النتائج 1 إلى 10 من 22
الموضوع: تركيب rear door seal
    الصورة الرمزية romany777
    رقم العضوية : 42412
    الاقامة : Kafr Sakr
    السيارة: vectra CDX 2001
    السيارة[2]: نوبيرا 2002
    الحالة : romany777 غير متواجد حالياً
    افتراضي تركيب rear door seal - Facebook Twitter whatsapp انشر الموضوع فى :
    اقتباس المشاركة الأصلية كتبت بواسطة iRox مشاهدة المشاركة
    DISCLAIMER: I take no responcibility for any damage done to your car from reading this guide!
    Right, Hey All!
    This 'How2'/Guide will hopefully show you how to apply the rear door seals found on the CDX models to your car. Its not too difficult, with a bit of time and confidence youll get on fine :) So lets get started! First off, heres some seals to show you what they look like, as youll need a pair with inserts!
    Okeydokey, lets go!
    Tools Needed
    Drill
    4mm ....l Drill Bit
    Mallet
    Sillicon Sealant / Matching Colour Pen
    The Guide
    Righto, first off open the back doors and look down the outer side, you will notice small pin head indents all the way down the curve of the door, there should be 9 in total. Watch not to confuse them with the other indents, as I mentioned the ones you are after are like a prod from a pin. In this picture some of them are circled in green:
    Now, carefully drill into these indents with the 4mm bit - keeping the drill flush to the ....l as best you can. (start of slow and gradually build up speed as the drill bit digs in) Try not to wiggle the drill too much either, you dont want to make the hole too big! Also be carefully once you break through the ....l not to drill too much into the other side :D
    Reapet for all 9 spots down the door, once finished it should a little like this:
    If, like my doors, they are a bit dirty now is the time to give them a quick clean-up especially at the areas around the holes. (this is so the silicon/paints bonds well to the ....l, and not the dirt :D) Once thats done, you can either use a touch-up paint pen or silicon sealant (clear) to act as an anti-rust barrier. Or, if you have your own prefered method, use that now! This is how mine looked at this point:
    Nearly done now! As you go to push in each insert from the seals, you may notice it can be a tight fit, this is where you may need to use the mallet. If you do then gently hold the seal to the door, align up the hole to the plastic insert and gently tap on the back of the seal. After one or two taps the insert should go in and feel nice and solid due to the tight fit!
    Again, repeat these steps for the rest of the seal inserts untill the whole seal is firmly inplace! Once done, wipe away any excess paint/silicon, stand back and admire your new seals! :D
    Job done! Obviously you will have to repeat for the other door but I'm sure you've worked that one out yourself lol :D
    If you have any comments, suggestions, complaints etc. pass them on!
    Cheers.
    الصورة الرمزية tananybasha
    رقم العضوية : 23085
    الاقامة : Giza
    السيارة: لايوجد حالياً
    السيارة[2]: Opel Vectra A Sport 2.0L M/T
    دراجة بخارية: هوندا 1000
    الحالة : tananybasha غير متواجد حالياً
    مقتبس منين
    لو أن ابن آدم هرب من رزقه كما يهرب من الموت لأدركه رزقه كما يدركه الموت
    محمد الطنانى
    رقم العضوية : 42412
