رقم العضوية : 131307
السيارة: .
السيارة[2]: E46
الجزء الحادي عشر :
62140086 Speed range program display does not light up
621400XX Speed range program display
62141111 Instrument cluster indicator lamps / warning lamps / background lighting Occasional failure
62141112 Instrument cluster indicator lamps / warning lamps / background lighting Permanent failure
621411XX Instrument cluster indicator lamps / warning lamps / background lighting
62141214 Catalytic converter overheating indicator Occasional malfunction
62141215 Catalytic converter overheating indicator Permanent malfunction
621412XX Catalytic converter overheating indicator
62141314 Auxiliary indicators in tachometer (E65) Occasional malfunction
62141315 Auxiliary indicators in tachometer (E65) Permanent malfunction
621413XX Auxiliary indicators in tachometer (E65)
62141414 Auxiliary indicators in speedometer (E65) Occasional malfunction
62141415 Auxiliary indicators in speedometer (E65) Permanent malfunction
621414XX Auxiliary indicators in speedometer (E65)
6214XXXX Indicator lights and instrument lights
62300014 Head-up display (HUD) Occasional malfunction
62300015 Head-up display (HUD) Permanent malfunction
62300018 Head-up display (HUD) Incorrect/incomplete reading
62300033 Head-up display (HUD) Optical distortion
62300036 Head-up display (HUD) Dented/wavy
623000XX Head-up display (HUD)
62300137 Cover for head-up display (HUD) Loose
62300139 Cover for head-up display (HUD) Unpleasant noises
62300141 Cover for head-up display (HUD) Poorly adapted/fitted
623001XX Cover for head-up display (HUD)
6230XXXX Head-up display (HUD)
62XXXXXX Instruments
63120213 Headlight housing Broken
63120232 Headlight housing Deformed / distorted / bent
63120237 Headlight housing Loose
63120241 Headlight housing Poorly adapted/fitted
63120248 Headlight housing Leaking
63120279 Headlight housing incorrect connection /contact
631202XX Headlight housing
63120634 Headlight adjustment Stiff to move
63120659 Headlight adjustment Too low / deep / slight
63120660 Headlight adjustment Too high
631206XX Headlight adjustment
63120814 Headlight vertical aim control, manual Occasional malfunction
63120815 Headlight vertical aim control, manual Permanent malfunction
631208XX Headlight vertical aim control, manual
63120914 Automatic/dynamic headlight vertical aim control Occasional malfunction
63120915 Automatic/dynamic headlight vertical aim control Permanent malfunction
631209XX Automatic/dynamic headlight vertical aim control
63121107 Headlight lens Cracked
63121150 Headlight lens Water ingress / condensate
63121154 Headlight lens Scratches, score marks
631211XX Headlight lens
63121207 Round headlight, low-beam insert Cracked
63121237 Round headlight, low-beam insert Loose
63121248 Round headlight, low-beam insert Leaking
63121275 Round headlight, low-beam insert corroded
631212XX Round headlight, low-beam insert
63121313 Headlight pop-up mechanism (E31) Broken
63121334 Headlight pop-up mechanism (E31) Stiff to move
631213XX Headlight pop-up mechanism (E31)
63121812 Parking light (lamp bulb) Permanent failure
631218XX Parking light (lamp bulb)
63121907 Round headlight, high-beam insert Cracked
63121937 Round headlight, high-beam insert Loose
63121948 Round headlight, high-beam insert Leaking
63121975 Round headlight, high-beam insert corroded
631219XX Round headlight, high-beam insert
63122011 Xenon headlight control unit Occasional failure
63122012 Xenon headlight control unit Permanent failure
631220XX Xenon headlight control unit
63122112 High beam halogen lamp bulb Permanent failure
631221XX High beam halogen lamp bulb
63122212 Low beam halogen lamp bulb Permanent failure
631222XX Low beam halogen lamp bulb
63122312 Xenon bulb Permanent failure
631223XX Xenon bulb
63122411 Xenon headlight shutter control (bi-xenon) Occasional failure
63122412 Xenon headlight shutter control (bi-xenon) Permanent failure
631224XX Xenon headlight shutter control (bi-xenon)
63122514 Automatic low beam Occasional malfunction
63122515 Automatic low beam Permanent malfunction
631225XX Automatic low beam
63122614 Adaptive cornering light (ALC) Occasional malfunction
63122615 Adaptive cornering light (ALC) Permanent malfunction
631226XX Adaptive cornering light (ALC)
63129086 E38 E39 Xenon headlight will not switch on
63129150 E46 Condensation in headlight(s)
63129411 E46 Xenon headlight sporadically inoperative
63129548 E39 E53 Misting (condensation) of lights
63129645 E31 Pop-up headlight not in position
6312XXXX Headlights
63130007 Front turn indicators Cracked
63130032 Front turn indicators Deformed / distorted / bent
63130037 Front turn indicators Loose
63130048 Front turn indicators Leaking
631300XX Front turn indicators
63130132 Additional turn indicator Deformed / distorted / bent
63130137 Additional turn indicator Loose
63130148 Additional turn indicator Leaking
631301XX Additional turn indicator
63130512 Turn signal indicator light, front (lamp bulb) Permanent failure
631305XX Turn signal indicator light, front (lamp bulb)
63130612 Auxiliary turn signal indicator light (lamp bulb) Permanent failure
631306XX Auxiliary turn signal indicator light (lamp bulb)
63130812 Direction indicator, front (neon tube) Permanent failure
631308XX Direction indicator, front (neon tube)
63130914 Ballast unit for neon direction indicator, front Occasional malfunction
63130915 Ballast unit for neon direction indicator, front Permanent malfunction
