[COLOR="rgb(139, 0, 0)"]نظرة اسبوعية علي الاسواق من FXstreet
EURUSD : No change , with the key support 1.3104/1.3325 intact on a weekly basis, further upside couldn't be ruled out , on daily support is at 1.3461 levels, so more upside is suggested , resistance is at 1.3645 levels , a break would target the 1.3710 levels. further upside will aim the 1.3785 levels, above the 1.3785 will look for the 1.3870 levels ahead of the 1.4025 levels.
On the downside, losing 1.3461 on a daily basis will confirm short term topping and is likely to pave the way towards the 1.3104/1.3325 levels.overall the pair is neutral this week with bullish bias !
GBPUSD : The GBPUSD has lost some of its upside momentum last week, resistance is at the 1.6121 levels ahead of the 1.6177 levels, with both levels intact on a daily basis, further downside couldn't be ruled out towards the 1.5840 levels , next support comes at the 1.5750/11.5716 levels.
On the upside, sustained break above the 1.6177 levels would target the 1.6260 levels where a breach is likely , If seen, next resistance is at the 1.6400 levels, further upside will aim the 1.6615 levels.overall the pair is under pressure below 16121/1.6177 level.
[/COLOR]
