النتائج 1 إلى 10 من 11
    الصورة الرمزية Y a r i s
    رقم العضوية : 128488
    الاقامة : ★ قسم تويوتا.★
    السيارة: ♠ وشيخ الياباني حالياً ♠
    السيارة[2]: ♥ عمدة تويوتا ♥ سابقاً
    دراجة بخارية: ♥♥♥♥♥♥♥♥ ♡ ☜
    الحالة : Y a r i s غير متواجد حالياً
    Exclamation ابعاد جنوط اليارس ( مرجع لجميع مقاسات الكويتش والجنوط ) ! - Facebook Twitter whatsapp انشر الموضوع فى :
    مرجع لجميع مقاسات الجنوط
    التي يمكن تركيبها لليارس دون مشاكل !!
    Official YARIS Wheel & Tire Guide
    WHEEL BOLT PATTERN PCD = 4 x 100mm
    CENTRE BORE = 54.1mm
    OEM wheel sizes, offsets (ET), and tyre sizes (diameter in inches):
    14x5, ET45, 175/65/14 = 23.0
    15x5.5, ET45, 185/60/15 = 23.7
    16x6, ET51, 195/50/16 = 23.7
    17x6.5, ET51, 205/45/17 = 24.3
    TRD Option 18x7.5, ET42, 215/35/18 = 23.9
    With stock suspension, you may safely fit many tyres from 23.0 to 24.3, +/-3%.
    __________________________________________________ _______
    Recommended offsets (ET) and tyre widths (mm):
    ET35+ = 175-185
    ET38-ET40 = 175-195
    ET42-ET45 = 195-205
    ET45+ = up to 215
    Here is an excellent and easy to use wheel and tyre fitment guide:
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Optional tyre sizes (diameter in inches):
    *Commonly recommended replacement sizes
    Fitment depends on wheel width, offset, and suspension mods.
    175/65/14 = 23.0*
    185/65/14 = 23.5*
    195/65/14 = 24.0
    195/60/14 = 23.2*
    205/60/14 = 23.7*
    215/60/14 = 24.2
    185/60/15 = 23.7*
    195/60/15 = 24.2*
    195/55/15 = 23.4*
    205/55/15 = 23.9*
    195/50/15 = 22.7
    205/50/15 = 23.1* (Most lowered applications)
    215/50/15 = 23.5
    225/50/15 = 23.9
    195/50/16 = 23.7*
    205/50/16 = 24.1*
    215/50/16 = 24.5
    195/55/16 = 24.4
    205/45/16 = 23.2* (Most lowered applications)
    225/45/16 = 23.9
    205/45/17 = 24.3*
    205/40/17 = 23.5* (Most lowered applications)
    215/40/17 = 23.8
    215/35/18 = 23.9*
    225/35/18 = 24.2
    205/40/18 = 24.4
    Staggered fitments:
    1. Staggered offsets are common in Japan. These applications even out fitment front to rear and are purely for appearance. Tyre size generally remains constant front to rear. Staggered offsets preclude tyre rotation. Recommended maximum stagger is 10mm.
    Example: FR, ET45//RR, ET38
    Example: FR, ET42//RR, ET35
    2. Staggered tyre widths are less common, especially on front wheel drive cars. These applications even out front to rear fitment. They are not recommended for the track, but as an appearance option they are safe under normal driving conditions. Staggered tyre widths preclude tyre rotation.
    Example: FR 205/55/15//RR 225/50/15
    Example: FR 205/50/16//RR 215/50/16
    Example: FR 205/40/17//RR 215/40/17
    3. Wheels spacers are another option to even out fitment front to rear. Maximum recommended rear spacer width is 10mm. Tyre rotation is still possible.