63130937 Ballast unit for neon direction indicator, front Loose
631309XX Ballast unit for neon direction indicator, front
63139037 E46/5 Front direction indicator light loose (retaining fixture)
63139122 E46/2/C Front direction indicator light loose (production fault)
6313XXXX Turn indicators
63140007 Side reflector Cracked
63140037 Side reflector Loose
63140048 Side reflector Leaking
63140075 Side reflector corroded
63140079 Side reflector incorrect connection /contact
631400XX Side reflector
63140212 Optical fibre conductor for side direction indicator lights Permanent failure
63140237 Optical fibre conductor for side direction indicator lights Loose
631402XX Optical fibre conductor for side direction indicator lights
63140312 Side spot light (light bulb) Permanent failure
631403XX Side spot light (light bulb)
6314XXXX Marker and side lights, reflector
63170007 Front fog lights Cracked
63170037 Front fog lights Loose
63170048 Front fog lights Leaking
63170075 Front fog lights corroded
631700XX Front fog lights
63170134 Front fog light adjustment Stiff to move
63170159 Front fog light adjustment Too low / deep / slight
63170160 Front fog light adjustment Too high
631701XX Front fog light adjustment
63170512 Fog light (halogen lamp bulb) Permanent failure
631705XX Fog light (halogen lamp bulb)
63179248 E46/2/C/5 Condensation in fog light
6317XXXX Fog lights and additional lights
63210007 Rear light Cracked
63210032 Rear light Deformed / distorted / bent
63210037 Rear light Loose
63210041 Rear light Poorly adapted/fitted
63210048 Rear light Leaking
63210079 Rear light incorrect connection /contact
632100XX Rear light
63210107 Reversing light (housing) Cracked
63210132 Reversing light (housing) Deformed / distorted / bent
63210137 Reversing light (housing) Loose
63210141 Reversing light (housing) Poorly adapted/fitted
63210148 Reversing light (housing) Leaking
63210179 Reversing light (housing) incorrect connection /contact
632101XX Reversing light (housing)
63210412 Rear fog light (light bulb / LED) Permanent failure
632104XX Rear fog light (light bulb / LED)
63210512 Tail light (light bulb / LED) Permanent failure
632105XX Tail light (light bulb / LED)
63210612 Brake light (light bulb / LED) Permanent failure
632106XX Brake light (light bulb / LED)
63210712 Reversing light (light bulb / LED) Permanent failure
632107XX Reversing light (light bulb / LED)
63210812 Rear direction indicator light (light bulb / LED) Permanent failure
632108XX Rear direction indicator light (light bulb / LED)
63210912 Tail light (neon tube) Permanent failure
632109XX Tail light (neon tube)
63211012 Brake light (neon tube) Permanent failure
632110XX Brake light (neon tube)
63211112 Direction indicator, rear (neon tube) Permanent failure
632111XX Direction indicator, rear (neon tube)
63211214 Ballast unit for neon tail light Occasional malfunction
63211215 Ballast unit for neon tail light Permanent malfunction
63211237 Ballast unit for neon tail light Loose
632112XX Ballast unit for neon tail light
63211312 Brake light (LED pc-board) Permanent failure
632113XX Brake light (LED pc-board)
63211407 Strip light, rear Cracked
63211432 Strip light, rear Deformed / distorted / bent
63211437 Strip light, rear Loose
63211441 Strip light, rear Poorly adapted/fitted
63211448 Strip light, rear Leaking
63211479 Strip light, rear incorrect connection /contact
632114XX Strip light, rear
63219048 E46/5 Tail light cluster fogged up
63219148 E52 Rear light leaking
6321XXXX Rear light cluster
63250007 Raised level brake light Cracked
63250032 Raised level brake light Deformed / distorted / bent
63250037 Raised level brake light Loose
63250048 Raised level brake light Leaking
632500XX Raised level brake light
63250512 Raised level brake light (bulb/LED) Permanent failure
632505XX Raised level brake light (bulb/LED)
6325XXXX Brake lights
63260007 Licence plate light Cracked
63260037 Licence plate light Loose
63260048 Licence plate light Leaking
632600XX Licence plate light
63260512 Licence plate light (lamp bulb) Permanent failure
632605XX Licence plate light (lamp bulb)
6326XXXX Licence plate light
63310012 Interior light Permanent failure
63310013 Interior light Broken
63310032 Interior light Deformed / distorted / bent
63310037 Interior light Loose
63310083 Interior light incorrect or no switching action
633100XX Interior light
63310112 Engine compartment light Permanent failure
63310113 Engine compartment light Broken
63310137 Engine compartment light Loose
63310148 Engine compartment light Leaking
633101XX Engine compartment light
63310212 Luggage compartment light Permanent failure
63310213 Luggage compartment light Broken
63310237 Luggage compartment light Loose
633102XX Luggage compartment light
63310312 Glovebox light Permanent failure
63310313 Glovebox light Broken
63310337 Glovebox light Loose
633103XX Glovebox light
63310512 Ashtray light Permanent failure
633105XX Ashtray light
63310612 Reading lights Permanent failure
63310613 Reading lights Broken
63310637 Reading lights Loose
63310683 Reading lights incorrect or no switching action
633106XX Reading lights
63310712 Footwell lights Permanent failure
63310713 Footwell lights Broken
63310737 Footwell lights Loose
633107XX Footwell lights
63311012 Make-up mirror lighting Permanent failure
63311013 Make-up mirror lighting Broken
63311032 Make-up mirror lighting Deformed / distorted / bent
