أخى العزيز
خد دى مواصفات الباك كاملة
Engine Type - Liquid-cooled, 4-stroke V-Twin
Displacement - 903 cm3
Bore and Stroke - 88.0 x 74.2 mm
Valve system - SOHC, 8 valves
Fuel system - Fuel injection: � 34 mm x 2 with dual throttles
Ignition - Digital
Starting - Electric
Lubrication - Forced lubrication, wet sump
Transmission - 5-speed, return
Final drive - Belt
Primary reduction ratio - 2.184 (83/38)
Gear ratios - 1st: 2.786 (39/14), 2nd: 1.889 (34/18), 3rd: 1.360 (34/25), 4th: 1.107 (31/28), 5th: 0.963 (26/27)
Final reduction ratio - 2.063 (66/32)
Clutch - Wet multi-disc, manual
Frame Type - Double-cradle, steel
Wheel travel - front: 150 mm, rear: 100 mm
Tyre - front: 130/90-16M/C 67H, rear: 180/70-15M/C 76H
Caster (rake) - 32�
Trail - 164 mm
Steering angle (left/right) - 38�/38�
Suspension - Front: Type, 41 mm telescopic fork, Rear: Type Uni-Trak Spring preload 7-way
Brakes - Front: Type, Single 300 mm disc Caliper Twin-piston Rear: Type, Single 270 mm disc Caliper Twin-piston
Wheelbase - 1,650 mm
Fuel capacity - 18 litres
ودى صورها
http://www.motards-online.com/moto-e...kiVN900_07.jpg
http://www.motards-online.com/moto-e...kiVN900_03.jpg
http://www.motards-online.com/moto-e...kiVN900_01.jpg
بس خد بالك أن السعر طبيعى جدا موش غالى ويمكن تلاقى حد عنده البايك يكون أرخص شوى
بس موش عارف هاتبقى زيها ولا لأ
وبعدين دور تانى ممكن تشوف حاجة برده تعجبك غيرها
سلام
