رقم العضوية : 131307
السيارة: .
السيارة[2]: E46
الجزء الثالث :
11530114 Thermostat Occasional malfunction
11530115 Thermostat Permanent malfunction
11530179 Thermostat incorrect connection /contact
115301XX Thermostat
11531212 Characteristic map thermostat, heating Permanent failure
11531296 Characteristic map thermostat, heating Fault code in diagnosis memory (warn. lamp on)
11531299 Characteristic map thermostat, heating Fault code stored in diagnosis fault code memory (no warning
115312XX Characteristic map thermostat, heating
11531348 Coolant return pipe Leaking
11531375 Coolant return pipe corroded
115313XX Coolant return pipe
1153XXXX Thermostat and engine-mounted coolant lines
11610379 Electric motor, individual control intake system (DISA) incorrect connection /contact
11610396 Electric motor, individual control intake system (DISA) Fault code in diagnosis memory (warn. lamp o
11610399 Electric motor, individual control intake system (DISA) Fault code stored in diagnosis fault code me
116103XX Electric motor, individual control intake system (DISA)
11610429 Differentiated fully variable intake system DIVA Sticking/jammed
11610439 Differentiated fully variable intake system DIVA Unpleasant noises
11610448 Differentiated fully variable intake system DIVA Leaking
116104XX Differentiated fully variable intake system DIVA
11610579 Actuator (incl. sensor) DIVA incorrect connection /contact
11610596 Actuator (incl. sensor) DIVA Fault code in diagnosis memory (warn. lamp on)
11610599 Actuator (incl. sensor) DIVA Fault code stored in diagnosis fault code memory (no warning lamp)
116105XX Actuator (incl. sensor) DIVA
11611237 Intake manifold Loose
11611239 Intake manifold Unpleasant noises
11611248 Intake manifold Leaking
116112XX Intake manifold
11611948 Decoupling flange between cylinder head and intake manifold Leaking
116119XX Decoupling flange between cylinder head and intake manifold
11612037 Vacuum hose, DISA flap valve Loose
11612048 Vacuum hose, DISA flap valve Leaking
116120XX Vacuum hose, DISA flap valve
11612111 Solenoid valve for intake manifold (DISA) Occasional failure
11612112 Solenoid valve for intake manifold (DISA) Permanent failure
116121XX Solenoid valve for intake manifold (DISA)
11612239 DISA flap/sliding sleeves Unpleasant noises
11612248 DISA flap/sliding sleeves Leaking
11612283 DISA flap/sliding sleeves incorrect or no switching action
11612296 DISA flap/sliding sleeves Fault code in diagnosis memory (warn. lamp on)
11612299 DISA flap/sliding sleeves Fault code stored in diagnosis fault code memory (no warning lamp)
116122XX DISA flap/sliding sleeves
11612315 Air shut-off valve, suction jet pump Permanent malfunction
116123XX Air shut-off valve, suction jet pump
11612483 Swirl flap incorrect or no switching action
116124XX Swirl flap
11612583 Swirl flap changeover valve incorrect or no switching action
11612584 Swirl flap changeover valve incorrect electrical resistance
116125XX Swirl flap changeover valve
11612615 Suction jet pump for brake booster Permanent malfunction
11612648 Suction jet pump for brake booster Leaking
116126XX Suction jet pump for brake booster
1161XXXX Intake manifold
11620001 Exhaust manifold Cracked / broken / torn off
11620032 Exhaust manifold Deformed / distorted / bent
11620039 Exhaust manifold Unpleasant noises
11620048 Exhaust manifold Leaking
116200XX Exhaust manifold
11620101 Heat shield for exhaust manifold Cracked / broken / torn off
11620137 Heat shield for exhaust manifold Loose
11620139 Heat shield for exhaust manifold Unpleasant noises
116201XX Heat shield for exhaust manifold
11620301 Stud bolts for exhaust manifold Cracked / broken / torn off
11620337 Stud bolts for exhaust manifold Loose
116203XX Stud bolts for exhaust manifold
11620448 Exhaust manifold gasket, cylinder head end Leaking
116204XX Exhaust manifold gasket, cylinder head end
11629039 E36/7 E39 E46 M54 RHD gasket with heat shield for exhaust manifold whirring noise
1162XXXX Exhaust manifold
11642637 Interference air valve - exhaust inspection Loose
11642648 Interference air valve - exhaust inspection Leaking
116426XX Interference air valve - exhaust inspection
1164XXXX Exhaust control unit
11650528 Exhaust turbocharger (ATL) Seized
11650531 Exhaust turbocharger (ATL) Excessive play
11650539 Exhaust turbocharger (ATL) Unpleasant noises
11650583 Exhaust turbocharger (ATL) incorrect or no switching action
116505XX Exhaust turbocharger (ATL)
11651848 Oil pipe, exhaust turbocharger (ATL) Leaking
116518XX Oil pipe, exhaust turbocharger (ATL)
11651914 Charge pressure regulation Occasional malfunction
11651915 Charge pressure regulation Permanent malfunction
116519XX Charge pressure regulation
11652048 Vacuum accumulator for exhaust turbocharger Leaking
116520XX Vacuum accumulator for exhaust turbocharger
11652111 Solenoid valve for exhaust turbocharger Occasional failure
11652112 Solenoid valve for exhaust turbocharger Permanent failure
11652183 Solenoid valve for exhaust turbocharger incorrect or no switching action
116521XX Solenoid valve for exhaust turbocharger
11652276 Filter EPDW exhaust turbocharger dirty / blocked
116522XX Filter EPDW exhaust turbocharger
11652329 EPDW boost pressure regulator Sticking/jammed
11652384 EPDW boost pressure regulator incorrect electrical resistance
116523XX EPDW boost pressure regulator
11652428 Compressor (mechanical supercharger) Seized
11652439 Compressor (mechanical supercharger) Unpleasant noises
11652448 Compressor (mechanical supercharger) Leaking
116524XX Compressor (mechanical supercharger)
11659015 E46 M47/TU Exhaust turbocharger failed
1165XXXX Turbocharger with control
11660011 Vacuum pump (diesel) Occasional failure
11660012 Vacuum pump (diesel) Permanent failure
11660039 Vacuum pump (diesel) Unpleasant noises
11660048 Vacuum pump (diesel) Leaking
116600XX Vacuum pump (diesel)
11660248 Vacuum lines Leaking
11660276 Vacuum lines dirty / blocked
11660279 Vacuum lines incorrect connection /contact
116602XX Vacuum lines
1166XXXX Vacuum pump
11710148 Exhaust gas recirculation valve (EGR) Leaking
11710176 Exhaust gas recirculation valve (EGR) dirty / blocked
11710183 Exhaust gas recirculation valve (EGR) incorrect or no switching action
117101XX Exhaust gas recirculation valve (EGR)
11710348 EGR valve, valve seat Leaking
117103XX EGR valve, valve seat
11710576 Filter electropneumatic pressure converter EPDW EGR dirty / blocked