63311037 Make-up mirror lighting Loose
63311083 Make-up mirror lighting incorrect or no switching action
633110XX Make-up mirror lighting
63311212 Door warning light Permanent failure
63311213 Door warning light Broken
63311237 Door warning light Loose
63311248 Door warning light Leaking
633112XX Door warning light
63311312 Door entry lighting Permanent failure
63311313 Door entry lighting Broken
63311337 Door entry lighting Loose
633113XX Door entry lighting
63311437 Entry aid, module - outer door handle lighting Loose
63311479 Entry aid, module - outer door handle lighting incorrect connection /contact
633114XX Entry aid, module - outer door handle lighting
63311512 Entry aid, lamp bulb Permanent failure
633115XX Entry aid, lamp bulb
63311637 Entry aid, light guide Loose
633116XX Entry aid, light guide
63311737 Entry aid, light exit Loose
633117XX Entry aid, light exit
63311812 Loading light in tailgate Permanent failure
63311813 Loading light in tailgate Broken
63311837 Loading light in tailgate Loose
633118XX Loading light in tailgate
63311914 Door armrest light (E65/E66) Occasional malfunction
63311915 Door armrest light (E65/E66) Permanent malfunction
63311941 Door armrest light (E65/E66) Poorly adapted/fitted
633119XX Door armrest light (E65/E66)
63312012 On-board torch Permanent failure
63312079 On-board torch incorrect connection /contact
633120XX On-board torch
63312112 Inner door opener lighting, LED socket Permanent failure
63312113 Inner door opener lighting, LED socket Broken
633121XX Inner door opener lighting, LED socket
63312214 C-pillar lights (LED module) Occasional malfunction
63312215 C-pillar lights (LED module) Permanent malfunction
63312237 C-pillar lights (LED module) Loose
633122XX C-pillar lights (LED module)
63312312 Inner door handle lights (X5) Permanent failure
63312337 Inner door handle lights (X5) Loose
633123XX Inner door handle lights (X5)
6331XXXX Interior lights
63XXXXXX Lights
64000111 Heating operation Occasional failure
64000112 Heating operation Permanent failure
64000117 Heating operation Odour
64000139 Heating operation Unpleasant noises
640001XX Heating operation
64000211 Heating power, defrosting windscreen and side windows Occasional failure
64000212 Heating power, defrosting windscreen and side windows Permanent failure
64000245 Heating power, defrosting windscreen and side windows Not controllable/adjustable
64000273 Heating power, defrosting windscreen and side windows too cold
64000274 Heating power, defrosting windscreen and side windows too hot
640002XX Heating power, defrosting windscreen and side windows
64000311 Heating power, footwell on driver's side Occasional failure
64000312 Heating power, footwell on driver's side Permanent failure
64000345 Heating power, footwell on driver's side Not controllable/adjustable
64000373 Heating power, footwell on driver's side too cold
64000374 Heating power, footwell on driver's side too hot
640003XX Heating power, footwell on driver's side
64000411 Heating power, footwell on passenger's side Occasional failure
64000412 Heating power, footwell on passenger's side Permanent failure
64000445 Heating power, footwell on passenger's side Not controllable/adjustable
64000473 Heating power, footwell on passenger's side too cold
64000474 Heating power, footwell on passenger's side too hot
640004XX Heating power, footwell on passenger's side
64000511 Heating power, rear compartment Occasional failure
64000512 Heating power, rear compartment Permanent failure
64000545 Heating power, rear compartment Not controllable/adjustable
64000573 Heating power, rear compartment too cold
64000574 Heating power, rear compartment too hot
640005XX Heating power, rear compartment
64000611 Heating power, dashboard in centre grill Occasional failure
64000612 Heating power, dashboard in centre grill Permanent failure
64000645 Heating power, dashboard in centre grill Not controllable/adjustable
64000673 Heating power, dashboard in centre grill too cold
64000674 Heating power, dashboard in centre grill too hot
640006XX Heating power, dashboard in centre grill
64000711 Heating power, dashboard outer grille on driver's side Occasional failure
64000712 Heating power, dashboard outer grille on driver's side Permanent failure
64000745 Heating power, dashboard outer grille on driver's side Not controllable/adjustable
64000773 Heating power, dashboard outer grille on driver's side too cold
64000774 Heating power, dashboard outer grille on driver's side too hot
640007XX Heating power, dashboard outer grille on driver's side
64000811 Heating power, dashboard outer grille on passenger's side Occasional failure
64000812 Heating power, dashboard outer grille on passenger's side Permanent failure
64000845 Heating power, dashboard outer grille on passenger's side Not controllable/adjustable
64000873 Heating power, dashboard outer grille on passenger's side too cold
64000874 Heating power, dashboard outer grille on passenger's side too hot
640008XX Heating power, dashboard outer grille on passenger's side
64003111 Cooling operation Occasional failure
64003112 Cooling operation Permanent failure
64003117 Cooling operation Odour
64003139 Cooling operation Unpleasant noises
640031XX Cooling operation
64003311 Cooling power, footwell on driver's side Occasional failure
64003312 Cooling power, footwell on driver's side Permanent failure
