مفيش جيتا الشكل الجديد نزلت بزينون !!!اعلن وكيل فولكس واجن عن نزول السياره جيتا 2012 الجديده
اول فئه : Trendline 1
engine, gearbox
- cubic capacity, litres/cm³ : 1.4/1390.
- max. Output, kw (bhp) at rpm: 90(122) / 5000.
- max. Torque, nm at rpm : 200/1500 - 4000
- gearbox : 7-speed automatic dual clutch gearbox dsg.
performance
- top speed: 202kph.
- acceleration from 0-80/0-100 kph:6.8/9.8 seconds.
- fuel consumption, litres/100 km: 6.3 combined.
safety
- airbags for driver and front passenger.
- curtain airbag system for front and rear passengers incl. Side airbags at front.
- anti lock brake system (abs) + electronic brakeforce distribution (ebd).
- electronic stabalization programme (esp) incl. Brakes assist system with dual rate function.
- 3-point inertia reel seat belts with height adjustment and belt tensioners.
- disc brakes at front and rear, ventilated discs at front.
- electronic engine immobilizer.
operating & interior equipment
- "climatic" air-conditioning system.
- electric front and rear windows.
- electro-mechanical speed-sensitive power steering.
- “rcd 310” radio system with mp3 player function with aux-in interface.
- radio wave remote control for central locking, 2 radio wave keys.
- isofix anchorage mounting points for two child seats on rear seat bench.
- electrically adjustable and heatable exterior mirrors.
- multi-function display.
- cruise control.
- driver's seat with height adjustment.
exterior equipment
- four 6.5j x 16 steel wheels with wheel security system, 205 / 55 r 16 tires
- halogen headlumps and turn signal lamps under one clear glass cover.
- front & rear fog lights.
- day-time running lights.
dimensions
- length / width / height : 4640 / 1778 / 1453 mm.
- wheelbase : 2578 mm.
- ground clearance (with full load) : 119.0 mm.
- fuel tank capacity : 55 liters.
weights
- unladen weight : 1395 kg.
- gross vehicle weight: 1940 kg.
- payload : 580 kg.
الفئه الثانيه : Trendline 2
engine, gearbox
performance
safety
- "climatronic" air-conditioning system with dual zone climate control.
- multi-function steering wheel.
- front & rear park distance control.
- cruise control.
exterior equipment
- five 6.5j x 16 alloy wheels with wheel security system, 205 / 55 r 16 tires.
dimensions
weights
- payload : 580 kg.
الفئه الثالثه او الفول اوبشن: Comfortline
engine, gearbox
performance
safety
- "rcd 510" touch screen radio system with mp3 player function incl. 6cd changer with aux-in interface.
- cruise control.
- rear armrest inc. Two cup holders.
- 230-volt socket in center console.
- front passengers seat with height adjustment.
- lumbar support for front seats.
exterior equipment
- bi-xenon headlights for high & low beams.
- electric tilt/slide glass sunroof.
dimensions
weights
- payload : 580 kg.
و بالنسبه للأسعار للأسف معنديش معلومات اكيده بس السيارات متواجده فى جميع معارض الوكيل على حسب ما اعلن .
شكرا لمروركم..
بس انا شايف انها كدا بتنافس بشده عربيات كتيره خصوصا مع المحرك ال1.4 تيربو .. دا غير ان تسارعها اكيد ممتاز بالنسبه للحجم و الوزن بس هنا بيكون المحرك ال 1400 تيربو فعلا صغير على الباسات بس الجمارك هى السبب :/
