الجزء السادس :
33520015 Shock absorber on rear axle Permanent malfunction
33520039 Shock absorber on rear axle Unpleasant noises
33520048 Shock absorber on rear axle Leaking
335200XX Shock absorber on rear axle
33520101 Shock absorber rubber joint Cracked / broken / torn off
33520137 Shock absorber rubber joint Loose
33520139 Shock absorber rubber joint Unpleasant noises
335201XX Shock absorber rubber joint
33520237 Screw connection on body thrust bearing Loose
335202XX Screw connection on body thrust bearing
33520337 Screw connection on shock absorber thrust bearing Loose
335203XX Screw connection on shock absorber thrust bearing
33520413 Connection for shock absorber with damping force adjustment (EDC), rear axle Broken
33520479 Connection for shock absorber with damping force adjustment (EDC), rear axle incorrect connection /c
335204XX Connection for shock absorber with damping force adjustment (EDC), rear axle
33520515 Shock absorber with damping force adjustment (EDC), rear axle Permanent malfunction
33520539 Shock absorber with damping force adjustment (EDC), rear axle Unpleasant noises
33520548 Shock absorber with damping force adjustment (EDC), rear axle Leaking
335205XX Shock absorber with damping force adjustment (EDC), rear axle
33520601 Thrust bearing, top rear Cracked / broken / torn off
33520639 Thrust bearing, top rear Unpleasant noises
335206XX Thrust bearing, top rear
3352XXXX Shock absorber
33530013 Coil spring, rear Broken
33530039 Coil spring, rear Unpleasant noises
335300XX Coil spring, rear
33530137 Piston rod guard, rear Loose
335301XX Piston rod guard, rear
33530301 Auxiliary spring (on piston rod), rear Cracked / broken / torn off
335303XX Auxiliary spring (on piston rod), rear
33539139 E53 Rattling noise from area of rear axle (spring)
3353XXXX Springs with mount
33550037 Retaining bracket, stabilizer bar (rear axle) Loose
335500XX Retaining bracket, stabilizer bar (rear axle)
33550121 Rubber mount, stabilizer bar (rear axle) Worn
33550139 Rubber mount, stabilizer bar (rear axle) Unpleasant noises
335501XX Rubber mount, stabilizer bar (rear axle)
33550234 Stabilizer link on stabilizer bar (rear axle) Stiff to move
33550237 Stabilizer link on stabilizer bar (rear axle) Loose
33550239 Stabilizer link on stabilizer bar (rear axle) Unpleasant noises
335502XX Stabilizer link on stabilizer bar (rear axle)
33550534 Stabiliser bar link on axle Stiff to move
33550537 Stabiliser bar link on axle Loose
33550539 Stabiliser bar link on axle Unpleasant noises
335505XX Stabiliser bar link on axle
33559022 E36/5 E36/7 M44 M52 S52 Stabilizer link, rear stabilizer bar
3355XXXX Stabiliser bar
33XXXXXX Rear axle
34000139 Front axle brakes - squeaking Unpleasant noises
340001XX Front axle brakes - squeaking
34000339 Front axle brakes - 'grating at traffic lights' Unpleasant noises
340003XX Front axle brakes - 'grating at traffic lights'
34000456 Front axle brakes - vibration Poor running characteristics / friction
340004XX Front axle brakes - vibration
34000539 Front axle brakes - other noise Unpleasant noises
340005XX Front axle brakes - other noise
34000656 Front axle brakes - cyclical vibration from steering wheel Poor running characteristics / friction
340006XX Front axle brakes - cyclical vibration from steering wheel
34001139 Rear axle brakes - squeaking Unpleasant noises
340011XX Rear axle brakes - squeaking
34001339 Rear axle brakes - 'grating at traffic lights' Unpleasant noises
340013XX Rear axle brakes - 'grating at traffic lights'
34001456 Rear axle brakes - vibration Poor running characteristics / friction
340014XX Rear axle brakes - vibration
34001539 Rear axle brakes - other noise Unpleasant noises
340015XX Rear axle brakes - other noise
34009356 E46 Torsional vibration in steering wheel when braking
3400XXXX Brakes (symptom defect codes)
34110001 Front brake discs Cracked / broken / torn off
34110075 Front brake discs corroded
341100XX Front brake discs
34110129 Front brake caliper Sticking/jammed
34110137 Front brake caliper Loose
34110148 Front brake caliper Leaking
341101XX Front brake caliper
34110216 Front brake linings Broken off
34110229 Front brake linings Sticking/jammed
341102XX Front brake linings
34110301 Front brake discs, shield plate Cracked / broken / torn off
34110339 Front brake discs, shield plate Unpleasant noises
341103XX Front brake discs, shield plate
34110414 Front brake pad wear sensor Occasional malfunction
34110415 Front brake pad wear sensor Permanent malfunction
34110479 Front brake pad wear sensor incorrect connection /contact
341104XX Front brake pad wear sensor
34110537 Front brake caliper - bleeder screw Loose
341105XX Front brake caliper - bleeder screw
34110637 Front brake caliper - lining retaining spring Loose
341106XX Front brake caliper - lining retaining spring
34110737 Front brake caliper - lining backing film Loose
341107XX Front brake caliper - lining backing film
