Dear Mr. Shebl,
thank you very much for contacting us and your interest in our LIQUI MOLY
products.
The difference between LIQUI MOLY CERA TEC and LIQUI MOLY MOTORPROTECT is
the composition of this products.
LIQUI MOLY MOTORPROTECT .......s a chemical component that hardens the
surfaces inside the engine under heat and pressure. So you can reduce wear
inside the engine.
LIQUI MOLY CERA TEC .......s also this chemical component and further a
solid lubricant that reduces friction very good. With CERA TEC you have a
ideal combination of these two active substances and we recommend you to
use this product in your new car.
Please see the attachement for more product informations :
(See attached file: 3721 Cera Tec_EN.pdf)
We hope we could help you with our informations. Should you have further
questions regarding our products we would be very pleased to get contacted
from you again.
Best Regards
i. A.
Steffen Niemietz
Anwendungstechniker
application engineer
Phone: +49 (0)731 / 14 20 - 658
Mobile: +49 (0)162 / 2 81 50 64
Fax: +49 (0)731 / 14 20 - 44658
LIQUI MOLY GMBH
F & E / Anwendungstechnik
Jerg-Wieland-Straße 4
D-89081 Ulm
www.liqui-moly.de
Amtsgericht Ulm HRB 1383 | Geschäftsführer: Ernst Prost
Court of registration Ulm, HRB 1383 | Managing Director: Ernst Prost
LIQUI MOLY ist Deutschlands beliebteste Motorenöl-Marke !
LIQUI MOLY is Germanys most popular motor-oil-brand !
Daten des Besuchers (englische Liqui Moly Webseite):
Firma:
Vorname: shebl
Strasse:
PLZ / Ort:
Land: egypt
Fax:
Nachricht:
i have a new car model 2011 elantra , and i ask which product to use to
protect my motor against wear and friction, cera tec or motorprotect, both
are nearly the same , but i want the best one, and more powerful one.
thanks in advance