117105XX Filter electropneumatic pressure converter EPDW EGR
11710601 EGR cooling Cracked / broken / torn off
11710637 EGR cooling Loose
11710648 EGR cooling Leaking
11710676 EGR cooling dirty / blocked
117106XX EGR cooling
11710729 Electropneumatic pressure converter EPDW for EGR Sticking/jammed
11710784 Electropneumatic pressure converter EPDW for EGR incorrect electrical resistance
117107XX Electropneumatic pressure converter EPDW for EGR
11710801 EGR pipe Cracked / broken / torn off
11710848 EGR pipe Leaking
117108XX EGR pipe
1171XXXX Exhaust gas recirculation (EGR)
11720211 Air pump Occasional failure
11720212 Air pump Permanent failure
11720239 Air pump Unpleasant noises
11720296 Air pump Fault code in diagnosis memory (warn. lamp on)
11720299 Air pump Fault code stored in diagnosis fault code memory (no warning lamp)
117202XX Air pump
11720376 Air filter, secondary air pump dirty / blocked
117203XX Air filter, secondary air pump
11720401 Secondary air line (manifold up to valve) Cracked / broken / torn off
11720448 Secondary air line (manifold up to valve) Leaking
117204XX Secondary air line (manifold up to valve)
11720514 Electric changeover valve, secondary air system Occasional malfunction
11720515 Electric changeover valve, secondary air system Permanent malfunction
11720537 Electric changeover valve, secondary air system Loose
11720548 Electric changeover valve, secondary air system Leaking
11720596 Electric changeover valve, secondary air system Fault code in diagnosis memory (warn. lamp on)
11720599 Electric changeover valve, secondary air system Fault code stored in diagnosis fault code memory (no
117205XX Electric changeover valve, secondary air system
11720615 Shut-off valve (return flow shut-off valve) Permanent malfunction
11720648 Shut-off valve (return flow shut-off valve) Leaking
117206XX Shut-off valve (return flow shut-off valve)
11720737 Intake line (between filter and pump) Loose
11720748 Intake line (between filter and pump) Leaking
117207XX Intake line (between filter and pump)
11720837 Delivery line (between pump and shut-off valve) Loose
11720848 Delivery line (between pump and shut-off valve) Leaking
117208XX Delivery line (between pump and shut-off valve)
11720937 Vacuum line between electric changeover valve and shut-off valve (petrol engine) Loose
11720948 Vacuum line between electric changeover valve and shut-off valve (petrol engine) Leaking
117209XX Vacuum line between electric changeover valve and shut-off valve (petrol engine)
11721048 Vacuum accumulator Leaking
117210XX Vacuum accumulator
1172XXXX Air pump, lines and control valves
11780214 Oxygen control sensor (before catalytic converter) Occasional malfunction
11780215 Oxygen control sensor (before catalytic converter) Permanent malfunction
11780279 Oxygen control sensor (before catalytic converter) incorrect connection /contact
11780296 Oxygen control sensor (before catalytic converter) Fault code in diagnosis memory (warn. lamp on)
11780299 Oxygen control sensor (before catalytic converter) Fault code stored in diagnosis fault code memory
117802XX Oxygen control sensor (before catalytic converter)
11780314 Oxygen monitor sensor Occasional malfunction
11780315 Oxygen monitor sensor Permanent malfunction
11780379 Oxygen monitor sensor incorrect connection /contact
11780396 Oxygen monitor sensor Fault code in diagnosis memory (warn. lamp on)
11780399 Oxygen monitor sensor Fault code stored in diagnosis fault code memory (no warning lamp)
117803XX Oxygen monitor sensor
11780411 Exhaust temperature sensor Occasional failure
11780412 Exhaust temperature sensor Permanent failure
11780413 Exhaust temperature sensor Broken
11780437 Exhaust temperature sensor Loose
11780496 Exhaust temperature sensor Fault code in diagnosis memory (warn. lamp on)
11780499 Exhaust temperature sensor Fault code stored in diagnosis fault code memory (no warning lamp)
117804XX Exhaust temperature sensor
11789346 E39 E52 S62 Exhaust gas temperature sensor - dispensed with
1178XXXX Exhaust control units
11XXXXXX Engine
12110029 Distributor Sticking/jammed
12110040 Distributor Poorly adjusted / outside tolerance
121100XX Distributor
12110201 Distributor cap / connections Cracked / broken / torn off
12110251 Distributor cap / connections Burnt/burnt through
121102XX Distributor cap / connections
12110613 Distributor rotor Broken
12110651 Distributor rotor Burnt/burnt through
121106XX Distributor rotor
1211XXXX Ignition, ignition distributor, circuit breaker
12120014 Spark plugs Occasional malfunction
12120015 Spark plugs Permanent malfunction
121200XX Spark plugs
12120182 Ignition leads arcing over
121201XX Ignition leads
12120237 Spark plug caps Loose
12120282 Spark plug caps arcing over
121202XX Spark plug caps
12120337 Angled plug (distributor cap + coil) Loose
12120382 Angled plug (distributor cap + coil) arcing over
121203XX Angled plug (distributor cap + coil)
1212XXXX Ignition harness, spark plugs
12130011 Ignition coil Occasional failure
12130012 Ignition coil Permanent failure
12130037 Ignition coil Loose
12130099 Ignition coil Fault code stored in diagnosis fault code memory (no warning lamp)
121300XX Ignition coil
12139112 E36/7 E46 Ignition coils fail (Bremi)
12139184 E65 E66 N62 Ignition coils (Bremi) fail
1213XXXX Ignition coil
12140814 Knock sensor Occasional malfunction
12140815 Knock sensor Permanent malfunction
12140837 Knock sensor Loose
12140896 Knock sensor Fault code in diagnosis memory (warn. lamp on)
12140899 Knock sensor Fault code stored in diagnosis fault code memory (no warning lamp)
121408XX Knock sensor
12140914 Differential pressure sensors (Cooper S) Occasional malfunction
12140915 Differential pressure sensors (Cooper S) Permanent malfunction
121409XX Differential pressure sensors (Cooper S)
12141014 Pulse generator, crankshaft Occasional malfunction
12141015 Pulse generator, crankshaft Permanent malfunction
12141037 Pulse generator, crankshaft Loose
12141096 Pulse generator, crankshaft Fault code in diagnosis memory (warn. lamp on)
12141099 Pulse generator, crankshaft Fault code stored in diagnosis fault code memory (no warning lamp)
121410XX Pulse generator, crankshaft
12141114 Pulse generator, camshaft Occasional malfunction
12141115 Pulse generator, camshaft Permanent malfunction
12141137 Pulse generator, camshaft Loose
12141196 Pulse generator, camshaft Fault code in diagnosis memory (warn. lamp on)
12141199 Pulse generator, camshaft Fault code stored in diagnosis fault code memory (no warning lamp)