34119339 E46 M52 M54 Front/rear brake pads, squeaking noise
3411XXXX Front wheel brake
34210001 Rear brake discs Cracked / broken / torn off
34210075 Rear brake discs corroded
342100XX Rear brake discs
34210129 Rear brake caliper Sticking/jammed
34210137 Rear brake caliper Loose
34210148 Rear brake caliper Leaking
342101XX Rear brake caliper
34210216 Rear brake linings Broken off
34210229 Rear brake linings Sticking/jammed
342102XX Rear brake linings
34210301 Rear brake discs, shield plate Cracked / broken / torn off
34210339 Rear brake discs, shield plate Unpleasant noises
342103XX Rear brake discs, shield plate
34210429 Automatic thrust rod adjustment Sticking/jammed
34210466 Automatic thrust rod adjustment No effect
342104XX Automatic thrust rod adjustment
34210637 Rear brake caliper - bleeder screw Loose
342106XX Rear brake caliper - bleeder screw
34210715 Hand/parking brake, automatic readjustment, rear brake caliper (MINI) Permanent malfunction
34210729 Hand/parking brake, automatic readjustment, rear brake caliper (MINI) Sticking/jammed
342107XX Hand/parking brake, automatic readjustment, rear brake caliper (MINI)
34210837 Rear brake caliper - lining retaining spring Loose
342108XX Rear brake caliper - lining retaining spring
34210937 Rear brake caliper - lining backing film Loose
342109XX Rear brake caliper - lining backing film
34211914 Rear brake pad sensor Occasional malfunction
34211915 Rear brake pad sensor Permanent malfunction
34211979 Rear brake pad sensor incorrect connection /contact
342119XX Rear brake pad sensor
34212023 Leg spring, rear brake caliper (hand/parking brake) Incorrect / not fitted
34212037 Leg spring, rear brake caliper (hand/parking brake) Loose
342120XX Leg spring, rear brake caliper (hand/parking brake)
3421XXXX Rear wheel brake
34300014 Pressure sensor ACC (adaptive cruise control) Occasional malfunction
34300015 Pressure sensor ACC (adaptive cruise control) Permanent malfunction
34300048 Pressure sensor ACC (adaptive cruise control) Leaking
34300079 Pressure sensor ACC (adaptive cruise control) incorrect connection /contact
343000XX Pressure sensor ACC (adaptive cruise control)
3430XXXX Brake actuation (hydraulic system)
34310014 Master brake cylinder Occasional malfunction
34310015 Master brake cylinder Permanent malfunction
34310039 Master brake cylinder Unpleasant noises
34310048 Master brake cylinder Leaking
343100XX Master brake cylinder
3431XXXX Master brake cylinder
34320048 Brake fluid reservoir Leaking
343200XX Brake fluid reservoir
34320148 Brake hose Leaking
343201XX Brake hose
34320248 Pipes Leaking
343202XX Pipes
34320848 Cap (incl. warning switch) brake fluid reservoir Leaking
34320879 Cap (incl. warning switch) brake fluid reservoir incorrect connection /contact
343208XX Cap (incl. warning switch) brake fluid reservoir
3432XXXX Brake lines
34330014 Brake booster Occasional malfunction
34330015 Brake booster Permanent malfunction
34330039 Brake booster Unpleasant noises
343300XX Brake booster
34330132 Vacuum hose/line, brake booster Deformed / distorted / bent
34330148 Vacuum hose/line, brake booster Leaking
343301XX Vacuum hose/line, brake booster
34330214 Brake booster check valve Occasional malfunction
34330215 Brake booster check valve Permanent malfunction
343302XX Brake booster check valve
3433XXXX Brake booster
34340148 Brake pressure regulator Leaking
34340166 Brake pressure regulator No effect
343401XX Brake pressure regulator
34340248 Pressure accumulator Leaking
343402XX Pressure accumulator
34340312 Regulator for pressure accumulator Permanent failure
34340339 Regulator for pressure accumulator Unpleasant noises
343403XX Regulator for pressure accumulator
3434XXXX Brake regulation
34410001 Handbrake/parking brake lever, handle Cracked / broken / torn off
34410029 Handbrake/parking brake lever, handle Sticking/jammed
34410039 Handbrake/parking brake lever, handle Unpleasant noises
34410065 Handbrake/parking brake lever, handle Does not lock into position
344100XX Handbrake/parking brake lever, handle
34410201 Handbrake lever cover / trim Cracked / broken / torn off
34410237 Handbrake lever cover / trim Loose
344102XX Handbrake lever cover / trim
34410437 Handbrake/parking brake, duo-servo brake shoes with lining Loose
34410439 Handbrake/parking brake, duo-servo brake shoes with lining Unpleasant noises
344104XX Handbrake/parking brake, duo-servo brake shoes with lining
34410701 Parking brake cable assemblies (bowden cable assemblies) Cracked / broken / torn off
34410739 Parking brake cable assemblies (bowden cable assemblies) Unpleasant noises
34410775 Parking brake cable assemblies (bowden cable assemblies) corroded
344107XX Parking brake cable assemblies (bowden cable assemblies)
34410829 Handbrake/parking brake, duo-servo brake shoe expander Sticking/jammed
344108XX Handbrake/parking brake, duo-servo brake shoe expander
34410934 Handbrake, Duo-Servo adjusting unit Stiff to move
344109XX Handbrake, Duo-Servo adjusting unit