64003345 Cooling power, footwell on driver's side Not controllable/adjustable
64003373 Cooling power, footwell on driver's side too cold
64003374 Cooling power, footwell on driver's side too hot
640033XX Cooling power, footwell on driver's side
64003411 Cooling power, footwell on passenger's side Occasional failure
64003412 Cooling power, footwell on passenger's side Permanent failure
64003445 Cooling power, footwell on passenger's side Not controllable/adjustable
64003473 Cooling power, footwell on passenger's side too cold
64003474 Cooling power, footwell on passenger's side too hot
640034XX Cooling power, footwell on passenger's side
64003511 Cooling power, rear compartment Occasional failure
64003512 Cooling power, rear compartment Permanent failure
64003545 Cooling power, rear compartment Not controllable/adjustable
64003573 Cooling power, rear compartment too cold
64003574 Cooling power, rear compartment too hot
640035XX Cooling power, rear compartment
64003611 Cooling power, dashboard in centre grill Occasional failure
64003612 Cooling power, dashboard in centre grill Permanent failure
64003645 Cooling power, dashboard in centre grill Not controllable/adjustable
64003673 Cooling power, dashboard in centre grill too cold
64003674 Cooling power, dashboard in centre grill too hot
640036XX Cooling power, dashboard in centre grill
64003711 Cooling power, dashboard outer grille on driver's side Occasional failure
64003712 Cooling power, dashboard outer grille on driver's side Permanent failure
64003745 Cooling power, dashboard outer grille on driver's side Not controllable/adjustable
64003773 Cooling power, dashboard outer grille on driver's side too cold
64003774 Cooling power, dashboard outer grille on driver's side too hot
640037XX Cooling power, dashboard outer grille on driver's side
64003811 Cooling power, dashboard outer grille on passenger's side Occasional failure
64003812 Cooling power, dashboard outer grille on passenger's side Permanent failure
64003845 Cooling power, dashboard outer grille on passenger's side Not controllable/adjustable
64003873 Cooling power, dashboard outer grille on passenger's side too cold
64003874 Cooling power, dashboard outer grille on passenger's side too hot
640038XX Cooling power, dashboard outer grille on passenger's side
64006111 Fan control Occasional failure
64006112 Fan control Permanent failure
64006145 Fan control Not controllable/adjustable
640061XX Fan control
64006211 Recirculating mode Occasional failure
64006212 Recirculating mode Permanent failure
64006239 Recirculating mode Unpleasant noises
640062XX Recirculating mode
64009274 E46 Overheating at temperature below 0°C (instrument cluster software error)
6400XXXX Heating and cooling capacity (symptom defect codes)
64110037 Heater housing Loose
64110048 Heater housing Leaking
641100XX Heater housing
64110112 Heater / heat exchanger (incl. PTC) Permanent failure
64110117 Heater / heat exchanger (incl. PTC) Odour
64110148 Heater / heat exchanger (incl. PTC) Leaking
64110176 Heater / heat exchanger (incl. PTC) dirty / blocked
64110179 Heater / heat exchanger (incl. PTC) incorrect connection /contact
64110180 Heater / heat exchanger (incl. PTC) short circuit
641101XX Heater / heat exchanger (incl. PTC)
64110329 Temperature control flap, front Sticking/jammed
64110337 Temperature control flap, front Loose
64110339 Temperature control flap, front Unpleasant noises
64110340 Temperature control flap, front Poorly adjusted / outside tolerance
641103XX Temperature control flap, front
64110413 Rotary temperature switch Broken
64110434 Rotary temperature switch Stiff to move
64110465 Rotary temperature switch Does not lock into position
64110479 Rotary temperature switch incorrect connection /contact
641104XX Rotary temperature switch
64110501 Bowden cables, heater operation Cracked / broken / torn off
64110529 Bowden cables, heater operation Sticking/jammed
64110534 Bowden cables, heater operation Stiff to move
64110537 Bowden cables, heater operation Loose
64110540 Bowden cables, heater operation Poorly adjusted / outside tolerance
641105XX Bowden cables, heater operation
64111013 Air volume rotary control switch Broken
64111034 Air volume rotary control switch Stiff to move
64111065 Air volume rotary control switch Does not lock into position
64111079 Air volume rotary control switch incorrect connection /contact
64111080 Air volume rotary control switch short circuit
641110XX Air volume rotary control switch
64111129 Vacuum hose for heater and air conditioning Sticking/jammed
64111137 Vacuum hose for heater and air conditioning Loose
64111148 Vacuum hose for heater and air conditioning Leaking
641111XX Vacuum hose for heater and air conditioning
64111279 Blower resistor incorrect connection /contact
64111280 Blower resistor short circuit
64111281 Blower resistor interruption
641112XX Blower resistor
64111413 Air distribution controls Broken
64111434 Air distribution controls Stiff to move
64111440 Air distribution controls Poorly adjusted / outside tolerance
641114XX Air distribution controls
64111529 Defroster flap, front Sticking/jammed
64111537 Defroster flap, front Loose
64111539 Defroster flap, front Unpleasant noises
64111540 Defroster flap, front Poorly adjusted / outside tolerance
641115XX Defroster flap, front
64111629 Fresh air flap, front Sticking/jammed
64111637 Fresh air flap, front Loose
64111639 Fresh air flap, front Unpleasant noises
