موضوع جميل بس افرد عايز لون العربيه ممكن الاقي
وهل المنتج ده موجود في مصر
رقم العضوية : 45
الاقامة : المعادي..أخر الشارع
السيارة: Logan A/T-Yaris HB HL
السيارة[2]: Astra J Cosmo
دراجة بخارية: NO
بقالي فترة موضوع الجنوط و ألونها شاغلني...فا جربت أعمل سيرش علي تلوين الجنوط..لاقيت تن الموضوع سهل و مش محتاج خبرة كبيرة قوي....بس اهم حاجة الحرص الشديد و أنت بترش...
أسيبكم مع الموضوع و يا رب يعجبكم:)
____________________________________
Paint your own Rims? Who would of thought something
previously done by professionals could be done in your own home.
While, the concept of painting your own rims has been around a few years now, many questions pop up of how to do it and I thought I would share my own experiences with painting my Integra stock rims. I have read up many examples of how to do this, but my first time trying was this year when I chose to refinish my winter rims. I was quite please with the outcome.
First, what the hell do you need to paint your rims? Paint of course :) This is where Duplicolor comes in with their wheel paint. They offer paint colors to match your style coming in white, gunmetal, classic silver and bronze as well. I chose to do mine in gunmetal leaving my lip the stock polished style look. So here are your options:
So you chose your colour, bought your paint and are semi-ready. First, you need to sand down your rims. Why? This gives the surface a rough texture so the paint has something to adhere to. Reference the article to polish your rims on how sanding of the rims works. The only difference with this is how far you want to go. In my case, being winter rims painted I chose not to go through the process of stripping the paint on the rims completely. I simply sanded down the surface with 300 grit sandpaper ensuring to make everything sanded equally. This gives the rough surface required for the paint to adhere, and as long as your rims had no damage it should be good enough.
Your rims are sanded, you have your paint and now are ready. First, make sure you clean all sanding dust off the rims and ensure a totally clean surface so the paint will stick and not flake off after your first drive out with your newly painted rims!!! Here are my rims washed and ready to completely dry before painting:
Here is an upclose shot of my Sanded Rim ready to have a fresh coat of Gunmetal paint applied to it:
You will notice my rims are masked off with newspaper and masking tape. Of course you want to do this so you dont turn your tires into the color you are painting. I don't want gunmetal painted tires. Also if you look close enough, you will know that the lip has been masked off as well. So I carefully applied the masking tape on the lip to protect it from being painted as well. Also, you know the lil thing you pump your air into, mask that off as well unless you want that to have a color change as well :)
The rims are dry, you have masked off what you dont want painted and now you are ready. Put some newspaper on the ground and place the rim on top of the newspaper. You don't want to paint the concrete underneath the rim so keep it clean with the newspaper.
Now apply your first coat of paint (gunmetal on my rims). Here is my first coat on two of the rims (the two on the right have been painted):
Here are pics of the rims painted and masked:
A couple of good shot of the Rim Painted with the Clear Coat shining while drying:
Now put away your rims somewhere and let them dry so the paint has time to cure. I left mine for a couple days and then took off the masked newspaper and tape. And the results are in.
Three Rims lined up and painted:
Up Close view of Dried Clear Coat, Nice and shiny :)
Here is single shots of the rims without the center caps installed yet:
Here is single shots of the rims with center caps installed yet:
Hope you enjoyed my venture into painting my own rims and hope this may tempt you trying the same with your old rims that you were maybe thinking of throwing away, but now can refinish into a nice set of rims.
منقول
رقم العضوية : 2660
الاقامة : حدائق الاهرام
السيارة: :(
السيارة[2]: lanos 99
دراجة بخارية: nop
[mshosh2]http://s3.postimage.org/z1xf3bakp/image.jpg[/mshosh2]
Mahmoud Fayed
رقم العضوية : 45
دراجة بخارية: NO
ماتعملش جنوط بلون العربية...هتبقي وحشة و مش هيبقي فيه contrast
لو عربيتك فاتحة حط جنط غامق...اسود أو رمادي
لو غامقة يبقي حط فضي أو أبيض...
رقم العضوية : 47
الاقامة : Al Monofeya
السيارة: Proton Wira
السيارة[2]: Lada 2015
طيب نجيب من البتاع ده؟
وفى منعه لون دهبى أو شامبين ولا لأ؟
رقم العضوية : 47
رقم العضوية : 32
الاقامة : جسر السويس-القاهرة
السيارة: BMW E90
السيارة[2]: Jeep KK 2009
رقم العضوية : 333
الاقامة : شرم الشيخ
السيارة: Optra 2010 A/T
السيارة[2]: Optra 2010 A/T
رقم العضوية : 3593
الاقامة : MANSOURA
السيارة: fiat 127 abarth 70 hp
السيارة[2]: pegout 504
انت عملت مجهود رائع فى اشرح وانا اتحمست قولنا نجيبه منين ماتسيبناش زى الفرخه الدايخه؟
رقم العضوية : 45
دراجة بخارية: NO
هو مش انا اللي عملت المجهود:)...الموضوع منقول:)
و يا كريم ممكن تعملها في مكان مغلق زي جراج مثلا أو تعملها في البلكونة في يوم مشمس و مافهوش رطوية أو عفرة...(فيه أيام زي ديه جايه بس كمان شهر كده:))
بالنسبة للون يتجاب منين انا معنديش فكرة بس ممكن نريح دمغنا و نوديها لبوهيجي يعمل القصة دي كلها و يضرب الليون اللي انت عايزة و يرشة و يدخله الفرن
رقم العضوية : 8412
الاقامة : Egypt - GIZA
السيارة: Waiting For
السيارة[2]: Daewoo - Lanos
طيب هل في ورش بتعمل الدهان او التلميع ده للجنوط ؟