121411XX Pulse generator, camshaft
12141511 Component, DME control unit Occasional failure
12141512 Component, DME control unit Permanent failure
12141523 Component, DME control unit Incorrect / not fitted
12141537 Component, DME control unit Loose
12141550 Component, DME control unit Water ingress / condensate
121415XX Component, DME control unit
12141715 Control unit for electrically heated catalytic converter Permanent malfunction
121417XX Control unit for electrically heated catalytic converter
12149009 E38 E39 M62 Air conditioning switches off during acceleration - DME reprogramming
12149047 R50 Dip in engine speed during gearshift (program DME)
12149105 E38 E39 E53 M62TU Engine will not start - FC 164
12149125 E36/7 E46 S54 Rough engine operation after cold start (program DME)
12149225 R50 Delayed throttle response (program DME)
12149487 E36 E38 E39 E46 E53 M52/TU M62/TU "Check engine" lamp comes on
12149696 E46 N42 DME data Valvetronic monitoring faulty
12149796 E36 E39 E46 E53 M54 Crankshaft position/rpm sensor
12149809 R53 Rough engine operation after cold start
1214XXXX Electronic shift or control units
12210011 Preheating relay/preheating control unit Occasional failure
12210012 Preheating relay/preheating control unit Permanent failure
122100XX Preheating relay/preheating control unit
1221XXXX Preheating relays
12230011 Sheathed-element preheater plugs Occasional failure
12230012 Sheathed-element preheater plugs Permanent failure
122300XX Sheathed-element preheater plugs
1223XXXX Sheathed-element preheater plugs
12310011 Alternator Occasional failure
12310012 Alternator Permanent failure
12310037 Alternator Loose
12310039 Alternator Unpleasant noises
12310048 Alternator Leaking
123100XX Alternator
12310601 Forced cooling for alternator Cracked / broken / torn off
12310632 Forced cooling for alternator Deformed / distorted / bent
12310637 Forced cooling for alternator Loose
123106XX Forced cooling for alternator
12310814 Vol***e regulator Occasional malfunction
12310815 Vol***e regulator Permanent malfunction
12310837 Vol***e regulator Loose
123108XX Vol***e regulator
1231XXXX Alternator with drive and mount
12410011 Starter motor Occasional failure
12410012 Starter motor Permanent failure
12410037 Starter motor Loose
12410039 Starter motor Unpleasant noises
124100XX Starter motor
12410401 Heat shield, starter Cracked / broken / torn off
12410439 Heat shield, starter Unpleasant noises
124104XX Heat shield, starter
1241XXXX Starter with mounting
12420713 Starter, alternator connections Broken
12420737 Starter, alternator connections Loose
12420775 Starter, alternator connections corroded
12420780 Starter, alternator connections short circuit
124207XX Starter, alternator connections
12420813 Ground cable, engine - body Broken
12420837 Ground cable, engine - body Loose
12420875 Ground cable, engine - body corroded
124208XX Ground cable, engine - body
12421013 Battery lead B+ (engine compartment) Broken
12421037 Battery lead B+ (engine compartment) Loose
12421075 Battery lead B+ (engine compartment) corroded
12421080 Battery lead B+ (engine compartment) short circuit
124210XX Battery lead B+ (engine compartment)
12421113 Battery lead B- (engine compartment) Broken
12421137 Battery lead B- (engine compartment) Loose
12421175 Battery lead B- (engine compartment) corroded
124211XX Battery lead B- (engine compartment)
12421213 Other starter lead Broken
12421237 Other starter lead Loose
12421275 Other starter lead corroded
12421280 Other starter lead short circuit
124212XX Other starter lead
1242XXXX Starter cable
12510337 DME/DDE control unit connector Loose
12510348 DME/DDE control unit connector Leaking
12510375 DME/DDE control unit connector corroded
12510379 DME/DDE control unit connector incorrect connection /contact
12510381 DME/DDE control unit connector interruption
125103XX DME/DDE control unit connector
12510413 Injection valve connector Broken
12510437 Injection valve connector Loose
12510475 Injection valve connector corroded
12510479 Injection valve connector incorrect connection /contact
12510481 Injection valve connector interruption
125104XX Injection valve connector
12510513 Sensor and component connector Broken
12510537 Sensor and component connector Loose
12510575 Sensor and component connector corroded
12510579 Sensor and component connector incorrect connection /contact
12510581 Sensor and component connector interruption
125105XX Sensor and component connector
12510613 Plug connections Broken
12510637 Plug connections Loose
12510675 Plug connections corroded
12510679 Plug connections incorrect connection /contact
12510681 Plug connections interruption
125106XX Plug connections
12510713 Wiring, heated catalytic converter Broken
12510737 Wiring, heated catalytic converter Loose
12510775 Wiring, heated catalytic converter corroded
12510780 Wiring, heated catalytic converter short circuit
12510781 Wiring, heated catalytic converter interruption
125107XX Wiring, heated catalytic converter
12511201 Lines, engine wiring harness Cracked / broken / torn off
12511269 Lines, engine wiring harness Worn / sheared through
12511281 Lines, engine wiring harness interruption
125112XX Lines, engine wiring harness
12511313 Terminal lugs/threaded connection Broken
12511337 Terminal lugs/threaded connection Loose
12511375 Terminal lugs/threaded connection corroded
12511380 Terminal lugs/threaded connection short circuit
125113XX Terminal lugs/threaded connection
1251XXXX Engine wiring harness
12530113 Wiring harness, transmission Broken
12530175 Wiring harness, transmission corroded
12530181 Wiring harness, transmission interruption
125301XX Wiring harness, transmission
1253XXXX Wiring harness, transmission
12610014 Engine oil level sensor (TÖNS) Occasional malfunction
12610015 Engine oil level sensor (TÖNS) Permanent malfunction
12610048 Engine oil level sensor (TÖNS) Leaking
126100XX Engine oil level sensor (TÖNS)
12610114 Oil pressure switch Occasional malfunction
12610115 Oil pressure switch Permanent malfunction
12610148 Oil pressure switch Leaking
126101XX Oil pressure switch
12610214 Engine oil temperature sensor Occasional malfunction
12610215 Engine oil temperature sensor Permanent malfunction
12610248 Engine oil temperature sensor Leaking
12610296 Engine oil temperature sensor Fault code in diagnosis memory (warn. lamp on)