    Example: FR, ET42//RR, ET42 with 5-10mm spacer
    وتحياتي
    منقول ومعدل من قبلي
    سقوط سماوات فوق رأس تجار روبابيكيا امين يارب
    الصورة الرمزية S O P H O S
    رقم العضوية : 71514
    الاقامة : EgYpT-ⵍⵎⵖⵔⵉⴱ-
    السيارة: -- -- all FiaT ---
    دراجة بخارية: - - - - - - -
    الحالة : S O P H O S غير متواجد حالياً
    Arrow -
    ـتـســلــم ايــدكــ يا حـج ,,
    تسلم يابوحميد ويخليك ليا
    http://www.nilemotors.net/Nile/312299-a-3.html
    الصورة الرمزية Mo.Kareem
    رقم العضوية : 52220
    الاقامة : مصر
    السيارة: Skoda a5
    السيارة[2]: اكسنت 98
    الحالة : Mo.Kareem غير متواجد حالياً
    طيب التويوتا كورولا 2004 4×100 ولا 4×114
    اقتباس المشاركة الأصلية كتبت بواسطة cdkareem مشاهدة المشاركة
    لا الكورولا ٢٠٠٤ ابعادها. ١٠٠ في ٤ خرم
    ويركب عليها جنوط اليارس. عادي كمان :) وتحياتي
    رقم العضوية : 52220
    الاقامة : مصر
    السيارة: Skoda a5
    الف شكرا يا ريس
    الصورة الرمزية ahmad--ezzat
    رقم العضوية : 6201
    السيارة: nissan sunny ex 2008
    السيارة[2]: Sonata 2013
    الحالة : ahmad--ezzat غير متواجد حالياً
    شكرااا ومعلومات جميله يا yaris
    انا بدور علي جنوط حديد لليارس 4x100 فعلا لانها نفس ابعاد الفيات
    لو حد عنده يديني مسج :)
    م/ احمـد عـزت
    الصورة الرمزية myself112
    رقم العضوية : 28931
    الاقامة : mansoura
    السيارة: mafe4
    السيارة[2]: بدور
    الحالة : myself112 غير متواجد حالياً
    تسلم ايدك :))
    الصورة الرمزية BLOODY_STONE
    رقم العضوية : 47706
    الاقامة : Alexandria , Egypt
    السيارة: ياريس 2009
    السيارة[2]: كابريس 1992
    دراجة بخارية: لا طبعا .. نار بقى و حرايق
    الحالة : BLOODY_STONE غير متواجد حالياً
    موضوع جميل اوي انا لسه قاعد بفك الطلاسم هههههههههههه عشان عايز اجيب جنوط قريب .. يا مسهل يا رب
    [img2]http://i945.photobucket.com/albums/ad291/BLOODY_STONE_2010/isamuIsamu.jpg[/img2]
    الصورة الرمزية amrrashed
    رقم العضوية : 376
    الاقامة : مصر الحبيبة
    السيارة: C4
    السيارة[2]: سوزوكى فيتارا
    الحالة : amrrashed غير متواجد حالياً
    شكرا علي المعلومات
    تعصى الاله وانت تزعم حبه هذا لعمرك فى المقال بديع
    لو كنت تصدق حبه لاطعتــه ان المحب لمن أحب مطيع
    عمرو راشـــــــــد
  1. جنوط 14 للبيع تايوانى ابعاد 4*100
    بواسطة mokhtarhany في المنتدى قســم خاص لبيع السيارات فقـــط
    مشاركات: 15
    آخر مشاركة: 10-01-2013, 11:47 AM
  2. ابعاد جنوط الياريس اية
    بواسطة Motaz.Habib في المنتدى تـويوتـــا
    مشاركات: 22
    آخر مشاركة: 25-09-2012, 09:55 PM
  3. هو ابعاد جنوط الهوندا 92 كام ؟؟؟؟
    بواسطة mody100 في المنتدى هـــــــوندا
    مشاركات: 6
    آخر مشاركة: 29-01-2012, 01:49 AM
  4. مطلوب جنوط 16 ابعاد 4*100
    بواسطة rageb في المنتدى قســم خاص لطلـبات شــراء الســـيارات و متعلقاتها فقـــط
    آخر مشاركة: 07-01-2012, 03:58 PM
  5. هل ابعاد جنوط ابيزا نفس ابعاد الكورى
    بواسطة waelms3 في المنتدى ورشـــة نــايل مــــوتـــورز
    مشاركات: 7
    آخر مشاركة: 23-08-2010, 01:37 PM