34411014 Parking brake actuating unit Occasional malfunction
34411015 Parking brake actuating unit Permanent malfunction
34411039 Parking brake actuating unit Unpleasant noises
344110XX Parking brake actuating unit
34411101 Parking brake assembly tray Cracked / broken / torn off
34411137 Parking brake assembly tray Loose
34411150 Parking brake assembly tray Water ingress / condensate
344111XX Parking brake assembly tray
34411201 Parking brake, assembly tray cover Cracked / broken / torn off
34411237 Parking brake, assembly tray cover Loose
344112XX Parking brake, assembly tray cover
34411329 Parking brake emergency release Sticking/jammed
34411366 Parking brake emergency release No effect
344113XX Parking brake emergency release
34411439 Parking brake control unit Unpleasant noises
34411448 Parking brake control unit Leaking
34411499 Parking brake control unit Fault code stored in diagnosis fault code memory (no warning lamp)
344114XX Parking brake control unit
34412087 Handbrake/parking brake warning lamp lights up
344120XX Handbrake/parking brake
34412163 Handbrake/parking brake lever travel Too long
344121XX Handbrake/parking brake lever travel
34412297 Handbrake/parking brake power distribution pulls to one side
344122XX Handbrake/parking brake power distribution
3441XXXX Parking brake
34510014 Hydraulic unit, ABS Occasional malfunction
34510015 Hydraulic unit, ABS Permanent malfunction
34510048 Hydraulic unit, ABS Leaking
34510072 Hydraulic unit, ABS Poorly bled
34510079 Hydraulic unit, ABS incorrect connection /contact
345100XX Hydraulic unit, ABS
34510514 Hydraulic unit (ABS/ASC) Occasional malfunction
34510515 Hydraulic unit (ABS/ASC) Permanent malfunction
34510548 Hydraulic unit (ABS/ASC) Leaking
34510572 Hydraulic unit (ABS/ASC) Poorly bled
34510579 Hydraulic unit (ABS/ASC) incorrect connection /contact
345105XX Hydraulic unit (ABS/ASC)
34511014 Hydraulic unit ABS/DSC Occasional malfunction
34511015 Hydraulic unit ABS/DSC Permanent malfunction
34511048 Hydraulic unit ABS/DSC Leaking
34511072 Hydraulic unit ABS/DSC Poorly bled
34511079 Hydraulic unit ABS/DSC incorrect connection /contact
345110XX Hydraulic unit ABS/DSC
34511114 Piston unit DSC Occasional malfunction
34511115 Piston unit DSC Permanent malfunction
34511148 Piston unit DSC Leaking
345111XX Piston unit DSC
34511214 Precharge pump DSC Occasional malfunction
34511215 Precharge pump DSC Permanent malfunction
34511248 Precharge pump DSC Leaking
34511279 Precharge pump DSC incorrect connection /contact
345112XX Precharge pump DSC
34511314 Pressure sensor DSC Occasional malfunction
34511315 Pressure sensor DSC Permanent malfunction
34511348 Pressure sensor DSC Leaking
34511379 Pressure sensor DSC incorrect connection /contact
345113XX Pressure sensor DSC
3451XXXX Slip Control Systems (ABS, ASC, DSC) - mechanism
34520314 Control unit (ABS/ASC) Occasional malfunction
34520315 Control unit (ABS/ASC) Permanent malfunction
34520379 Control unit (ABS/ASC) incorrect connection /contact
345203XX Control unit (ABS/ASC)
34520514 Wheel speed sensor, front Occasional malfunction
34520515 Wheel speed sensor, front Permanent malfunction
34520537 Wheel speed sensor, front Loose
34520579 Wheel speed sensor, front incorrect connection /contact
345205XX Wheel speed sensor, front
34520614 Wheel speed sensor, rear Occasional malfunction
34520615 Wheel speed sensor, rear Permanent malfunction
34520637 Wheel speed sensor, rear Loose
34520679 Wheel speed sensor, rear incorrect connection /contact
345206XX Wheel speed sensor, rear
34521014 DSC control unit (incl. HDC) Occasional malfunction
34521015 DSC control unit (incl. HDC) Permanent malfunction
34521079 DSC control unit (incl. HDC) incorrect connection /contact
345210XX DSC control unit (incl. HDC)
34521114 Rotation rate sensor / sensor cluster DSC Occasional malfunction
34521115 Rotation rate sensor / sensor cluster DSC Permanent malfunction
34521137 Rotation rate sensor / sensor cluster DSC Loose
34521179 Rotation rate sensor / sensor cluster DSC incorrect connection /contact
345211XX Rotation rate sensor / sensor cluster DSC
34529414 E38 E39 E53 Servotronic sporadically inoperative - ASC-/DSC control unit
3452XXXX Slip Control Systems (ABS, ASC, DSC) - electronics
34XXXXXX Brakes
35110037 Pedal bracket Loose
351100XX Pedal bracket
3511XXXX Pedal bracket
35210134 Brake pedal Stiff to move
35210139 Brake pedal Unpleasant noises
352101XX Brake pedal
35210637 Brake pedal rubber Loose
352106XX Brake pedal rubber
35219139 E53 Brake pedal noise during fast release
3521XXXX Brake pedal with connecting linkages
35310134 Clutch pedal Stiff to move
35310139 Clutch pedal Unpleasant noises
35310157 Clutch pedal Vibration / oscillation
353101XX Clutch pedal
35310737 Clutch pedal rubber Loose
353107XX Clutch pedal rubber
3531XXXX Clutch pedal with connecting linkages
35410013 Accelerator operation/accelerator pedal module Broken
