فيه كلام جديد قالوهولى
قالولى لو الجو فى مصر بيبقى حر قوى خلى المدى الحرارى 6 ولما سئلتهم هى بتعلى الهورس بوور بتاع الماتور ولا لأ ردو عليا والرد اهو زى ما بعتوا
It is only the service life / life span of the spark plug but for the horse power it is not. Changing your power cable will do.
Standard type of spark plug like BKR5ES-11, replacement is like 3000-5000 km you should change.
Platinum type like BKR5/6EGP – 5000-10000 km
IRIDIUM type like BKR5EIX-11 – 10000-20000 km
Above are just ideal replacement period to achieve its maximum performance but in reality changing of spark plug may vary accordingly depending on
how frequent you use your car.
Hope this information will help you decide which spark plug you have to choose.
Thanks
Erwin
