كويس جدا السعر دا على فكره
بس انا كنت عايز اعرف منك هما العربيات موديل كام بالضبط و سنه كام ويعملو كام لو حب الواحد يشتري
العربيه الاول.عشان بس الصوره تبقى واضحه ليا يا محمد بك
بص على فكره بجد انت لو جربت عربيه دفع خلفي قويه اعلى من (200 - 250 hp) رأيك هيختلف كتييييييييييير لانها متعه مختلفه عن الامامي خاااااااااالص
فعلا عندك حق انا شخصيا بحترم ال awd بعين الrwd
ربنا يخليك
:Zb_sor1[1]:
A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
But Could you illustrate more its still not clear that how can you do it that way
The main advantage of a limited slip differential is shown by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely—the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, and thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use, such as driving in mud, off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the angular velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some traction available on at least one of the wheels.
How could you name that "Having FUN
this just solving problems of fwd as I understand from the quotation
Am I Right
يا جماعة انا احتج :rfds:
الاوبل فكترا برده ليها طعمها
انا عملت فيها شوية تعديلات بسيطه
تعديلات فى أوبل فكترا موديل 2000
ويا سلام لو ركبت عليها البدى كيت والجنوط دى
http://www3.0zz0.com/2009/01/26/09/930671583.jpg
http://www3.0zz0.com/2009/01/26/09/437767915.jpg
كده تبقى عربيه وهمية :36_9_4:
