Dear Respected
Regarding the above mentioned subject please be informed that this issue is due to changing the dipstick, while the engine is the same, the oil filter & the oil pan are also the same, so if you put 3.6liters in your 2008 or 2009 vehicle and measured the oil level with 2007 dipstick you will find it normal, and this case have been finalized with Dr. Moaaz Al Sharabassy over the phone and in his last visit; if you want more details
And as for the invoicing, you will pay only for the quantity you replaced (ex. 3.1, 3.2, ...) and this will be the first time to decimate oil charging in any service center, but if the quantity exceeded3.5 you will be charged for 4 liters and take the remaining oil
Kind regards
Kind regards
