و لكن لا تنسى أنه فى الرابط الثانى المذكور فى المداخلة ، هناك تحذير من إستخدام تلك الطريقة و ها هو ما ذك كتعليق على المداخلة
"Not recommended! Mothballs are often paradichlorobenzene, not
naphthalene. The former would form HCl and oxychlorides upon combustion
which would be very corrosive to the engine cylinders. Even if it is
naphthalene, the ignition system whether old fashioned carburetor or new
fashioned solid state, is not "expecting" an aromatic hydrocarbon. The
fuel/air combustion mix is going to be very smokey and possibly foul up the
engine, the fuel injectors (if present), and make a mess of you catalytic
converter. Sounds like a good way to mess up an engine to me.
Vince Calder
لذا وجب التنويه