12610299 Engine oil temperature sensor Fault code stored in diagnosis fault code memory (no warning lamp)
126102XX Engine oil temperature sensor
12610314 Oil status sensor Occasional malfunction
12610315 Oil status sensor Permanent malfunction
12610348 Oil status sensor Leaking
126103XX Oil status sensor
12610414 Evaluator TÖNS Occasional malfunction
12610415 Evaluator TÖNS Permanent malfunction
126104XX Evaluator TÖNS
12619314 E65 E66 N62 Oil level sensor malfunction
1261XXXX Oil pressure, oil temperature, oil level indicator
12630514 Temperature switch for coolant Occasional malfunction
12630515 Temperature switch for coolant Permanent malfunction
12630548 Temperature switch for coolant Leaking
126305XX Temperature switch for coolant
12630811 Master relay for DME/DDE Occasional failure
12630812 Master relay for DME/DDE Permanent failure
126308XX Master relay for DME/DDE
12630911 Ignition coil relay Occasional failure
12630912 Ignition coil relay Permanent failure
126309XX Ignition coil relay
12631011 Secondary air pump relay Occasional failure
12631012 Secondary air pump relay Permanent failure
12631079 Secondary air pump relay incorrect connection /contact
12631096 Secondary air pump relay Fault code in diagnosis memory (warn. lamp on)
12631099 Secondary air pump relay Fault code stored in diagnosis fault code memory (no warning lamp)
126310XX Secondary air pump relay
12631179 Valvetronic relay module/IVM (integrated supply module) incorrect connection /contact
12631196 Valvetronic relay module/IVM (integrated supply module) Fault code in diagnosis memory (warn. lamp o
12631199 Valvetronic relay module/IVM (integrated supply module) Fault code stored in diagnosis fault code me
126311XX Valvetronic relay module/IVM (integrated supply module)
12631214 Compressor relay for mechanical charger Occasional malfunction
12631215 Compressor relay for mechanical charger Permanent malfunction
12631237 Compressor relay for mechanical charger Loose
126312XX Compressor relay for mechanical charger
1263XXXX Switches and relays
12640014 Fuel heating Occasional malfunction
12640015 Fuel heating Permanent malfunction
126400XX Fuel heating
1264XXXX Fuel heating
12710014 Control unit for electronic engine output control (EML) Occasional malfunction
12710015 Control unit for electronic engine output control (EML) Permanent malfunction
12710037 Control unit for electronic engine output control (EML) Loose
12710087 Control unit for electronic engine output control (EML) warning lamp lights up
127100XX Control unit for electronic engine output control (EML)
12710114 Engine emergency program, accelerator sensor Occasional malfunction
12710115 Engine emergency program, accelerator sensor Permanent malfunction
12710181 Engine emergency program, accelerator sensor interruption
127101XX Engine emergency program, accelerator sensor
12710214 Engine emergency program, throttle body Occasional malfunction
12710215 Engine emergency program, throttle body Permanent malfunction
12710234 Engine emergency program, throttle body Stiff to move
12710281 Engine emergency program, throttle body interruption
12710299 Engine emergency program, throttle body Fault code stored in diagnosis fault code memory (no warning
127102XX Engine emergency program, throttle body
1271XXXX Electronic control unit
12720014 Pedal position sensor Occasional malfunction
12720015 Pedal position sensor Permanent malfunction
12720034 Pedal position sensor Stiff to move
12720037 Pedal position sensor Loose
12720039 Pedal position sensor Unpleasant noises
12720096 Pedal position sensor Fault code in diagnosis memory (warn. lamp on)
12720099 Pedal position sensor Fault code stored in diagnosis fault code memory (no warning lamp)
127200XX Pedal position sensor
1272XXXX Sensor for control unit
12900212 Cooling fan for electrical equipment box (E-box) Permanent failure
12900239 Cooling fan for electrical equipment box (E-box) Unpleasant noises
129002XX Cooling fan for electrical equipment box (E-box)
12900312 Temperature switch for electrical equipment box (E-box) Permanent failure
12900323 Temperature switch for electrical equipment box (E-box) Incorrect / not fitted
129003XX Temperature switch for electrical equipment box (E-box)
1290XXXX Electrical equipment box
12XXXXXX Engine electrics
13310439 Solenoid valve (fuel delivery) Unpleasant noises
13310448 Solenoid valve (fuel delivery) Leaking
13310483 Solenoid valve (fuel delivery) incorrect or no switching action
13310499 Solenoid valve (fuel delivery) Fault code stored in diagnosis fault code memory (no warning lamp)
133104XX Solenoid valve (fuel delivery)
1331XXXX Fuel pump with drive and pressure line
13320048 Fuel filter Leaking
133200XX Fuel filter
13321348 Filter drain plug with water level sensor (DDE) Leaking
133213XX Filter drain plug with water level sensor (DDE)
13321437 Fuel cooler (diesel) Loose
13321448 Fuel cooler (diesel) Leaking
13321476 Fuel cooler (diesel) dirty / blocked
133214XX Fuel cooler (diesel)
13321514 Valve, fuel preheating (diesel) Occasional malfunction
13321515 Valve, fuel preheating (diesel) Permanent malfunction
13321548 Valve, fuel preheating (diesel) Leaking
133215XX Valve, fuel preheating (diesel)
1332XXXX Fuel filter
13410115 Idle regulating valve Permanent malfunction
13410124 Idle regulating valve Surge
13410129 Idle regulating valve Sticking/jammed
13410139 Idle regulating valve Unpleasant noises
13410196 Idle regulating valve Fault code in diagnosis memory (warn. lamp on)
13410199 Idle regulating valve Fault code stored in diagnosis fault code memory (no warning lamp)
134101XX Idle regulating valve
13410348 Idle speed, air duct Leaking
134103XX Idle speed, air duct
1341XXXX Speed governor
13515015 Distributor-type injection pump diesel (not CR) Permanent malfunction
13515056 Distributor-type injection pump diesel (not CR) Poor running characteristics / friction
13515099 Distributor-type injection pump diesel (not CR) Fault code stored in diagnosis fault code memory (no
135150XX Distributor-type injection pump diesel (not CR)
13515411 Cutout solenoid Occasional failure
13515412 Cutout solenoid Permanent failure
135154XX Cutout solenoid
13515848 Distributor-type injection pump, shaft seal Leaking
135158XX Distributor-type injection pump, shaft seal
13515948 Distributor-type injection pump, housing Leaking
135159XX Distributor-type injection pump, housing
13516048 Distributor-type injection pump, inlet/outlet Leaking