    الاقامة : Kafr Sakr
    النسخه العربى علشان الحبايب
    طريقه تركيب العازل الجلد فى الباب الخلفى
    دى صوره العازل الجلد اللى هنركبه فى الباب الخلفى للعربيه
    هنحتاج شنيور وقلم فلوماستر وانبوبه سيليكون
    هنعلم فى الباب مكان الخروم على حسب عدد المسامير اللى فى العازل الجلد( فى الغالب 9 مسامير)
    ونخرم الباب قطر الفتحه حوالى 4 ملى
    متخايش الفتحات توسع عن 4 مللى علشان العازل يثبت كويس
    دى شكل الفتحات بعد الشغل
    نضف كويس مكان الفتحات
    وبعدين نحط السليكون فى الفتحات ونثبت العازل
    الف مبروك العازل الجديد
    vvoc.com
    الصورة الرمزية ENG\AHMED
    رقم العضوية : 4805
    السيارة: Fluence 11,lanos 01
    السيارة[2]: FOCUS 06,PICANTO 13
    الحالة : ENG\AHMED غير متواجد حالياً
    ماهو موجود اصلا فى الفكترا بى
    رقم العضوية : 42412
    الاقامة : Kafr Sakr
    اقتباس المشاركة الأصلية كتبت بواسطة eng\ahmed مشاهدة المشاركة
    تمام يا باشا
    علشان الفيكترا a متزعلش مننا
    رقم العضوية : 23085
    الاقامة : Giza
    لو ايه اللى حصل مش هاخرم فى الباب عشان اركب كاوتشه
    محمد الطنانى
    الصورة الرمزية فادى محمد
    رقم العضوية : 21177
    الاقامة : damietta
    السيارة: الحمد لله
    السيارة[2]: opel vectra 1600 mo.1999
    الحالة : فادى محمد غير متواجد حالياً
    والله يا طنون انا لسه شايف النهارده واحد معاه فيكترا بي لسه موظبها وعاوز يركب ايريال علي طرف السقف اللي ورا تخيل عمل ايه ؟؟خرم السقف حتت خرم نص قطر الدايره 1سم !!الشنيور شغال وكانه بيقطع في قلبي ,عاوز اقوله حرااااام .بس بامانه تعب عقبال ما خرم السقف والصاج ماشاء الله تخييين.
    اخوكم /فادي محمد عيد ..من مواضيعي المصوره للفيكترا بي ....
    http://www.nilemotors.net/Nile/97671...post3872017889 تغيير اويل سايل اسبراتير
    http://www.nilemotors.net/Nile/13044...post3872432932تنظيف الايديال كونترول
    http://www.nilemotors.net/Nile/15035...post3872669019تعديل في اضاءه التابلوه
    http://www.nilemotors.net/Nile/143705-b.html#post3872580355تغيير فرش السقف للفيكترا
    http://www.nilemotors.net/Nile/181441-a.html#post3873046581تغيير جوان وش التاكيهات
    hellboy سابقا
    رقم العضوية : 23085
    الاقامة : Giza
    ما ده اسمه جنان رسمى
    محمد الطنانى
    الصورة الرمزية mera11
    رقم العضوية : 83255
    الاقامة : Bahrain
    السيارة: opel vectra A1.6
    السيارة[2]: lada
    الحالة : mera11 غير متواجد حالياً
    مفيش حل من غير تخريم
    سبحان الذى سخر لنا هذا وما كنا له مقرنين وإنا إلى ربنا لمنقلبون
    سعيد خالد
    الصورة الرمزية ashrafnoby
    رقم العضوية : 40013
    الاقامة : الاسماعليه
    السيارة: اوبل فيكترا 1995 1600 سىسى
    السيارة[2]: اوبل فيكترا 1995 1600 سىسى
    دراجة بخارية: دراجة نارية
    الحالة : ashrafnoby غير متواجد حالياً
    العازل الجلد اجيبه منين وسعره كام وشكرا على طريقه الشرح الجميله الرائعه
  1. rear bumper diffuser
    بواسطة smsm_nabawy في المنتدى تعـــديل الســـيارات و الإضافات
    مشاركات: 6
    آخر مشاركة: 15-08-2011, 03:34 PM
  2. rear smoke light
    بواسطة Tarek Gen 2 في المنتدى بــروتـــون
    آخر مشاركة: 16-07-2011, 11:54 AM
  3. 250 fire 1996 4 seal
    بواسطة moamen23 في المنتدى قسم بيع وشراء للدراجات النارية
    مشاركات: 16
    آخر مشاركة: 05-05-2011, 12:27 AM
  4. Rear screen de-icing
    بواسطة MACATHIUS في المنتدى قسم خاص بالسيارة لـــوجـــــان
    آخر مشاركة: 27-05-2010, 05:21 PM
  5. seal car
    بواسطة ahmedashram في المنتدى قســم خاص لبيع السيارات فقـــط
    آخر مشاركة: 03-12-2008, 02:19 PM