64111640 Fresh air flap, front Poorly adjusted / outside tolerance
641116XX Fresh air flap, front
64111729 Footwell flaps, front Sticking/jammed
64111737 Footwell flaps, front Loose
64111739 Footwell flaps, front Unpleasant noises
64111740 Footwell flaps, front Poorly adjusted / outside tolerance
641117XX Footwell flaps, front
64111829 Rear compartment flap, front Sticking/jammed
64111837 Rear compartment flap, front Loose
64111839 Rear compartment flap, front Unpleasant noises
64111840 Rear compartment flap, front Poorly adjusted / outside tolerance
641118XX Rear compartment flap, front
64112029 Recirculating air flap, front Sticking/jammed
64112037 Recirculating air flap, front Loose
64112039 Recirculating air flap, front Unpleasant noises
64112040 Recirculating air flap, front Poorly adjusted / outside tolerance
641120XX Recirculating air flap, front
64112214 Seat heating Occasional malfunction
64112215 Seat heating Permanent malfunction
64112266 Seat heating No effect
64112273 Seat heating too cold
64112274 Seat heating too hot
641122XX Seat heating
64112302 Heating/air conditioning control unit, front Software error / internal device fault
64112314 Heating/air conditioning control unit, front Occasional malfunction
64112315 Heating/air conditioning control unit, front Permanent malfunction
641123XX Heating/air conditioning control unit, front
64112711 Blower output s***e, front Occasional failure
64112712 Blower output s***e, front Permanent failure
64112779 Blower output s***e, front incorrect connection /contact
64112780 Blower output s***e, front short circuit
641127XX Blower output s***e, front
64113079 Temperature sensor, interior incorrect connection /contact
64113080 Temperature sensor, interior short circuit
641130XX Temperature sensor, interior
64113332 Moisture condensate drain hose on air conditioning Deformed / distorted / bent
64113337 Moisture condensate drain hose on air conditioning Loose
641133XX Moisture condensate drain hose on air conditioning
64113401 Water valve Cracked / broken / torn off
64113414 Water valve Occasional malfunction
64113415 Water valve Permanent malfunction
64113439 Water valve Unpleasant noises
64113448 Water valve Leaking
64113479 Water valve incorrect connection /contact
641134XX Water valve
64113512 Auxiliary water pump Permanent failure
64113539 Auxiliary water pump Unpleasant noises
64113548 Auxiliary water pump Leaking
64113579 Auxiliary water pump incorrect connection /contact
641135XX Auxiliary water pump
64113914 Interior sensor blower Occasional malfunction
64113915 Interior sensor blower Permanent malfunction
64113939 Interior sensor blower Unpleasant noises
641139XX Interior sensor blower
64114029 Mixing flaps, front Sticking/jammed
64114037 Mixing flaps, front Loose
64114039 Mixing flaps, front Unpleasant noises
64114040 Mixing flaps, front Poorly adjusted / outside tolerance
641140XX Mixing flaps, front
64114129 Ventilation flaps, front Sticking/jammed
64114137 Ventilation flaps, front Loose
64114139 Ventilation flaps, front Unpleasant noises
64114140 Ventilation flaps, front Poorly adjusted / outside tolerance
641141XX Ventilation flaps, front
64114215 Sensor for automatic recirculated air control (AUC) Permanent malfunction
64114237 Sensor for automatic recirculated air control (AUC) Loose
641142XX Sensor for automatic recirculated air control (AUC)
64114312 Control unit for automatic recirculated air control (AUC) Permanent failure
64114314 Control unit for automatic recirculated air control (AUC) Occasional malfunction
641143XX Control unit for automatic recirculated air control (AUC)
64114411 Switch for automatic recirculated air control (AUC) Occasional failure
64114412 Switch for automatic recirculated air control (AUC) Permanent failure
64114437 Switch for automatic recirculated air control (AUC) Loose
64114486 Switch for automatic recirculated air control (AUC) does not light up
641144XX Switch for automatic recirculated air control (AUC)
64114514 Independent air conditioning remote control (transmitter/receiver) Occasional malfunction
64114515 Independent air conditioning remote control (transmitter/receiver) Permanent malfunction
641145XX Independent air conditioning remote control (transmitter/receiver)
64114611 Blower output s***e, rear air conditioner Occasional failure
64114612 Blower output s***e, rear air conditioner Permanent failure
64114679 Blower output s***e, rear air conditioner incorrect connection /contact
64114680 Blower output s***e, rear air conditioner short circuit
641146XX Blower output s***e, rear air conditioner
64114702 Operating unit/control unit for rear air conditioner Software error / internal device fault
64114714 Operating unit/control unit for rear air conditioner Occasional malfunction
64114715 Operating unit/control unit for rear air conditioner Permanent malfunction
641147XX Operating unit/control unit for rear air conditioner
64114814 Blower, rear air conditioner Occasional malfunction
64114815 Blower, rear air conditioner Permanent malfunction
64114839 Blower, rear air conditioner Unpleasant noises
641148XX Blower, rear air conditioner
64114914 Condensation sensor Occasional malfunction
64114915 Condensation sensor Permanent malfunction
64114979 Condensation sensor incorrect connection /contact
641149XX Condensation sensor
64116314 Switches/buttons heating operating unit and heater/air conditioner, front Occasional malfunction