135160XX Distributor-type injection pump, inlet/outlet
13516512 High pressure pump HDP Permanent failure
13516515 High pressure pump HDP Permanent malfunction
13516548 High pressure pump HDP Leaking
13516596 High pressure pump HDP Fault code in diagnosis memory (warn. lamp on)
13516599 High pressure pump HDP Fault code stored in diagnosis fault code memory (no warning lamp)
135165XX High pressure pump HDP
1351XXXX Injection pump, regulator section, mixture regulator
13530137 Injector line, DDE connection, nozzle Loose
13530148 Injector line, DDE connection, nozzle Leaking
135301XX Injector line, DDE connection, nozzle
13530737 Injector line, DDE connection, pump Loose
13530748 Injector line, DDE connection, pump Leaking
135307XX Injector line, DDE connection, pump
13530848 Leakage oil line, diesel Leaking
13530876 Leakage oil line, diesel dirty / blocked
135308XX Leakage oil line, diesel
13531048 Diesel fuel injector (not CR) Leaking
13531084 Diesel fuel injector (not CR) incorrect electrical resistance
135310XX Diesel fuel injector (not CR)
13531139 Pressure regulator, petrol Unpleasant noises
13531148 Pressure regulator, petrol Leaking
135311XX Pressure regulator, petrol
13531248 Circuit line/injection tube, petrol Leaking
135312XX Circuit line/injection tube, petrol
13531501 Cover sections for engine Cracked / broken / torn off
13531532 Cover sections for engine Deformed / distorted / bent
13531539 Cover sections for engine Unpleasant noises
135315XX Cover sections for engine
13531737 Fuel pressure regulator, vacuum hose Loose
135317XX Fuel pressure regulator, vacuum hose
13532048 High pressure accumulator (rail) Leaking
135320XX High pressure accumulator (rail)
13532101 High pressure lines Cracked / broken / torn off
13532148 High pressure lines Leaking
135321XX High pressure lines
13532215 Injector, common rail Permanent malfunction
13532239 Injector, common rail Unpleasant noises
13532248 Injector, common rail Leaking
13532284 Injector, common rail incorrect electrical resistance
13532296 Injector, common rail Fault code in diagnosis memory (warn. lamp on)
13532299 Injector, common rail Fault code stored in diagnosis fault code memory (no warning lamp)
135322XX Injector, common rail
13532337 Flange for injector (CR) Loose
135323XX Flange for injector (CR)
13532415 Rail pressure sensor Permanent malfunction
13532448 Rail pressure sensor Leaking
13532496 Rail pressure sensor Fault code in diagnosis memory (warn. lamp on)
13532499 Rail pressure sensor Fault code stored in diagnosis fault code memory (no warning lamp)
135324XX Rail pressure sensor
13532529 Pressure control valve Sticking/jammed
13532548 Pressure control valve Leaking
13532584 Pressure control valve incorrect electrical resistance
135325XX Pressure control valve
13532648 Distributor block, common rail (CR) Leaking
135326XX Distributor block, common rail (CR)
13532711 Valve, air-contained fuel injectors Occasional failure
13532712 Valve, air-contained fuel injectors Permanent failure
135327XX Valve, air-contained fuel injectors
1353XXXX Injectors and lines
13540034 Throttle body with flap Stiff to move
13540037 Throttle body with flap Loose
13540040 Throttle body with flap Poorly adjusted / outside tolerance
13540048 Throttle body with flap Leaking
135400XX Throttle body with flap
13540212 Throttle valve potentiometer/switch Permanent failure
13540237 Throttle valve potentiometer/switch Loose
13540296 Throttle valve potentiometer/switch Fault code in diagnosis memory (warn. lamp on)
13540299 Throttle valve potentiometer/switch Fault code stored in diagnosis fault code memory (no warning lam
135402XX Throttle valve potentiometer/switch
13540613 Tension/torsion spring for throttle body Broken
135406XX Tension/torsion spring for throttle body
13540711 Motor-driven throttle valve Occasional failure
13540712 Motor-driven throttle valve Permanent failure
13540734 Motor-driven throttle valve Stiff to move
13540748 Motor-driven throttle valve Leaking
13540796 Motor-driven throttle valve Fault code in diagnosis memory (warn. lamp on)
13540799 Motor-driven throttle valve Fault code stored in diagnosis fault code memory (no warning lamp)
135407XX Motor-driven throttle valve
13540834 Throttle valve actuation on M models Stiff to move
13540837 Throttle valve actuation on M models Loose
13540840 Throttle valve actuation on M models Poorly adjusted / outside tolerance
13540848 Throttle valve actuation on M models Leaking
135408XX Throttle valve actuation on M models
13540911 ASC choke valve Occasional failure
13540912 ASC choke valve Permanent failure
13540934 ASC choke valve Stiff to move
13540948 ASC choke valve Leaking
135409XX ASC choke valve
13541012 EDR actuator (motor-driven throttle valve control) with operating system, M-models Permanent failure
13541034 EDR actuator (motor-driven throttle valve control) with operating system, M-models Stiff to move
13541040 EDR actuator (motor-driven throttle valve control) with operating system, M-models Poorly adjusted /
13541048 EDR actuator (motor-driven throttle valve control) with operating system, M-models Leaking
13541096 EDR actuator (motor-driven throttle valve control) with operating system, M-models Fault code in dia
13541099 EDR actuator (motor-driven throttle valve control) with operating system, M-models Fault code stored
135410XX EDR actuator (motor-driven throttle valve control) with operating system, M-models
1354XXXX Throttle valve and controls
13610311 Component, DDE control unit Occasional failure
13610312 Component, DDE control unit Permanent failure
13610323 Component, DDE control unit Incorrect / not fitted
13610337 Component, DDE control unit Loose
13610350 Component, DDE control unit Water ingress / condensate
136103XX Component, DDE control unit
13610511 Control unit for direct fuel injection (N73) Occasional failure
13610512 Control unit for direct fuel injection (N73) Permanent failure
136105XX Control unit for direct fuel injection (N73)
13619818 E65 M57 M67 Incorrect oil service indicator after DDE replacement
1361XXXX Electronic control unit
13620211 Coolant temperture sensor (on engine) Occasional failure
13620212 Coolant temperture sensor (on engine) Permanent failure
13620237 Coolant temperture sensor (on engine) Loose
13620248 Coolant temperture sensor (on engine) Leaking
13620296 Coolant temperture sensor (on engine) Fault code in diagnosis memory (warn. lamp on)
13620299 Coolant temperture sensor (on engine) Fault code stored in diagnosis fault code memory (no warning l
136202XX Coolant temperture sensor (on engine)
13620514 Intake air temperature sensor Occasional malfunction
13620515 Intake air temperature sensor Permanent malfunction
13620537 Intake air temperature sensor Loose
13620548 Intake air temperature sensor Leaking
13620596 Intake air temperature sensor Fault code in diagnosis memory (warn. lamp on)
13620599 Intake air temperature sensor Fault code stored in diagnosis fault code memory (no warning lamp)
136205XX Intake air temperature sensor
13620714 Mass air flow sensor Occasional malfunction
13620715 Mass air flow sensor Permanent malfunction
13620776 Mass air flow sensor dirty / blocked
13620796 Mass air flow sensor Fault code in diagnosis memory (warn. lamp on)
13620799 Mass air flow sensor Fault code stored in diagnosis fault code memory (no warning lamp)
136207XX Mass air flow sensor
13620814 Boost pressure sensor for DDE Occasional malfunction
13620815 Boost pressure sensor for DDE Permanent malfunction
13620837 Boost pressure sensor for DDE Loose
136208XX Boost pressure sensor for DDE
13621114 Battery temperature sensor Occasional malfunction
13621115 Battery temperature sensor Permanent malfunction
13621137 Battery temperature sensor Loose
136211XX Battery temperature sensor
13621211 Engine oil temperature sensor (VANOS) Occasional failure
13621212 Engine oil temperature sensor (VANOS) Permanent failure
13621237 Engine oil temperature sensor (VANOS) Loose
13621248 Engine oil temperature sensor (VANOS) Leaking
13621296 Engine oil temperature sensor (VANOS) Fault code in diagnosis memory (warn. lamp on)
13621299 Engine oil temperature sensor (VANOS) Fault code stored in diagnosis fault code memory (no warning l
136212XX Engine oil temperature sensor (VANOS)
13621311 Coolant temperature sensor (radiator outlet) Occasional failure
13621312 Coolant temperature sensor (radiator outlet) Permanent failure
13621337 Coolant temperature sensor (radiator outlet) Loose
13621348 Coolant temperature sensor (radiator outlet) Leaking
13621399 Coolant temperature sensor (radiator outlet) Fault code stored in diagnosis fault code memory (no wa
136213XX Coolant temperature sensor (radiator outlet)
13621515 Predelivery pressure sensor, common rail (CR) Permanent malfunction
13621548 Predelivery pressure sensor, common rail (CR) Leaking
136215XX Predelivery pressure sensor, common rail (CR)
13621648 Differential pressure sensor (intake pipe pressure sensor) Leaking
13621699 Differential pressure sensor (intake pipe pressure sensor) Fault code stored in diagnosis fault code
136216XX Differential pressure sensor (intake pipe pressure sensor)
1362XXXX Sensor for control unit
13630511 Fuel pump relay Occasional failure
13630512 Fuel pump relay Permanent failure
13630599 Fuel pump relay Fault code stored in diagnosis fault code memory (no warning lamp)
136305XX Fuel pump relay
1363XXXX Electromechanical shift units
13640114 Fuel injector/high pressure fuel injector HDEV (petrol) Occasional malfunction
13640115 Fuel injector/high pressure fuel injector HDEV (petrol) Permanent malfunction
13640139 Fuel injector/high pressure fuel injector HDEV (petrol) Unpleasant noises
13640148 Fuel injector/high pressure fuel injector HDEV (petrol) Leaking
13640196 Fuel injector/high pressure fuel injector HDEV (petrol) Fault code in diagnosis memory (warn. lamp o
13640199 Fuel injector/high pressure fuel injector HDEV (petrol) Fault code stored in diagnosis fault code me
136401XX Fuel injector/high pressure fuel injector HDEV (petrol)
13640248 O-ring for injector Leaking
136402XX O-ring for injector
1364XXXX Injector valves, start valves
13710037 Intake air cleaner housing Loose
13710048 Intake air cleaner housing Leaking
137100XX Intake air cleaner housing
13710314 Auxiliary air flaps (N73) Occasional malfunction
13710315 Auxiliary air flaps (N73) Permanent malfunction
137103XX Auxiliary air flaps (N73)
13719337 E53 M62 Intake hose loose
1371XXXX Intake mufflers
13720001 Unfiltered air flow (before air filter) Cracked / broken / torn off
13720032 Unfiltered air flow (before air filter) Deformed / distorted / bent
13720037 Unfiltered air flow (before air filter) Loose
13720039 Unfiltered air flow (before air filter) Unpleasant noises
13720048 Unfiltered air flow (before air filter) Leaking
137200XX Unfiltered air flow (before air filter)
13720101 Clean air flow (after air filter) Cracked / broken / torn off
13720132 Clean air flow (after air filter) Deformed / distorted / bent
13720137 Clean air flow (after air filter) Loose
13720139 Clean air flow (after air filter) Unpleasant noises
13720148 Clean air flow (after air filter) Leaking
137201XX Clean air flow (after air filter)
13720201 Flexible gaiter for volume air flow/mass air flow sensor Cracked / broken / torn off
13720237 Flexible gaiter for volume air flow/mass air flow sensor Loose
13720239 Flexible gaiter for volume air flow/mass air flow sensor Unpleasant noises
13720248 Flexible gaiter for volume air flow/mass air flow sensor Leaking
137202XX Flexible gaiter for volume air flow/mass air flow sensor
1372XXXX Air flow
13740037 Sound generator with mounting bracket Loose
13740048 Sound generator with mounting bracket Leaking
137400XX Sound generator with mounting bracket
1374XXXX Engine sound system
13800117 CN gas supply system Odour
13800139 CN gas supply system Unpleasant noises
138001XX CN gas supply system
13800209 CN gas - changing over to gas mode Goes out
13800211 CN gas - changing over to gas mode Occasional failure
13800212 CN gas - changing over to gas mode Permanent failure
138002XX CN gas - changing over to gas mode
13800324 CN gas - idle speed in gas mode Surge
13800335 CN gas - idle speed in gas mode Uneven running
13800347 CN gas - idle speed in gas mode Drop in engine speed
138003XX CN gas - idle speed in gas mode
13800417 CN gas - engine in gas mode Odour
13800425 CN gas - engine in gas mode Rough running
13800438 CN gas - engine in gas mode Shaking
13800442 CN gas - engine in gas mode Misfires / malfunction
13800456 CN gas - engine in gas mode Poor running characteristics / friction
138004XX CN gas - engine in gas mode
13800560 CN gas - fuel consumption in gas mode Too high
138005XX CN gas - fuel consumption in gas mode
13800659 CN gas - engine output in gas mode Too low / deep / slight
138006XX CN gas - engine output in gas mode
13800763 CN gas - starting time in gas mode Too long
