انا بسال السؤال ده لان احد الزملاء قالى معلومة غريبة وهى ان باور الالنترا بيفصل عند 140 وده اعتقد ان فيه خطر كبير وبرضه اعتقد ان الكلام ده مش مظبوط :dontudear:فاتمنى الرد
ايوة يااخونا انا كمان سمعت نفس الكلام ممكن من الناس اللى عندها الالنترا بتقولنا صحه الكلام ده ولا ديه اشاعات على العربيه
I've seen a lot of non sense in this subject before... I guess the Elantra manual should be the final say
Electronic power steering
Power steering uses the motor to assist
you in steering the vehicle. If the engine
is off or if the power steering system
becomes inoperative, the vehicle may
still be steered, but it will require
increased steering effort.
The motor driven power steering is controlled
by power steering control unit
which sense the steering wheel torque,
steering wheel position and vehicle
speed to command the motor.
The steering wheel becomes heavier as
the vehicle’s speed increases and
becomes lighter as the vehicle’s speed
decreases for the better control of the
steering wheel.Should you notice any change in the
effort required to steer during normal
vehicle operation, have the power steering
checked by an authorized Hyundai
dealer.
✽ NOTICE
The following symptoms may occur during
normal vehicle operation:
• The EPS warning light does not illuminate.
• The steering wheel becomes heavier
after turning the ignition switch on.
This happens as the system performs
the EPS system diagnostics. When the
diagnostics is completed, the steering
wheel will return to its normal condition.
• Click noise may be heard from the
EPS relay after the ignition switch is
turned to the ON or LOCK position.
• Motor noise may be heard when the
vehicle is at a stop or at a low driving
speed.
• The steering effort can suddenly
increase, if the operation of EPS system
is stopped to prevent serious accidents
when the malfunction of EPS
system is detected by self-diagnosis.
Tilt steering
Tilt steering allows you to adjust the
steering wheel before you drive. You can
also raise it to give your legs more room
when you exit and enter the vehicle.
The steering wheel should be positioned
so that it is comfortable for you to drive,
while permitting you to see the instrument
panel warning lights and gauges.
انا سألت مرة كنت فى معرض سمير ريان وسألت عن الموضوع دة
وكانت الأجابة الألنترا الى تكيفها بكر بتفصل بعد 100
والى تكيفها تاتش مش بتفصل
انا مش شايف خطوره ولا مشكله ولا عيب ولا اى حاجة
المفروض اى باور بيتقل كل ما سرعه العربيه تزيد لغايه ما بيفصل تماما
ايه مشكلتكم لو كان بيفصل عن 140؟
هو انت وانت ماشى على 140 هتحتاج تلف الدركسيون قد ايه؟ عشان تبقى محتاج باور شغال معاك؟
اشاعااااااااااااااااااااا ااااااااااااااااااااااااا ااااااااااااااااااااااااا اااااااااات الباور شغال عادى بس بيتقل كل مالسرعة تزيد عشان مصلحتك
العربية ما واحد صاحبى و مش بيفصل خالص و اقل لمسة العربية بتستجيب و دة مش ظريف ومش عارف حكاية التكييف البكر و التاتش دى بس هوة عندة تاتش
لا ازاى مش خطورة طبعا خطورة ازاى اصلا باور كهربا ميفصلش علي السرعات العالية دا اكيد عيب طبعا