35410014 Accelerator operation/accelerator pedal module Occasional malfunction
35410015 Accelerator operation/accelerator pedal module Permanent malfunction
35410034 Accelerator operation/accelerator pedal module Stiff to move
35410037 Accelerator operation/accelerator pedal module Loose
35410039 Accelerator operation/accelerator pedal module Unpleasant noises
35410057 Accelerator operation/accelerator pedal module Vibration / oscillation
354100XX Accelerator operation/accelerator pedal module
35410601 Bowden cable for throttle actuation Cracked / broken / torn off
35410634 Bowden cable for throttle actuation Stiff to move
35410640 Bowden cable for throttle actuation Poorly adjusted / outside tolerance
354106XX Bowden cable for throttle actuation
35410814 Kick-down switch Occasional malfunction
35410815 Kick-down switch Permanent malfunction
35410837 Kick-down switch Loose
35410840 Kick-down switch Poorly adjusted / outside tolerance
354108XX Kick-down switch
35411537 Full-throttle stop Loose
35411540 Full-throttle stop Poorly adjusted / outside tolerance
354115XX Full-throttle stop
35419071 E38 E39 E46 E52 E53 E65 E66 R50 R53 "Stick-slip" effect from accelerator pedal module
3541XXXX Accelerator pedal with linkages, kick-down
35500137 Foot-operated parking brake damper Loose
35500148 Foot-operated parking brake damper Leaking
35500166 Foot-operated parking brake damper No effect
355001XX Foot-operated parking brake damper
35500234 Foot-operated parking brake release cable Stiff to move
35500266 Foot-operated parking brake release cable No effect
355002XX Foot-operated parking brake release cable
35500337 Foot-operated parking brake - rubber on pedal Loose
355003XX Foot-operated parking brake - rubber on pedal
35500413 Foot-operated parking brake, release handle Broken
35500429 Foot-operated parking brake, release handle Sticking/jammed
35500441 Foot-operated parking brake, release handle Poorly adapted/fitted
355004XX Foot-operated parking brake, release handle
35502029 Foot-operated parking brake Sticking/jammed
35502034 Foot-operated parking brake Stiff to move
35502039 Foot-operated parking brake Unpleasant noises
35502065 Foot-operated parking brake Does not lock into position
35502087 Foot-operated parking brake warning lamp lights up
355020XX Foot-operated parking brake
35502163 Foot-operated parking brake - travel Too long
355021XX Foot-operated parking brake - travel
3550XXXX Foot-operated parking brake (actuation)
35XXXXXX Foot actuation
36110148 Steel disc wheel, aluminium band wheel Leaking
36110157 Steel disc wheel, aluminium band wheel Vibration / oscillation
361101XX Steel disc wheel, aluminium band wheel
36110248 Light alloy wheel Leaking
36110257 Light alloy wheel Vibration / oscillation
361102XX Light alloy wheel
36110548 Rubber valve Leaking
361105XX Rubber valve
36110648 Screw valve, aluminium Leaking
36110675 Screw valve, aluminium corroded
361106XX Screw valve, aluminium
36111039 Spare wheel/compact spare Unpleasant noises
36111048 Spare wheel/compact spare Leaking
36111065 Spare wheel/compact spare Does not lock into position
36111075 Spare wheel/compact spare corroded
361110XX Spare wheel/compact spare
36111148 Valve extension, space saver spare wheel Leaking
361111XX Valve extension, space saver spare wheel
3611XXXX Wheels
36120122 Tyres - Continental Manufacturing fault
36120139 Tyres - Continental Unpleasant noises
36120157 Tyres - Continental Vibration / oscillation
361201XX Tyres - Continental
36120222 Tyres - Dunlop Manufacturing fault
36120239 Tyres - Dunlop Unpleasant noises
36120257 Tyres - Dunlop Vibration / oscillation
361202XX Tyres - Dunlop
36120322 Tyres - Pirelli Manufacturing fault
36120339 Tyres - Pirelli Unpleasant noises
36120357 Tyres - Pirelli Vibration / oscillation
361203XX Tyres - Pirelli
36120422 Tyres - Uniroyal Manufacturing fault
36120439 Tyres - Uniroyal Unpleasant noises
36120457 Tyres - Uniroyal Vibration / oscillation
361204XX Tyres - Uniroyal
36120622 Tyres - Goodyear Manufacturing fault
36120639 Tyres - Goodyear Unpleasant noises
36120657 Tyres - Goodyear Vibration / oscillation
361206XX Tyres - Goodyear
36120722 Tyres - Michelin Manufacturing fault
36120739 Tyres - Michelin Unpleasant noises
36120757 Tyres - Michelin Vibration / oscillation
361207XX Tyres - Michelin
36120822 Tyres - Bridgestone Manufacturing fault
36120839 Tyres - Bridgestone Unpleasant noises
36120857 Tyres - Bridgestone Vibration / oscillation
361208XX Tyres - Bridgestone
36121085 Emergency section RSC tyres (Run System Component) not passed
361210XX Emergency section RSC tyres (Run System Component)
36121137 Tyre fit, RSC tyres (Run System Component) Loose
361211XX Tyre fit, RSC tyres (Run System Component)
36129257 E65 E66 Torsional vibration in steering wheel without brake intervention (wheels)
3612XXXX Tyres
36130036 Wheel cover Dented/wavy
36130037 Wheel cover Loose
36130078 Wheel cover poor surface finish
36130091 Wheel cover colour differences