138007XX CN gas - starting time in gas mode
1380XXXX CN-gas - unit
13810137 CN gas - low pressure line Loose
13810148 CN gas - low pressure line Leaking
138101XX CN gas - low pressure line
13810214 CN gas - injection valve Occasional malfunction
13810215 CN gas - injection valve Permanent malfunction
13810239 CN gas - injection valve Unpleasant noises
138102XX CN gas - injection valve
1381XXXX CN gas - valves and lines
13820114 CN gas - high / low pressure reducer Occasional malfunction
13820115 CN gas - high / low pressure reducer Permanent malfunction
138201XX CN gas - high / low pressure reducer
13820214 CN gas - intake system, vacuum sensor Occasional malfunction
13820215 CN gas - intake system, vacuum sensor Permanent malfunction
138202XX CN gas - intake system, vacuum sensor
13820314 CN gas - metering unit Occasional malfunction
13820315 CN gas - metering unit Permanent malfunction
13820348 CN gas - metering unit Leaking
13820380 CN gas - metering unit short circuit
13820381 CN gas - metering unit interruption
138203XX CN gas - metering unit
1382XXXX CN gas - mixture regulator, metering system, pressure relief
13830114 CN gas - gas cylinder with non-return valve Occasional malfunction
13830137 CN gas - gas cylinder with non-return valve Loose
13830148 CN gas - gas cylinder with non-return valve Leaking
13830152 CN gas - gas cylinder with non-return valve Not opening
13830153 CN gas - gas cylinder with non-return valve Not closing
13830175 CN gas - gas cylinder with non-return valve corroded
138301XX CN gas - gas cylinder with non-return valve
13830211 CN gas - gas leak sensor Occasional failure
13830212 CN gas - gas leak sensor Permanent failure
13830214 CN gas - gas leak sensor Occasional malfunction
13830215 CN gas - gas leak sensor Permanent malfunction
138302XX CN gas - gas leak sensor
13830348 CN gas - vent housing Leaking
138303XX CN gas - vent housing
13830448 CN gas - vent hose Leaking
138304XX CN gas - vent hose
13830537 CN gas - tank frame Loose
13830575 CN gas - tank frame corroded
138305XX CN gas - tank frame
13830613 CN gas - condensate tank Broken
13830617 CN gas - condensate tank Odour
13830637 CN gas - condensate tank Loose
138306XX CN gas - condensate tank
1383XXXX CN gas - gas tank with bracket and valves
13840148 CN gas - high pressure lines Leaking
138401XX CN gas - high pressure lines
13840327 CN gas - non-return valve Locked/jammed
13840348 CN gas - non-return valve Leaking
13840383 CN gas - non-return valve incorrect or no switching action
138403XX CN gas - non-return valve
1384XXXX CN gas - high pressure lines
13850137 CN gas - electromagnetic non-return valve Loose
13850148 CN gas - electromagnetic non-return valve Leaking
13850180 CN gas - electromagnetic non-return valve short circuit
13850183 CN gas - electromagnetic non-return valve incorrect or no switching action
138501XX CN gas - electromagnetic non-return valve
13850214 CN gas - filler connection Occasional malfunction
13850215 CN gas - filler connection Permanent malfunction
13850248 CN gas - filler connection Leaking
13850276 CN gas - filler connection dirty / blocked
138502XX CN gas - filler connection
13850301 CN gas - end cap Cracked / broken / torn off
138503XX CN gas - end cap
13850514 CN gas - changeover, gas/petrol operation Occasional malfunction
13850515 CN gas - changeover, gas/petrol operation Permanent malfunction
13850529 CN gas - changeover, gas/petrol operation Sticking/jammed
13850537 CN gas - changeover, gas/petrol operation Loose
13850586 CN gas - changeover, gas/petrol operation does not light up
138505XX CN gas - changeover, gas/petrol operation
13850686 CN gas - indicator lamp does not light up
138506XX CN gas - indicator lamp
1385XXXX CN gas - electrical components
13860114 CN gas - control unit Occasional malfunction
13860115 CN gas - control unit Permanent malfunction
13860137 CN gas - control unit Loose
138601XX CN gas - control unit
13860214 CN gas - changeover module Occasional malfunction
13860215 CN gas - changeover module Permanent malfunction
13860237 CN gas - changeover module Loose
138602XX CN gas - changeover module
13860314 CN gas - gas quality switch Occasional malfunction
13860315 CN gas - gas quality switch Permanent malfunction
138603XX CN gas - gas quality switch
13860414 CN gas - oxygen sensor Occasional malfunction
13860415 CN gas - oxygen sensor Permanent malfunction
13860479 CN gas - oxygen sensor incorrect connection /contact
138604XX CN gas - oxygen sensor
13860514 CN gas - non-return relay Occasional malfunction
13860515 CN gas - non-return relay Permanent malfunction
13860537 CN gas - non-return relay Loose
138605XX CN gas - non-return relay
1386XXXX CN gas - engine electrics
13900114 Fuel tank vent valve (carbon canister) Occasional malfunction
13900115 Fuel tank vent valve (carbon canister) Permanent malfunction
13900139 Fuel tank vent valve (carbon canister) Unpleasant noises
13900196 Fuel tank vent valve (carbon canister) Fault code in diagnosis memory (warn. lamp on)
13900199 Fuel tank vent valve (carbon canister) Fault code stored in diagnosis fault code memory (no warning
139001XX Fuel tank vent valve (carbon canister)
13900237 Hose to tank venting valve Loose
13900248 Hose to tank venting valve Leaking
139002XX Hose to tank venting valve
1390XXXX Carbon canister vent
13XXXXXX Fuel metering and control system
16110032 Fuel tank Deformed / distorted / bent
16110048 Fuel tank Leaking
16110075 Fuel tank corroded
16110094 Fuel tank difficult to fill tank
161100XX Fuel tank
16110137 Fuel tank filler tube (incl. filler hose) Loose
16110148 Fuel tank filler tube (incl. filler hose) Leaking
16110175 Fuel tank filler tube (incl. filler hose) corroded
161101XX Fuel tank filler tube (incl. filler hose)
16110234 Fuel tank bayonet cap Stiff to move
16110237 Fuel tank bayonet cap Loose
16110248 Fuel tank bayonet cap Leaking
161102XX Fuel tank bayonet cap
16110337 Fuel expansion tank Loose
16110348 Fuel expansion tank Leaking
161103XX Fuel expansion tank
16110601 Fuel tank mount Cracked / broken / torn off
16110637 Fuel tank mount Loose
16110639 Fuel tank mount Unpleasant noises
161106XX Fuel tank mount
16110714 Fuel tank pressure sensor Occasional malfunction
16110715 Fuel tank pressure sensor Permanent malfunction
16110799 Fuel tank pressure sensor Fault code stored in diagnosis fault code memory (no warning lamp)
161107XX Fuel tank pressure sensor
