رقم العضوية : 150631
الاقامة : مصر
السيارة: مفبش
السيارة[2]: ماذدا
Corsa C 2000 - 2006 Fuse Listing
Fuse 1 - 7.5 Amp - Central Control Unit
Fuse 2 - 7.5 Amp - Engine Control Unit
Fuse 3 - 7.5 Amp - Instruments, Information Display, Horn, Hazards, Immobilizer
Fuse 4 - 5 Amp - Numberplate Lamp
Fuse 5 - 20 Amp - Electric Window (left)
Fuse 6 - 10 Amp - Automatic Transmission
Fuse 7 - 30 Amp - Headlamp Wash System
Fuse 8 - 10 Amp - Starter
Fuse 9 - 20 Amp - Fuel Injection Systems, Fuel Pump, Stationary Heater
Fuse 10 - 10 Amp - Horn
Fuse 11 - 15 Amp - Central Control Unit
Fuse 12 - 20 Amp - Information Display, Infotainment System, Radio
Fuse 13 - 10 Amp - Vauxhall Alarm System
Fuse 14 - 7.5 Amp - Exterior Mirrors
Fuse 15 - 15 Amp - Windscreen Wash System
Fuse 16 - 5 Amp - Courtesy Lamp
Fuse 17 - 20 Amp - Central Control Unit
Fuse 18 - 20 Amp - Sun Roof
Fuse 19 - 5 Amp - Vauxhall Alarm System
Fuse 20 - 20 Amp - Electric Window (Right)
Fuse 21 - Unknown - Please contact me if you have any information on this fuse
Fuse 22 - 5 Amp - Central Control Unit, Immobilizer
Fuse 23 - 20 Amp - Windscreen Wiper
Fuse 24 - 5 Amp - Infotainment System, Information Display, Courtesy Lamp, Instruments, EPS
Fuse 25 - 10 Amp - Brake Lamp
Fuse 26 - 20 Amp - Automatic Transmission, Fuel Injection Systems, Reverse Lamps, Cigarette Lighter
Fuse 27 - 15 Amp - Seat Heater (right)
Fuse 28 - 15 Amp - Seat Heater (left)
Fuse 29 - 20 Amp - Rear Window Wiper
Fuse 30 - 15 Amp - Engine Control Unit
Fuse 31 - 15 Amp - Air Conditioning System
Fuse 32 - 5 Amp - ABS, Easytronic, Automatic Transmission, Airbag
Fuse 33 [Petrol engine] - 15 Amp - Engine Control Unit
Fuse 33 [Diesel engine] - 7.5 Amp - Engine Control Unit
Fuse 34 - 30 Amp - Diesel Filter Heater
Fuse 35 - 5 Amp - Sunroof, Electric Windows, Radio
Fuse 36 - 10 Amp - Dipped Beam (left)
Fuse 37 - 10 Amp - Dipped Beam (right)
Fuse 38 - 5 Amp - Tail Lamp (left), Parking Lamp (left)
Fuse 39 - 5 Amp - Tail Lamp (right), Parking Lamp (right)
Fuse 40 - Unknown - Please contact me if you have any information on this fuse
Fuse 41 - 15 Amp - Fog Lamps
Fuse 42 - 10 Amp - Fog Tail Lamps
Fuse 43 - 10 Amp - Main Beam (left)
Fuse 44 - 10 Amp - Main Beam (right)
Fuse 45 - 30 Amp - Interior Fan
Fuse 46 - 20 Amp - Engine Control Unit
Fuse 47 - 30 Amp - Heated Rear Window
Fuse 48 - 30 Amp - Starter
Fuse 49 - 50 Amp - EPS
Fuse 50 - 40 Amp - ABS
Fuse 51 [Petrol engine] - 60 Amp - Easytronic
Fuse 51 [Diesel engine] - 80 Amp - Engine Control Unit
Fuse 52 [Petrol engine with Air Conditioning] - 30 Amp - Cooling Fan
Fuse 52 [Petrol engine Z10XE, Z12XE without Air Conditioning] - 20 Amp - Cooling Fan
Fuse 52 [Petrol engine Z14XE, Z18XE without Air Conditioning] - 40 Amp - Cooling Fan
Fuse 52 [Diesel engine] - 40 Amp - Cooling Fan
Fuse 53 [Petrol engine] - 30 Amp - Air Conditioning Cooling Fan
Fuse 53 [Diesel engine] - 40 Amp - Air Conditioning Cooling Fan