64116315 Switches/buttons heating operating unit and heater/air conditioner, front Permanent malfunction
64116337 Switches/buttons heating operating unit and heater/air conditioner, front Loose
64116354 Switches/buttons heating operating unit and heater/air conditioner, front Scratches, score marks
64116386 Switches/buttons heating operating unit and heater/air conditioner, front does not light up
641163XX Switches/buttons heating operating unit and heater/air conditioner, front
64116414 Heating operating unit, front Occasional malfunction
64116415 Heating operating unit, front Permanent malfunction
64116486 Heating operating unit, front does not light up
641164XX Heating operating unit, front
64116586 Automatic air conditioning control panel, front does not light up
641165XX Automatic air conditioning control panel, front
64116618 Automatic air conditioner display Incorrect/incomplete reading
64116686 Automatic air conditioner display does not light up
641166XX Automatic air conditioner display
64116714 Temperature sensor, heater core/heat exchanger Occasional malfunction
64116715 Temperature sensor, heater core/heat exchanger Permanent malfunction
64116779 Temperature sensor, heater core/heat exchanger incorrect connection /contact
64116780 Temperature sensor, heater core/heat exchanger short circuit
641167XX Temperature sensor, heater core/heat exchanger
64118011 Rear compartment heater/air conditioner Occasional failure
64118012 Rear compartment heater/air conditioner Permanent failure
64118039 Rear compartment heater/air conditioner Unpleasant noises
64118045 Rear compartment heater/air conditioner Not controllable/adjustable
641180XX Rear compartment heater/air conditioner
64118113 Rear compartment heater/air conditioner operation Broken
64118134 Rear compartment heater/air conditioner operation Stiff to move
64118154 Rear compartment heater/air conditioner operation Scratches, score marks
641181XX Rear compartment heater/air conditioner operation
64118213 Rear compartment blower operation Broken
64118234 Rear compartment blower operation Stiff to move
64118245 Rear compartment blower operation Not controllable/adjustable
641182XX Rear compartment blower operation
64118315 Solar sensor for air conditioning system Permanent malfunction
64118337 Solar sensor for air conditioning system Loose
641183XX Solar sensor for air conditioning system
64118411 Switch for air conditioning/recirculated air (Z3) Occasional failure
64118412 Switch for air conditioning/recirculated air (Z3) Permanent failure
64118437 Switch for air conditioning/recirculated air (Z3) Loose
64118486 Switch for air conditioning/recirculated air (Z3) does not light up
641184XX Switch for air conditioning/recirculated air (Z3)
64119011 E46 (With SA 534) No air outlet in A/C mode - faulty temperature sensor
64119166 E39 M47 M57 restricted use of residual heat
64119312 E39 E53 IHKR blower malfunction
64119483 E46 (with SA 530) Ventilation nozzles, air outlet not correct
64119811 E46 E39 E53 Sporadic failure of heating/air conditioning blower
6411XXXX Heater with actuation, seat heating
64120014 Independent park heating/auxiliary heater, independent ventilation Occasional malfunction
64120015 Independent park heating/auxiliary heater, independent ventilation Permanent malfunction
64120017 Independent park heating/auxiliary heater, independent ventilation Odour
64120039 Independent park heating/auxiliary heater, independent ventilation Unpleasant noises
64120045 Independent park heating/auxiliary heater, independent ventilation Not controllable/adjustable
64120048 Independent park heating/auxiliary heater, independent ventilation Leaking
64120072 Independent park heating/auxiliary heater, independent ventilation Poorly bled
64120073 Independent park heating/auxiliary heater, independent ventilation too cold
64120074 Independent park heating/auxiliary heater, independent ventilation too hot
641200XX Independent park heating/auxiliary heater, independent ventilation
64120114 Fuel pump for independent park heating Occasional malfunction
64120115 Fuel pump for independent park heating Permanent malfunction
64120148 Fuel pump for independent park heating Leaking
641201XX Fuel pump for independent park heating
64120202 Control unit for independent park heating Software error / internal device fault
64120214 Control unit for independent park heating Occasional malfunction
64120215 Control unit for independent park heating Permanent malfunction
64120279 Control unit for independent park heating incorrect connection /contact
641202XX Control unit for independent park heating
64120312 Water pump for independent park heating Permanent failure
64120339 Water pump for independent park heating Unpleasant noises
641203XX Water pump for independent park heating
64120412 Flame monitor for independent park heating Permanent failure
641204XX Flame monitor for independent park heating
64120512 Water temperature sensor for independent park heating Permanent failure
641205XX Water temperature sensor for independent park heating
64120612 Temperature limiter for independent park heating Permanent failure
641206XX Temperature limiter for independent park heating
64120712 Glow plug/pin for independent park heating Permanent failure
641207XX Glow plug/pin for independent park heating
64120851 Burner head for independent park heating Burnt/burnt through
