.nilemotors.net/Nile/167905-a.html
  7. #27
    الصورة الرمزية sefelden2005
    رقم العضوية : 75768
    السيارة: Dayo
    السيارة[2]: Marsedes
    الحالة : sefelden2005 غير متواجد حالياً
    انا باشكر كل من هو قائم وصانع ومسئولين عن هذا الموقع الممتاز ولكل فرد مشترك فيه وهذه اول اضافه ليا ان شاء الله ويارب تكون فيها أفاده للجميع
    يوجد هذا لبجهاز فعلا فى أسكندريه ودى تفاصيله واسعارة واماكنه
    الصفحه الرئيسيه : عربيات ، موتوسيكلات و قوارب » قطع غيار و اكسسوارات
    انذار سياره يجعل سيارتك فى موبايلك يرن عليك وتبطل السياره منه - واستمت
    حالة السلعة:
    جديدة تماما
    الكمية:
    44 متاح
    سعر البيع:
    850.00 جنيها مصريا
    اشتري هذه السلعة بسهولة وأمان مع سوق سيف باي اعرف المزيد...
    طريقة الشحن و الدفع المتاحة لهذه السلعة
    الشحن بعد الدفع الألكتروني ( أون لآين )
    الدفع النقدي عند إستلام الشحنة COD
    كبّر الصورة
  8. #28
    الصورة الرمزية MaZaGAngeE
    رقم العضوية : 19004
    الاقامة : El-menya
    السيارة: Lancer 1993 & VW 1964
    السيارة[2]: نيسان صني فيس لفت
    دراجة بخارية: هانكو 150
    الحالة : MaZaGAngeE غير متواجد حالياً
    مفيش منه بيشتغل جي بي اس من غير شريحة تلفون ؟ لو العربية دخلت مكان مفيش شبكة فيه خلاص كده ضاعت
    [mshosh2]http://www.4shared.com/photo/lCkSz74F/morsee.html[/mshosh2]
  9. #29
    الصورة الرمزية khaled_sabry
    رقم العضوية : 30583
    الاقامة : Egypt - Cairo , Canada - Alberta
    السيارة: Toyota Corolla 1978 ,Peugeot504 1983, Peugeot 406 2006,kia pride 2000,chevrolet traverse 2009,Mazda3
    السيارة[2]: BMW 320i 2002,BMW X5 2007,BMW X5 F15 2014
    دراجة بخارية: نفسى اتعلم سواقتها
    الحالة : khaled_sabry غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة MaZaGAngeE مشاهدة المشاركة
    احتمال صعب انك دلوقتى تلاقى مكان مافيهوش شبكه حتى ماكنش محمد منير قال ( و تقنع ناس كتير متغطيين) الا لو كان الحرامى عامل حسابه للجهاز ده و عارفه كويس
    و هو يعنى الحرامى حيطلع ناصح اوى و ياخد العربيه و يجرى بيها على الصحراء ؟؟؟
  1. جهاز انزار gsm & gps ( تحكم موبيل و تحديد مكان السيارة )
    بواسطة mmtronic في المنتدى كــماليــات السيـــارات و الإكسسوارات
    مشاركات: 22
    آخر مشاركة: 06-09-2012, 03:53 PM
  2. ما هي طريقة تحديد وتثبيت سرعة السياره ؟
    بواسطة gfd في المنتدى ورشـــة نــايل مــــوتـــورز
    مشاركات: 29
    آخر مشاركة: 18-02-2011, 06:31 PM