361300XX Wheel cover
36130137 Wheel cap / hub cover Loose
36130178 Wheel cap / hub cover poor surface finish
36130191 Wheel cap / hub cover colour differences
361301XX Wheel cap / hub cover
36130237 Badge, hub cover / wheel cover Loose
36130268 Badge, hub cover / wheel cover Peels off / detaches itself
36130291 Badge, hub cover / wheel cover colour differences
361302XX Badge, hub cover / wheel cover
36130316 Wheel stud lock / keeper Broken off
36130329 Wheel stud lock / keeper Sticking/jammed
361303XX Wheel stud lock / keeper
36130529 Hub cover with self-aligning RR symbol Sticking/jammed
36130565 Hub cover with self-aligning RR symbol Does not lock into position
361305XX Hub cover with self-aligning RR symbol
3613XXXX Hub caps, finishers, mounting
36200112 Wheel electronics (RDC) Permanent failure
36200137 Wheel electronics (RDC) Loose
362001XX Wheel electronics (RDC)
36200212 Fixed aerial (RDC) Permanent failure
362002XX Fixed aerial (RDC)
36200380 RDC / RPA button short circuit
36200381 RDC / RPA button interruption
362003XX RDC / RPA button
36200413 Valve unit RDC Broken
36200448 Valve unit RDC Leaking
36200475 Valve unit RDC corroded
362004XX Valve unit RDC
36200512 Tyre failure indicator (RPA) Permanent failure
362005XX Tyre failure indicator (RPA)
36201012 RDC / RPA control unit Permanent failure
362010XX RDC / RPA control unit
36209015 E65 E66 Tyre pressure control (RDC) not functioning
3620XXXX Tyre monitoring systems RDC / RPA
36XXXXXX Wheels and tyres
37001545 Air suspension (LF) height setting, general Not controllable/adjustable
37001559 Air suspension (LF) height setting, general Too low / deep / slight
37001560 Air suspension (LF) height setting, general Too high
37001598 Air suspension (LF) height setting, general not satisfactory
370015XX Air suspension (LF) height setting, general
37001639 Level control, hydropneumatic (HP) Unpleasant noises
37001659 Level control, hydropneumatic (HP) Too low / deep / slight
37001660 Level control, hydropneumatic (HP) Too high
370016XX Level control, hydropneumatic (HP)
3700XXXX Integrated suspension system (symptom defect codes)
37100014 ARS control unit (active roll stabilization) Occasional malfunction
37100015 ARS control unit (active roll stabilization) Permanent malfunction
37100037 ARS control unit (active roll stabilization) Loose
371000XX ARS control unit (active roll stabilization)
37100113 ARS valve block Broken
37100114 ARS valve block Occasional malfunction
37100115 ARS valve block Permanent malfunction
37100148 ARS valve block Leaking
37100179 ARS valve block incorrect connection /contact
371001XX ARS valve block
37100437 ARS hoses Loose
37100439 ARS hoses Unpleasant noises
37100448 ARS hoses Leaking
371004XX ARS hoses
37100537 ARS pipes Loose
37100539 ARS pipes Unpleasant noises
37100548 ARS pipes Leaking
371005XX ARS pipes
37100613 Pipe/hose retaining fixtures ARS Broken
37100637 Pipe/hose retaining fixtures ARS Loose
371006XX Pipe/hose retaining fixtures ARS
3710XXXX Control and suspension elements
37110001 Air suspension (LF) seal, front spring strut Cracked / broken / torn off
371100XX Air suspension (LF) seal, front spring strut
37110137 Mounting on body, air suspension (LF) front spring strut Loose
371101XX Mounting on body, air suspension (LF) front spring strut
37110237 Mounting on axle, air suspension (LF) front spring strut Loose
371102XX Mounting on axle, air suspension (LF) front spring strut
37110339 Front spring strut, air suspension (LF) Unpleasant noises
37110348 Front spring strut, air suspension (LF) Leaking
37110375 Front spring strut, air suspension (LF) corroded
371103XX Front spring strut, air suspension (LF)
37110434 Active stabilizer bar ARS, front axle Stiff to move
37110439 Active stabilizer bar ARS, front axle Unpleasant noises
37110448 Active stabilizer bar ARS, front axle Leaking
371104XX Active stabilizer bar ARS, front axle
3711XXXX Control and suspension elements, front
37120114 HP level control valve Occasional malfunction
37120115 HP level control valve Permanent malfunction
37120137 HP level control valve Loose
37120139 HP level control valve Unpleasant noises
37120148 HP level control valve Leaking
371201XX HP level control valve
37120201 HP mount Cracked / broken / torn off
37120239 HP mount Unpleasant noises
371202XX HP mount
37120515 HP shock absorber Permanent malfunction
37120539 HP shock absorber Unpleasant noises
37120548 HP shock absorber Leaking
371205XX HP shock absorber
37120632 HP control rod Deformed / distorted / bent
37120637 HP control rod Loose
37120640 HP control rod Poorly adjusted / outside tolerance
371206XX HP control rod
37120748 HP gas pressure accumulator, McPherson strut Leaking
371207XX HP gas pressure accumulator, McPherson strut
37120815 HP shock absorber with damping force booster Permanent malfunction
37120839 HP shock absorber with damping force booster Unpleasant noises
37120848 HP shock absorber with damping force booster Leaking