641208XX Burner head for independent park heating
64120914 Combustion air blower for independent park heating Occasional malfunction
64120915 Combustion air blower for independent park heating Permanent malfunction
64120939 Combustion air blower for independent park heating Unpleasant noises
64120979 Combustion air blower for independent park heating incorrect connection /contact
641209XX Combustion air blower for independent park heating
64121012 Independent heating silencer (incl. exhaust pipe) Permanent failure
641210XX Independent heating silencer (incl. exhaust pipe)
64121248 Fuel line for independent park heating Leaking
641212XX Fuel line for independent park heating
64121348 Water hose for independent park heating Leaking
641213XX Water hose for independent park heating
64121414 Independent heating/air conditioning remote control (transmitter/receiver) Occasional malfunction
64121415 Independent heating/air conditioning remote control (transmitter/receiver) Permanent malfunction
641214XX Independent heating/air conditioning remote control (transmitter/receiver)
64121637 Independent park heating valve unit with support bracket Loose
64121639 Independent park heating valve unit with support bracket Unpleasant noises
641216XX Independent park heating valve unit with support bracket
64121729 Independent park heating changeover valve Sticking/jammed
64121739 Independent park heating changeover valve Unpleasant noises
641217XX Independent park heating changeover valve
64121829 Independent park heating shut-off valve Sticking/jammed
64121839 Independent park heating shut-off valve Unpleasant noises
641218XX Independent park heating shut-off valve
64121911 Electric through-flow heater (EDH) Occasional failure
64121912 Electric through-flow heater (EDH) Permanent failure
64121948 Electric through-flow heater (EDH) Leaking
64121979 Electric through-flow heater (EDH) incorrect connection /contact
641219XX Electric through-flow heater (EDH)
64122037 Intake silencer, independent heating Loose
64122048 Intake silencer, independent heating Leaking
641220XX Intake silencer, independent heating
64129040 E38 E39 M47 M57 M67 Heavy smoke emission from auxiliary heater
6412XXXX Auxiliary heater with controls
64210037 Heater, coolant hoses Loose
64210048 Heater, coolant hoses Leaking
642100XX Heater, coolant hoses
64210413 Cold air distributor Broken
64210439 Cold air distributor Unpleasant noises
642104XX Cold air distributor
6421XXXX Air and water lines
64220041 Defrost outlet nozzles Poorly adapted/fitted
642200XX Defrost outlet nozzles
64220514 Rear compartment mixing air control Occasional malfunction
64220515 Rear compartment mixing air control Permanent malfunction
64220531 Rear compartment mixing air control Excessive play
64220534 Rear compartment mixing air control Stiff to move
64220579 Rear compartment mixing air control incorrect connection /contact
64220586 Rear compartment mixing air control does not light up
642205XX Rear compartment mixing air control
64220613 Fresh air grille Broken
64220631 Fresh air grille Excessive play
64220634 Fresh air grille Stiff to move
64220639 Fresh air grille Unpleasant noises
64220648 Fresh air grille Leaking
64220678 Fresh air grille poor surface finish
642206XX Fresh air grille
64220714 Mixing air control, front Occasional malfunction
64220715 Mixing air control, front Permanent malfunction
64220731 Mixing air control, front Excessive play
64220734 Mixing air control, front Stiff to move
64220779 Mixing air control, front incorrect connection /contact
64220786 Mixing air control, front does not light up
642207XX Mixing air control, front
64220829 Ventilation grille (incl. knurled wheel) hinged box, front centre armrest Sticking/jammed
64220837 Ventilation grille (incl. knurled wheel) hinged box, front centre armrest Loose
642208XX Ventilation grille (incl. knurled wheel) hinged box, front centre armrest
64220911 Actuator, defroster nozzles Occasional failure
64220912 Actuator, defroster nozzles Permanent failure
64220939 Actuator, defroster nozzles Unpleasant noises
642209XX Actuator, defroster nozzles
64221013 Rear compartment heater / air conditioner fresh air grille Broken
64221034 Rear compartment heater / air conditioner fresh air grille Stiff to move
64221048 Rear compartment heater / air conditioner fresh air grille Leaking
64221078 Rear compartment heater / air conditioner fresh air grille poor surface finish
642210XX Rear compartment heater / air conditioner fresh air grille
64221111 Active rear ventilation (in luggage compartment) Occasional failure
64221112 Active rear ventilation (in luggage compartment) Permanent failure
64221139 Active rear ventilation (in luggage compartment) Unpleasant noises
642211XX Active rear ventilation (in luggage compartment)
64229040 E38 Unequal temperature distribution from centre ventilation grille
6422XXXX Nozzles and outlet pipes
64230111 Fan for rear window (convertible) Occasional failure
64230112 Fan for rear window (convertible) Permanent failure
64230137 Fan for rear window (convertible) Loose
64230139 Fan for rear window (convertible) Unpleasant noises
64230175 Fan for rear window (convertible) corroded
642301XX Fan for rear window (convertible)
6423XXXX Fan for rear window in convertible
64300017 External air guide (clean air channel) Odour
64300037 External air guide (clean air channel) Loose
