المشاركة الأصلية كتبت بواسطة K.Ossama
What we check and why DSG transmission oil and filter change?
Why does my DSG transmission oil and filter need to be changed?
This sophisticated piece of engineering needs regular oil changes. The smooth two-clutch system is computer-controlled with very fine engineering tolerances. If the gearbox oil is dirty it will damage the other parts and affect the performance.
What happens if it's not changed?
Dirty oil can overheat the gearbox or cause the clutches to burn out. This will lead to poor gear selection, loss of power and transmission failure.
What do we do?
We check the gearbox for leaks, drain it and replace the oil filter* before filling it with high quality gearbox oil to Volkswagen approved standards.
*Only on applicable vehicles
How often does it need to be changed?
The oil, every 40,000 miles, the filter may need to be changed as well.
Benefits of having my DSG oil and filter changed:
1...Saves on costly gearbox repairs
2...Improves your car's performance
3...Keeps your warranty valid for any repairs to parts related to the gearbox
4...Special offer price with our Fixed Price Servicing for Volkswagens 3-10 years old, up to and including 2.0-litre engines.
DSG transmission oil and filter change : Volkswagen UK