371208XX HP shock absorber with damping force booster
37120913 HP plug connection, McPherson strut Broken
37120979 HP plug connection, McPherson strut incorrect connection /contact
371209XX HP plug connection, McPherson strut
37121034 Active stabilizer bar ARS, rear axle Stiff to move
37121039 Active stabilizer bar ARS, rear axle Unpleasant noises
37121048 Active stabilizer bar ARS, rear axle Leaking
371210XX Active stabilizer bar ARS, rear axle
37123301 Air suspension (LF) seal, rear spring strut Cracked / broken / torn off
371233XX Air suspension (LF) seal, rear spring strut
37123437 Mounting on axle, air suspension (LF) rear spring strut Loose
371234XX Mounting on axle, air suspension (LF) rear spring strut
37123537 Mounting on body, air suspension (LF) rear spring strut Loose
371235XX Mounting on body, air suspension (LF) rear spring strut
37123639 Rear spring strut, air suspension (LF) Unpleasant noises
37123648 Rear spring strut, air suspension (LF) Leaking
37123675 Rear spring strut, air suspension (LF) corroded
371236XX Rear spring strut, air suspension (LF)
37123737 Auxiliary volume tank, rear air suspension Loose
37123748 Auxiliary volume tank, rear air suspension Leaking
37123775 Auxiliary volume tank, rear air suspension corroded
371237XX Auxiliary volume tank, rear air suspension
3712XXXX Control and suspension elements, rear
37131048 HP pipes/hoses Leaking
371310XX HP pipes/hoses
37131148 HP distributor Leaking
371311XX HP distributor
3713XXXX Connecting lines
37140114 Camber-angle warning switch Occasional malfunction
37140115 Camber-angle warning switch Permanent malfunction
37140140 Camber-angle warning switch Poorly adjusted / outside tolerance
37140179 Camber-angle warning switch incorrect connection /contact
371401XX Camber-angle warning switch
37140202 Damping force control unit (EDC) Software error / internal device fault
37140279 Damping force control unit (EDC) incorrect connection /contact
37140280 Damping force control unit (EDC) short circuit
371402XX Damping force control unit (EDC)
37140514 Transverse acceleration sensor DSC Occasional malfunction
37140515 Transverse acceleration sensor DSC Permanent malfunction
37140537 Transverse acceleration sensor DSC Loose
37140579 Transverse acceleration sensor DSC incorrect connection /contact
371405XX Transverse acceleration sensor DSC
37140614 Height sensor Occasional malfunction
37140615 Height sensor Permanent malfunction
37140637 Height sensor Loose
37140679 Height sensor incorrect connection /contact
371406XX Height sensor
37140737 Level sensor - track rod Loose
371407XX Level sensor - track rod
37140802 Air suspension control unit - single axle suspension Software error / internal device fault
37140879 Air suspension control unit - single axle suspension incorrect connection /contact
37140880 Air suspension control unit - single axle suspension short circuit
37140899 Air suspension control unit - single axle suspension Fault code stored in diagnosis fault code memor
371408XX Air suspension control unit - single axle suspension
37140902 Air suspension control unit, two-axle suspension Software error / internal device fault
37140979 Air suspension control unit, two-axle suspension incorrect connection /contact
37140980 Air suspension control unit, two-axle suspension short circuit
37140999 Air suspension control unit, two-axle suspension Fault code stored in diagnosis fault code memory (n
371409XX Air suspension control unit, two-axle suspension
37141014 Transverse acceleration sensor ARS Occasional malfunction
37141015 Transverse acceleration sensor ARS Permanent malfunction
37141037 Transverse acceleration sensor ARS Loose
37141079 Transverse acceleration sensor ARS incorrect connection /contact
371410XX Transverse acceleration sensor ARS
3714XXXX Electrical components
37200013 ARS valve block bracket on body Broken
37200037 ARS valve block bracket on body Loose
37200039 ARS valve block bracket on body Unpleasant noises
372000XX ARS valve block bracket on body
3720XXXX Pressure accumulator and pump unit
37210014 Accumulator/valve unit, air suspension (LF) Occasional malfunction
37210015 Accumulator/valve unit, air suspension (LF) Permanent malfunction
37210037 Accumulator/valve unit, air suspension (LF) Loose
37210048 Accumulator/valve unit, air suspension (LF) Leaking
37210075 Accumulator/valve unit, air suspension (LF) corroded
372100XX Accumulator/valve unit, air suspension (LF)
3721XXXX Pressure accumulator
37220114 Air suspension - air supply unit Occasional malfunction
37220115 Air suspension - air supply unit Permanent malfunction
37220132 Air suspension - air supply unit Deformed / distorted / bent
37220137 Air suspension - air supply unit Loose
37220139 Air suspension - air supply unit Unpleasant noises
37220148 Air suspension - air supply unit Leaking
37220178 Air suspension - air supply unit poor surface finish
372201XX Air suspension - air supply unit
