Hi ...talkin about the air filter you can go with k&n for carb engines....it will add more noisy sound and a little HP increase and for the sparks plugs use the manual recommended type anything above will be a waste of money and you are asking about a sport suspension system for a lada !!! it will have a negative side more than positive one that you will feel more unstable at lower speeds and as i know lada is not that fast car ...only in case you speed more
than 120 kph and you feel problems
THERE IS NO SPORT CLUTCH FOR LADA 2107
