while hot , stop the engine
and pull the temp sensor plug
start the engine again
is the pointer go to zero or sticks
if sticks then gauge is faulty and you can replace the sensor as well
are fans running normally ??
what about insulation around accelerator pedal ??
lanos they have plastic guard plates under the engine
are they fitted ??
