الفتيس اللى فى الميجان غير اللى فى الاسترا و الكورولا
فتيس الميجان اصلا فتيس اتوماتيك
اما الاسترا و الكورولا فهو مانيوال لكن بينقل بطريقة اتوماتيك, و اسمه automated manual transmission
و ده شرح له:
Automated Manual Transmission (AMT)
Automated manual transmissions combine the best features of manual and automatic transmissions.
Manual transmissions are lighter than conventional automatic transmissions and suffer fewer energy losses. However, most drivers prefer the convenience of an automatic.
AMT operates similarly to a manual transmission except that it does not require clutch actuation or shifting by the driver. Automatic shifting is controlled electronically (shift-by-wire) and performed by a hydraulic system or electric motor. In addition, technologies can be employed to make the shifting process smoother than conventional manual transmissions
اللى بيتقال عليه نتشة ده, هو مش نتشة خالص: هو بس احساس بالنقلات, كأن واحد بينقل فتيس مانوال لكن بهدوء شوية
