النتائج 1 إلى 10 من 15
    الصورة الرمزية Hayabusa
    رقم العضوية : 40672
    الحالة : Hayabusa غير متواجد حالياً
    Thumbs up Honda Motorcycles (Racing) In Egypt - Facebook Twitter whatsapp انشر الموضوع فى :
    الصور, الموديلات دى منقولة من موقع هوندا ايجيبت يعنى انا مش جايب حاجة من دماغى
    ويارب الموضوع يعجبكوا
    CBR 1000RR
    RepsoL
    Engine Type Liquid-cooled inline-four
    Displacement 998cc
    Bore & Stroke 75mm x 56.5mm
    Compression Ratio 12.2:1
    Valve Train
    Chain-driven DOHC, 4 valves per cylinder
    Fuel Delivery Dual Stage Fuel Injection
    Transmission
    Close-ratio six-speed
    Final Drive O-ring-sealed chain
    Front Suspension
    43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel
    Rear Suspension
    Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
    Brakes
    Front dual 320mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
    Seat Height
    820mm (32.3 inches)
    Wheelbase
    1,402mm (55.2 inches)
    Dry Weight
    tba
    Fuel Capacity 18.2 litres
    ColourRed/Black, Light Silver ....llic
    ده الملك اللى شفته موجود لحد دلوقتى,
    ياجماعة انا شوفت الrace دة وكان منقول على عربية نقل فى طريق مصر اسماعلية ,حاجة فوق الخيال وحجمه كبير عامل زى الحصان
    بس كنت هاموت واسمع صوته فى التزويد
    وبتمنى اشتريه
    CBR 1000 RR
    Displacement 998cc
    Valve Train
    Transmission
    Front Suspension 43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
    Brakes
    Seat Height 820mm (32.3 inches)
    Wheelbase
    Dry Weight tba
    Fuel Capacity
    18.2 litres
    CBR 600RR
    Displacement 599cc
    Bore & Stroke
    67mm x 42.5mm
    Valve Train Chain-driven DOHC, 4 valves per cylinder
    Transmission
    Front Suspension
    41mm inverted HMAS cartridge fork with full adjustability; 119mm (4.7 inches) travel Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 130mm (5.1 inches) travel Tires 120/70ZR - 17 radial front; 180/55ZR - 17 radial rear
    Brakes
    Front dual 310mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
    Wheelbase
    1,368mm (53.8 inches)
    Dry Weight
    156.5 kg (345 pounds)
    Fuel Capacity
    18.1 litres
    Colour
    Black, Red/Black, Ultra Blue ....llic/Silver
    Contact Them At
    للاستفسار عن الاسعار
    Motorcycles :
    26th July st., Tersana shopping center ,
    Mohandesseen , P.O.BOX 59(11511)
    tel:
    33448340
    +(202)
    Motorcycles:
    19 Sultan Hussiesn St., Mahatit El Raml Alexandria
    tel:+(203)
    4851317 -4813743
    Honda Hot Line:
    19811
    الصورة الرمزية otefa
    رقم العضوية : 27285
    الاقامة : الكرة الأرضية
    السيارة: -Cabrice-LTZ
    السيارة[2]: ِAlfa156 seles-جيب جراند شيروكي
    الحالة : otefa غير متواجد حالياً
    تشكيلة حلوة خصوصا الريبسول
    إِن يَنصُرْ.كُمُ اللَّـهُ فَلَا غَالِبَ لَكُمْ ۖ وَإِن يَخْذُلْكُمْ فَمَن ذَا الَّذِي يَنصُرُ.كُم مِّن بَعْدِهِ ۗ وَعَلَى اللَّـهِ فَلْيَتَوَكَّلِ الْمُؤْمِنُونَ ﴿160)