64300039 External air guide (clean air channel) Unpleasant noises
64300048 External air guide (clean air channel) Leaking
643000XX External air guide (clean air channel)
6430XXXX Air cleaning systems for vehicle interior
64310213 Microfilter housing Broken
64310237 Microfilter housing Loose
64310248 Microfilter housing Leaking
643102XX Microfilter housing
6431XXXX Particulate filter
64510015 Air conditioning evaporator, front Permanent malfunction
64510017 Air conditioning evaporator, front Odour
64510048 Air conditioning evaporator, front Leaking
64510078 Air conditioning evaporator, front poor surface finish
645100XX Air conditioning evaporator, front
64510514 Cool box (multifunction armrest, rear) Occasional malfunction
64510515 Cool box (multifunction armrest, rear) Permanent malfunction
64510539 Cool box (multifunction armrest, rear) Unpleasant noises
64510579 Cool box (multifunction armrest, rear) incorrect connection /contact
645105XX Cool box (multifunction armrest, rear)
64511212 Expansion valve Permanent failure
64511239 Expansion valve Unpleasant noises
64511248 Expansion valve Leaking
64511276 Expansion valve dirty / blocked
645112XX Expansion valve
64511312 Evaporator temperature sensor, front Permanent failure
64511379 Evaporator temperature sensor, front incorrect connection /contact
64511380 Evaporator temperature sensor, front short circuit
645113XX Evaporator temperature sensor, front
64511412 Evaporator temperature sensor, rear air conditioner Permanent failure
64511479 Evaporator temperature sensor, rear air conditioner incorrect connection /contact
64511480 Evaporator temperature sensor, rear air conditioner short circuit
645114XX Evaporator temperature sensor, rear air conditioner
64511515 Evaporator, rear air conditioner Permanent malfunction
64511517 Evaporator, rear air conditioner Odour
64511548 Evaporator, rear air conditioner Leaking
64511578 Evaporator, rear air conditioner poor surface finish
645115XX Evaporator, rear air conditioner
6451XXXX Air conditioner (evaporator), control elements
64520014 Air conditioning compressor Occasional malfunction
64520025 Air conditioning compressor Rough running
64520037 Air conditioning compressor Loose
64520048 Air conditioning compressor Leaking
645200XX Air conditioning compressor
64520114 Air conditioner, magnetic clutch with belt pulley Occasional malfunction
64520115 Air conditioner, magnetic clutch with belt pulley Permanent malfunction
64520137 Air conditioner, magnetic clutch with belt pulley Loose
64520151 Air conditioner, magnetic clutch with belt pulley Burnt/burnt through
64520179 Air conditioner, magnetic clutch with belt pulley incorrect connection /contact
64520180 Air conditioner, magnetic clutch with belt pulley short circuit
645201XX Air conditioner, magnetic clutch with belt pulley
64520579 Compressor overheat protection switch incorrect connection /contact
64520580 Compressor overheat protection switch short circuit
64520583 Compressor overheat protection switch incorrect or no switching action
645205XX Compressor overheat protection switch
6452XXXX Compressor
64530013 Air conditioning pipes Broken
64530037 Air conditioning pipes Loose
64530039 Air conditioning pipes Unpleasant noises
64530048 Air conditioning pipes Leaking
645300XX Air conditioning pipes
64530101 Air conditioning hoses Cracked / broken / torn off
64530137 Air conditioning hoses Loose
64530139 Air conditioning hoses Unpleasant noises
64530148 Air conditioning hoses Leaking
645301XX Air conditioning hoses
64530201 Air conditioning condenser Cracked / broken / torn off
64530215 Air conditioning condenser Permanent malfunction
64530248 Air conditioning condenser Leaking
64530275 Air conditioning condenser corroded
645302XX Air conditioning condenser
64530315 Dehumidifier flask Permanent malfunction
64530337 Dehumidifier flask Loose
64530348 Dehumidifier flask Leaking
645303XX Dehumidifier flask
64530579 Low-pressure switch incorrect connection /contact
64530580 Low-pressure switch short circuit
64530583 Low-pressure switch incorrect or no switching action
645305XX Low-pressure switch
64530679 Medium-pressure switch incorrect connection /contact
64530680 Medium-pressure switch short circuit
64530683 Medium-pressure switch incorrect or no switching action
645306XX Medium-pressure switch
64530779 High-pressure switch incorrect connection /contact
64530780 High-pressure switch short circuit
64530783 High-pressure switch incorrect or no switching action
645307XX High-pressure switch
64530848 Fuel cooling connection Leaking
645308XX Fuel cooling connection
64530948 Pressure switch/pressure sensor Leaking
64530979 Pressure switch/pressure sensor incorrect connection /contact
64530980 Pressure switch/pressure sensor short circuit
64530983 Pressure switch/pressure sensor incorrect or no switching action
645309XX Pressure switch/pressure sensor
64531012 Fuse/safety valve for dehumidifier flask Permanent failure
64531048 Fuse/safety valve for dehumidifier flask Leaking
645310XX Fuse/safety valve for dehumidifier flask
64539048 E36 (automatic transmission) air conditioning condenser leaking
64539139 E46 Drumming/humming noise when air conditioning active
6453XXXX Condenser and drier with lines
64540114 Electric auxiliary fan (pressure fan) Occasional malfunction
64540115 Electric auxiliary fan (pressure fan) Permanent malfunction
64540139 Electric auxiliary fan (pressure fan) Unpleasant noises
