تشكيلة حلوة خصوصا الريبسول
رقم العضوية : 40672
الصور, الموديلات دى منقولة من موقع هوندا ايجيبت يعنى انا مش جايب حاجة من دماغى
ويارب الموضوع يعجبكوا
CBR 1000RR
RepsoL
Engine Type Liquid-cooled inline-four
Displacement 998cc
Bore & Stroke 75mm x 56.5mm
Compression Ratio 12.2:1
Valve Train Chain-driven DOHC, 4 valves per cylinder
Fuel Delivery Dual Stage Fuel Injection
Transmission Close-ratio six-speed
Final Drive O-ring-sealed chain
Front Suspension 43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel
Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
Brakes Front dual 320mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
Seat Height 820mm (32.3 inches)
Wheelbase 1,402mm (55.2 inches)
Dry Weight tba
Fuel Capacity 18.2 litres
ColourRed/Black, Light Silver ....llic
ده الملك اللى شفته موجود لحد دلوقتى,
ياجماعة انا شوفت الrace دة وكان منقول على عربية نقل فى طريق مصر اسماعلية ,حاجة فوق الخيال وحجمه كبير عامل زى الحصان
بس كنت هاموت واسمع صوته فى التزويد
وبتمنى اشتريه
CBR 1000 RR
Displacement 998cc
Front Suspension 43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
Dry Weight tba
CBR 600RR
Displacement 599cc
Bore & Stroke 67mm x 42.5mm
Front Suspension 41mm inverted HMAS cartridge fork with full adjustability; 119mm (4.7 inches) travel Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 130mm (5.1 inches) travel Tires 120/70ZR - 17 radial front; 180/55ZR - 17 radial rear
Brakes Front dual 310mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
Wheelbase 1,368mm (53.8 inches)
Dry Weight 156.5 kg (345 pounds)
Fuel Capacity 18.1 litres
Colour
Black, Red/Black, Ultra Blue ....llic/Silver
Contact Them At
للاستفسار عن الاسعار
Motorcycles :
26th July st., Tersana shopping center ,
Mohandesseen , P.O.BOX 59(11511)
tel:
33448340
+(202)
Motorcycles:
19 Sultan Hussiesn St., Mahatit El Raml Alexandria
tel:+(203)
4851317 -4813743
Honda Hot Line:
19811
رقم العضوية : 27285
الاقامة : الكرة الأرضية
السيارة: -Cabrice-LTZ
السيارة[2]: ِAlfa156 seles-جيب جراند شيروكي
إِن يَنصُرْ.كُمُ اللَّـهُ فَلَا غَالِبَ لَكُمْ ۖ وَإِن يَخْذُلْكُمْ فَمَن ذَا الَّذِي يَنصُرُ.كُم مِّن بَعْدِهِ ۗ وَعَلَى اللَّـهِ فَلْيَتَوَكَّلِ الْمُؤْمِنُونَ ﴿160)
م/محمد
رقم العضوية : 26282
و الله جمدييييييييييييييييييييين موووووووووووووووووووووووو ووووووووووت
تشكر علي التشكيله
رقم العضوية : 41237
والله حجات جميلة ربنا يكتبهالنا بس انا عاوز اعرف انتا معجب بال rr اوى كدة ليه مع ان فى موديلات fireblade شكلها جاحد انا معايا 2004 و ماشاءالله صوت انقلاع طيارة فعلا
بس للامانة انا مجربتش ال ارار عشان احكم عليها بس احسن حاجة شايفها فى ال ارار ان الشكمان ورا عشان بعيد عنك فى الوقعة اللى فى الجناب بيكوى الرجلين و شكرا على المجهود
رقم العضوية : 27285
ده موتوسيكلي
م/محمد
رقم العضوية : 27285
م/محمد
رقم العضوية : 29966
الاقامة : اسكندريه
السيارة: HONDA CBR1000RR 2008
السيارة[2]: 318i BMW
دراجة بخارية: honda cbr1000rr 2008
تمام الجكمان اللى ورا فيه عيوب كتير
وانا جربت الاتنين
ومعايا الشكل الجديد
بايك مجنوووووووووووووووووووووو ن
رقم العضوية : 40927
الاقامة : الشرقية
السيارة: cbr 600 f4
السيارة[2]: افيو
دراجة بخارية: cbr 600 f4
الف شكر يا برنس على المجموعة الرائعة دى وعلى فكرة انا شفت لل cbr 1000 كذا فيديو حقيقى وهممممممممممممم .
رقم العضوية : 40672
شكرا يا جماعة انا لسة 18 سنه ولسة ربنا مكتبليش اسوق ريس لحد النهاردة وبأذن الله اول ما هاركب هاركب 600rr لانه وهمى بس احل مشاكلى مع اهلى
رقم العضوية : 37214
الاقامة : الكويت
السيارة: BMW 325 2004
السيارة[2]: BMW 528 1998
دراجة بخارية: suzuki gsxr 2008
ممكن تقولي ايه عيوب الشكمان لما يكون تحت الكرسي انا سألت اكتر من شخص وقالو مافيهوش اي مشكله والاخ otefa بيقول انه الموديلات الجديده اتغير وبقي الشكمان صغير وتحت وده غير صحيح متغير في الالف cc بس ولكن ال 600 c c زي ماهو من 2004 لغايه دلوقتي واكيد لو في حراره او بيعمل مشاكل كان غيرو مكانه