16110939 Fuel (sloshing sound) Unpleasant noises
161109XX Fuel (sloshing sound)
16111017 Fuel supply system Odour
161110XX Fuel supply system
16111148 Threaded connection for left tank installation unit, fuel tank Leaking
161111XX Threaded connection for left tank installation unit, fuel tank
16111248 Threaded connection for right tank installation unit, fuel tank Leaking
161112XX Threaded connection for right tank installation unit, fuel tank
16111348 Left tank installation unit, fuel tank Leaking
161113XX Left tank installation unit, fuel tank
16111448 Right tank installation unit, fuel tank Leaking
161114XX Right tank installation unit, fuel tank
1611XXXX Fuel tank with mount
16120037 Fuel lines/connections in engine compartment (fixed to body) Loose
16120039 Fuel lines/connections in engine compartment (fixed to body) Unpleasant noises
16120048 Fuel lines/connections in engine compartment (fixed to body) Leaking
161200XX Fuel lines/connections in engine compartment (fixed to body)
16120237 Fuel lines/connections (at tank) Loose
16120239 Fuel lines/connections (at tank) Unpleasant noises
16120248 Fuel lines/connections (at tank) Leaking
161202XX Fuel lines/connections (at tank)
16120711 Distributor (between fuel supply and return line) Occasional failure
16120712 Distributor (between fuel supply and return line) Permanent failure
16120748 Distributor (between fuel supply and return line) Leaking
16120776 Distributor (between fuel supply and return line) dirty / blocked
161207XX Distributor (between fuel supply and return line)
16120837 Fuel lines/connections, underbody Loose
16120839 Fuel lines/connections, underbody Unpleasant noises
16120848 Fuel lines/connections, underbody Leaking
161208XX Fuel lines/connections, underbody
16129239 E39 E46 M57 Fuel pump resonance noise in vehicle interior
1612XXXX Fuel lines
16130037 Breather line/connections (from fuel tank to carbon canister / expansion tank) Loose
16130039 Breather line/connections (from fuel tank to carbon canister / expansion tank) Unpleasant noises
16130048 Breather line/connections (from fuel tank to carbon canister / expansion tank) Leaking
16130076 Breather line/connections (from fuel tank to carbon canister / expansion tank) dirty / blocked
161300XX Breather line/connections (from fuel tank to carbon canister / expansion tank)
16130239 Carbon canister (AKF) Unpleasant noises
16130248 Carbon canister (AKF) Leaking
16130276 Carbon canister (AKF) dirty / blocked
161302XX Carbon canister (AKF)
16130437 Breather line/connections (from carbon canister to fuel tank vent valve) Loose
16130439 Breather line/connections (from carbon canister to fuel tank vent valve) Unpleasant noises
16130448 Breather line/connections (from carbon canister to fuel tank vent valve) Leaking
16130476 Breather line/connections (from carbon canister to fuel tank vent valve) dirty / blocked
161304XX Breather line/connections (from carbon canister to fuel tank vent valve)
16130501 Leak diagnosis unit Cracked / broken / torn off
16130514 Leak diagnosis unit Occasional malfunction
16130515 Leak diagnosis unit Permanent malfunction
16130539 Leak diagnosis unit Unpleasant noises
16130548 Leak diagnosis unit Leaking
16130576 Leak diagnosis unit dirty / blocked
161305XX Leak diagnosis unit
16130632 Leak diagnosis unit connection at carbon canister (AKF) Deformed / distorted / bent
16130648 Leak diagnosis unit connection at carbon canister (AKF) Leaking
16130676 Leak diagnosis unit connection at carbon canister (AKF) dirty / blocked
161306XX Leak diagnosis unit connection at carbon canister (AKF)
16130732 Line to intake pipe (leakage diagnosis unit LDE only) Deformed / distorted / bent
16130739 Line to intake pipe (leakage diagnosis unit LDE only) Unpleasant noises
16130748 Line to intake pipe (leakage diagnosis unit LDE only) Leaking
16130776 Line to intake pipe (leakage diagnosis unit LDE only) dirty / blocked
161307XX Line to intake pipe (leakage diagnosis unit LDE only)
16130832 Dust filter with line to leak diagnosis unit Deformed / distorted / bent
16130866 Dust filter with line to leak diagnosis unit No effect
16130876 Dust filter with line to leak diagnosis unit dirty / blocked
161308XX Dust filter with line to leak diagnosis unit
16139117 E46 M43TU M52TU M54 Fuel odour
1613XXXX Fuel ventilation system, emission monitoring
16140218 Fuel filler sensor, left Incorrect/incomplete reading
161402XX Fuel filler sensor, left
16140318 Fuel filler sensor, right Incorrect/incomplete reading
161403XX Fuel filler sensor, right
16140411 Electric fuel pump in fuel tank (in-tank electric fuel pump) Occasional failure
16140412 Electric fuel pump in fuel tank (in-tank electric fuel pump) Permanent failure
16140439 Electric fuel pump in fuel tank (in-tank electric fuel pump) Unpleasant noises
161404XX Electric fuel pump in fuel tank (in-tank electric fuel pump)
16140515 Fuel sucking jet pump Permanent malfunction
16140539 Fuel sucking jet pump Unpleasant noises
16140576 Fuel sucking jet pump dirty / blocked
161405XX Fuel sucking jet pump
16140699 EKP control unit Fault code stored in diagnosis fault code memory (no warning lamp)
161406XX EKP control unit
16140739 Pressure regulator in delivery unit Unpleasant noises
16140748 Pressure regulator in delivery unit Leaking
161407XX Pressure regulator in delivery unit
16140848 Hydraulic lines/connections in fuel tank Leaking
161408XX Hydraulic lines/connections in fuel tank
16140981 Electric lines/connections in fuel tank interruption
161409XX Electric lines/connections in fuel tank
16141011 Electric fuel pump in feed line (diesel, in-line electric fuel pump) Occasional failure
16141012 Electric fuel pump in feed line (diesel, in-line electric fuel pump) Permanent failure
16141039 Electric fuel pump in feed line (diesel, in-line electric fuel pump) Unpleasant noises
161410XX Electric fuel pump in feed line (diesel, in-line electric fuel pump)
16141148 Fuel filter in delivery unit Leaking
161411XX Fuel filter in delivery unit
16141276 Intake filter, in-tank electric fuel pump dirty / blocked
161412XX Intake filter, in-tank electric fuel pump
16149218 E53 M62 M54 Fuel gauge incorrect (fuel level sensor)
16149318 E36/7 Incorrect value shown by fuel gauge (fuel level sensor)
16149418 E36 Fuel gauge incorrect - fuel level sensor
16149518 R50 W10 MINI Fuel gauge incorrect indication (fill level sensor)
1614XXXX Fuel delivery, preparation and volume measurement
16XXXXXX Fuel supply
