طيب انا لقيت الموضوع ده على فتيس CVT للهوندا. ينفع نجربه فى اللانسر
Here is the procedure (copied from TOV) on how to reset then recalibrate your CVT transmission, it only takes a few minutes:
RESET CVT MEMORY (from singapore forum)
a) Start the car till it's normal temp
b) Do not switch on your air-con, radio, and other electrical stuffs
c) Apply handbrake (throughout this whole procedure)
d) Apply footbrake (do not release)
e) Put your gear to N for 2 mins
f) After 2 mins, put your gear to D for 1 min
RE-CALIBRATE CVT GEARBOX (IF CHANGE BATTERY) - autoworld forum
a) Starts the car and let it runs until the engine cold indicator is off.
b) Switch off the engine and restart again.
c) Switch on the front lights.
d) Shift the gear to 'n'. while stepping on the brake
e) Shift the gear between 'n', 'd', 's', 'l', 's', 'd' and back to 'n'.
f) Repeated this process about 3 times about 1-2 seconds between the
gears.