37220701 Mounting bracket for air supply system Cracked / broken / torn off
37220732 Mounting bracket for air supply system Deformed / distorted / bent
37220737 Mounting bracket for air supply system Loose
37220775 Mounting bracket for air supply system corroded
372207XX Mounting bracket for air supply system
3722XXXX Pump unit with container
37230003 Pneumatic plug connection, air suspension Ripped
37230048 Pneumatic plug connection, air suspension Leaking
372300XX Pneumatic plug connection, air suspension
37230132 Piping systems, air suspension (LF) Deformed / distorted / bent
37230137 Piping systems, air suspension (LF) Loose
37230139 Piping systems, air suspension (LF) Unpleasant noises
37230148 Piping systems, air suspension (LF) Leaking
372301XX Piping systems, air suspension (LF)
3723XXXX Pneumatic pipes and distributor
37XXXXXX Integrated suspension systems
41110101 Side member, front (engine mount) Cracked / broken / torn off
41110136 Side member, front (engine mount) Dented/wavy
41110175 Side member, front (engine mount) corroded
411101XX Side member, front (engine mount)
41110201 Battery carrier, front Cracked / broken / torn off
41110236 Battery carrier, front Dented/wavy
41110275 Battery carrier, front corroded
411102XX Battery carrier, front
41110301 Side member, door sill Cracked / broken / torn off
41110336 Side member, door sill Dented/wavy
41110375 Side member, door sill corroded
411103XX Side member, door sill
41110401 Side member, rear (luggage compartment floor) Cracked / broken / torn off
41110436 Side member, rear (luggage compartment floor) Dented/wavy
41110475 Side member, rear (luggage compartment floor) corroded
411104XX Side member, rear (luggage compartment floor)
41110501 Battery carrier, rear Cracked / broken / torn off
41110536 Battery carrier, rear Dented/wavy
41110575 Battery carrier, rear corroded
411105XX Battery carrier, rear
41110601 Support beam, side wall Cracked / broken / torn off
41110636 Support beam, side wall Dented/wavy
41110675 Support beam, side wall corroded
411106XX Support beam, side wall
41110701 Bush on rear axle support Cracked / broken / torn off
41110704 Bush on rear axle support Screw connection torn
41110775 Bush on rear axle support corroded
411107XX Bush on rear axle support
41110801 Bush mounting, rear axle support Cracked / broken / torn off
41110836 Bush mounting, rear axle support Dented/wavy
41110875 Bush mounting, rear axle support corroded
411108XX Bush mounting, rear axle support
41110901 Seatbelt mounting Cracked / broken / torn off
41110975 Seatbelt mounting corroded
411109XX Seatbelt mounting
41111001 Impact absorber support Cracked / broken / torn off
41111048 Impact absorber support Leaking
41111075 Impact absorber support corroded
411110XX Impact absorber support
41111101 Cross member, luggage compartment floor Cracked / broken / torn off
41111175 Cross member, luggage compartment floor corroded
411111XX Cross member, luggage compartment floor
41111201 Reinforcement for rear safety belt Cracked / broken / torn off
41111239 Reinforcement for rear safety belt Unpleasant noises
41111275 Reinforcement for rear safety belt corroded
411112XX Reinforcement for rear safety belt
41111301 Holder on B+ distributor Cracked / broken / torn off
41111304 Holder on B+ distributor Screw connection torn
41111336 Holder on B+ distributor Dented/wavy
411113XX Holder on B+ distributor
41111401 Holder on tank filler pipe Cracked / broken / torn off
41111404 Holder on tank filler pipe Screw connection torn
41111436 Holder on tank filler pipe Dented/wavy
41111441 Holder on tank filler pipe Poorly adapted/fitted
41111475 Holder on tank filler pipe corroded
411114XX Holder on tank filler pipe
4111XXXX Carrier
41120001 Floor panels Cracked / broken / torn off
41120075 Floor panels corroded
411200XX Floor panels
41120201 Connection, engine support beam/wheel housing Cracked / broken / torn off
41120248 Connection, engine support beam/wheel housing Leaking
41120275 Connection, engine support beam/wheel housing corroded
411202XX Connection, engine support beam/wheel housing
41120337 Sealing plugs in underbody Loose
41120348 Sealing plugs in underbody Leaking
411203XX Sealing plugs in underbody
41120437 >Heat shields Loose
41120439 >Heat shields Unpleasant noises
411204XX >Heat shields
4112XXXX Floor panels
41130001 Front bulkhead Cracked / broken / torn off
41130048 Front bulkhead Leaking
41130075 Front bulkhead corroded
411300XX Front bulkhead
41130101 Crossmember, bulkhead Cracked / broken / torn off
41130148 Crossmember, bulkhead Leaking
41130175 Crossmember, bulkhead corroded
411301XX Crossmember, bulkhead
41130201 Carrier support, bulkhead Cracked / broken / torn off
41130248 Carrier support, bulkhead Leaking
41130275 Carrier support, bulkhead corroded
411302XX Carrier support, bulkhead
41130301 Partition wall, equipment area Cracked / broken / torn off
41130348 Partition wall, equipment area Leaking
