i can't get youe question? do you need the exact tightening torque or what?
normally the exach tgihtening fotr these nuts is 3-5 turns beyound hand tight ,
but give us more details about your request so we can help you
رقم العضوية : 3265
السيارة[2]: لانسر
رقم العضوية : 72
الاقامة : البحرين
السيارة: سوزوكي ماروتي، مصر
سبعاوى
رقم العضوية : 3265
السيارة[2]: لانسر
thanx eng.sab3aawy for your reply
you have aswered my question
but the mechanic over tighten them because bushings tend to move on bumby roads ,he said.normally the exact tgihtening fot these nuts is 3-5 turns beyound hand tight
logically,if i tighten the nuts by hand then 3-5 turns by Wrench that will make a gap between bushings and the end link of the sway bar?
[shr71=http://pic.phyrefile.com/2007/10/20/jtte2o.gif]TG[/shr71]
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
i ususally tighten them bolts till i see the bushing is on the verge of getting deformed if it continue to tighten the bolt
bear in mind that those bushings are so big as their is too much play occurs between the sway bar and the rod connecting the bar to the control arm so over tightening them is not a good idea and might stress the rod
i can see that you got red bushings... are those polyurethane bushings??? what car is that (make and model)
رقم العضوية : 3265
السيارة[2]: لانسر
hi MMadouh
This is not my car, i found this picture on the internet
mine are stock
thnx for your advice
رقم العضوية : 900
السيارة: 2car
السيارة[2]: 1car
you should tighten it hard to make the bar stiffer and less rolling
رقم العضوية : 920
السيارة: 504
السيارة[2]: civic
Because for every small movement in the sway bar, the car body rolls a lot.
رقم العضوية : 4616
السيارة: None
السيارة[2]: Renault fluence
دراجة بخارية: None
شىء عظيم جدا
ممكن شرح الإختراع ده بيعمل ايه؟
اهو نستفيد و نتعلم بالمرة
رقم العضوية : 102
دراجة بخارية: N/A
رقم العضوية : 4616
السيارة: None
دراجة بخارية: None
قصدى الموضوع كله يا باشا