    م/محمد
    الصورة الرمزية jasmido
    رقم العضوية : 26282
    الحالة : jasmido غير متواجد حالياً
    و الله جمدييييييييييييييييييييين موووووووووووووووووووووووو ووووووووووت
    تشكر علي التشكيله
    الصورة الرمزية volkswagen
    رقم العضوية : 41237
    الحالة : volkswagen غير متواجد حالياً
    والله حجات جميلة ربنا يكتبهالنا بس انا عاوز اعرف انتا معجب بال rr اوى كدة ليه مع ان فى موديلات fireblade شكلها جاحد انا معايا 2004 و ماشاءالله صوت انقلاع طيارة فعلا
    بس للامانة انا مجربتش ال ارار عشان احكم عليها بس احسن حاجة شايفها فى ال ارار ان الشكمان ورا عشان بعيد عنك فى الوقعة اللى فى الجناب بيكوى الرجلين و شكرا على المجهود
    رقم العضوية : 27285
    ده موتوسيكلي
    م/محمد
    رقم العضوية : 27285
    اقتباس المشاركة الأصلية كتبت بواسطة volkswagen مشاهدة المشاركة
    بس ياباشا استحمل بقي الحرارة الي جيالك من تحت الكرسي ده غير انه بيكل الدرج الي تحت الكرسي
    وعلي فكرة في موديلات 2008 رجعو تاني خلوه شكمان صغير في الجنب
    م/محمد
    الصورة الرمزية yascro
    رقم العضوية : 29966
    الاقامة : اسكندريه
    السيارة: HONDA CBR1000RR 2008
    السيارة[2]: 318i BMW
    دراجة بخارية: honda cbr1000rr 2008
    الحالة : yascro غير متواجد حالياً
    تمام الجكمان اللى ورا فيه عيوب كتير
    وانا جربت الاتنين
    ومعايا الشكل الجديد
    بايك مجنوووووووووووووووووووووو ن
    الصورة الرمزية attiaahmed
    رقم العضوية : 40927
    الاقامة : الشرقية
    السيارة: cbr 600 f4
    السيارة[2]: افيو
    دراجة بخارية: cbr 600 f4
    الحالة : attiaahmed غير متواجد حالياً
    الف شكر يا برنس على المجموعة الرائعة دى وعلى فكرة انا شفت لل cbr 1000 كذا فيديو حقيقى وهممممممممممممم .
    رقم العضوية : 40672
    شكرا يا جماعة انا لسة 18 سنه ولسة ربنا مكتبليش اسوق ريس لحد النهاردة وبأذن الله اول ما هاركب هاركب 600rr لانه وهمى بس احل مشاكلى مع اهلى
    الصورة الرمزية naser_56
    رقم العضوية : 37214
    الاقامة : الكويت
    السيارة: BMW 325 2004
    السيارة[2]: BMW 528 1998
    دراجة بخارية: suzuki gsxr 2008
    الحالة : naser_56 غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة yascro مشاهدة المشاركة
    وانا جربت الاتنين
    ومعايا الشكل الجديد
    ممكن تقولي ايه عيوب الشكمان لما يكون تحت الكرسي انا سألت اكتر من شخص وقالو مافيهوش اي مشكله والاخ otefa بيقول انه الموديلات الجديده اتغير وبقي الشكمان صغير وتحت وده غير صحيح متغير في الالف cc بس ولكن ال 600 c c زي ماهو من 2004 لغايه دلوقتي واكيد لو في حراره او بيعمل مشاكل كان غيرو مكانه
  1. vento motorcycles??
    بواسطة mahmoudtork في المنتدى مختــلف أنواع الدراجات النارية
    مشاركات: 1
    آخر مشاركة: 28-02-2010, 01:34 AM
  2. اريد استفسار جيد عن الموتوسيكل الرايس الهوندا Honda Racing
    بواسطة ahmedsaiko في المنتدى مختــلف أنواع الدراجات النارية
    آخر مشاركة: 15-02-2010, 04:49 PM
  3. Honda egypt
    بواسطة sherifahmed في المنتدى هـــــــوندا
    آخر مشاركة: 08-08-2008, 10:58 AM
  4. Max Speed in Honda City in Egypt
    بواسطة kimoboy في المنتدى مقــاطـع الفيــديـو و الكليبات و صـور للسيارات
    آخر مشاركة: 16-12-2007, 10:50 PM