411303XX Partition wall, equipment area
41130401 Rear wall, heating Cracked / broken / torn off
41130448 Rear wall, heating Leaking
41130475 Rear wall, heating corroded
411304XX Rear wall, heating
41130501 Front cross beam Cracked / broken / torn off
41130548 Front cross beam Leaking
41130575 Front cross beam corroded
411305XX Front cross beam
41130601 Luggage compartment partition Cracked / broken / torn off
411306XX Luggage compartment partition
4113XXXX Partition walls
41140001 Front wheel housings Cracked / broken / torn off
41140036 Front wheel housings Dented/wavy
41140048 Front wheel housings Leaking
41140075 Front wheel housings corroded
411400XX Front wheel housings
41140301 Rear wheel housings Cracked / broken / torn off
41140336 Rear wheel housings Dented/wavy
41140348 Rear wheel housings Leaking
41140375 Rear wheel housings corroded
411403XX Rear wheel housings
41140401 Spring strut support, front Cracked / broken / torn off
41140436 Spring strut support, front Dented/wavy
41140475 Spring strut support, front corroded
411404XX Spring strut support, front
41140513 Holder, front wheel housing Broken
41140532 Holder, front wheel housing Deformed / distorted / bent
41140575 Holder, front wheel housing corroded
411405XX Holder, front wheel housing
4114XXXX Wheel housings
41210036 B-pillar Dented/wavy
41210075 B-pillar corroded
412100XX B-pillar
41210136 A-pillar Dented/wavy
41210175 A-pillar corroded
412101XX A-pillar
41210236 C-pillar Dented/wavy
41210275 C-pillar corroded
412102XX C-pillar
41210375 Windscreen panel corroded
412103XX Windscreen panel
41210636 D-pillar Dented/wavy
41210675 D-pillar corroded
412106XX D-pillar
41210737 Cover, rear window frame E85 Loose
412107XX Cover, rear window frame E85
41219001 E38/3 Reinforcing door lock striker mount at rear
4121XXXX Side frame and pillars
41310001 Outer roof panel Cracked / broken / torn off
41310036 Outer roof panel Dented/wavy
41310075 Outer roof panel corroded
413100XX Outer roof panel
41319136 R50 R53 (with no slide/tilt sunroof) roof outer skin panel draw-in points
4131XXXX Roof
41330041 Front trim with front panel Poorly adapted/fitted
41330075 Front trim with front panel corroded
413300XX Front trim with front panel
4133XXXX Front trim
41340048 Rear end panel, body Leaking
41340075 Rear end panel, body corroded
413400XX Rear end panel, body
4134XXXX Rear trim
41350036 Front side panels Dented/wavy
41350041 Front side panels Poorly adapted/fitted
41350075 Front side panels corroded
413500XX Front side panels
41350136 Rear side panels Dented/wavy
41350148 Rear side panels Leaking
41350175 Rear side panels corroded
413501XX Rear side panels
4135XXXX Side panels
41510036 Front doors Dented/wavy
41510041 Front doors Poorly adapted/fitted
41510075 Front doors corroded
415100XX Front doors
41510134 Hinges on front doors Stiff to move
41510141 Hinges on front doors Poorly adapted/fitted
415101XX Hinges on front doors
41510237 Sound deadener on front doors Loose
415102XX Sound deadener on front doors
41510537 Impact protection, front doors Loose
415105XX Impact protection, front doors
4151XXXX Front side doors
41520036 Rear doors Dented/wavy
41520041 Rear doors Poorly adapted/fitted
41520075 Rear doors corroded
415200XX Rear doors
41520134 Hinges on rear doors Stiff to move
41520141 Hinges on rear doors Poorly adapted/fitted
415201XX Hinges on rear doors
41520237 Sound deadener on rear doors Loose
415202XX Sound deadener on rear doors
41520337 Impact protection, rear doors Loose
415203XX Impact protection, rear doors
4152XXXX Rear side doors
41610036 Engine hood Dented/wavy
41610041 Engine hood Poorly adapted/fitted
41610075 Engine hood corroded
416100XX Engine hood
41610134 Engine hood hinges/hinge tube Stiff to move
41610139 Engine hood hinges/hinge tube Unpleasant noises
41610141 Engine hood hinges/hinge tube Poorly adapted/fitted
416101XX Engine hood hinges/hinge tube
4161XXXX Engine hood
41620036 Rear lid Dented/wavy
41620041 Rear lid Poorly adapted/fitted
41620075 Rear lid corroded
416200XX Rear lid
41620134 Rear lid hinges Stiff to move
41620141 Rear lid hinges Poorly adapted/fitted
416201XX Rear lid hinges
41620436 Bottom section of tailgate (X5) Dented/wavy
41620441 Bottom section of tailgate (X5) Poorly adapted/fitted
41620475 Bottom section of tailgate (X5) corroded
416204XX Bottom section of tailgate (X5)
41629040 E46/2/C Tailgate adjustment
4162XXXX Rear lid
41630041 Fuel filler flap Poorly adapted/fitted
41630052 Fuel filler flap Not opening
41630075 Fuel filler flap corroded
416300XX Fuel filler flap
41630136 Soft-top cover flap (convertible) Dented/wavy
41630141 Soft-top cover flap (convertible) Poorly adapted/fitted
41630175 Soft-top cover flap (convertible) corroded
416301XX Soft-top cover flap (convertible)
41630237 Hinges for soft-top cover flap (convertible) Loose
416302XX Hinges for soft-top cover flap (convertible)
4163XXXX Other flaps/lids
41XXXXXX Body
