الصور, الموديلات دى منقولة من موقع هوندا ايجيبت يعنى انا مش جايب حاجة من دماغى
ويارب الموضوع يعجبكوا
CBR 1000RR
RepsoL
http://www.hondaegypt.com.eg/images/cbr1000rr.jpg
Engine Type Liquid-cooled inline-four
Displacement 998cc
Bore & Stroke 75mm x 56.5mm
Compression Ratio 12.2:1
Valve Train Chain-driven DOHC, 4 valves per cylinder
Fuel Delivery Dual Stage Fuel Injection
Transmission Close-ratio six-speed
Final Drive O-ring-sealed chain
Front Suspension 43mm inverted HMAS cartridge fork with full adjustability; 120mm (4.7 inches) travel
Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 135mm (5.3 inches) travel
Tires 120/70ZR - 17 radial front; 190/50ZR - 17 radial rear
Brakes Front dual 320mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
Seat Height 820mm (32.3 inches)
Wheelbase 1,402mm (55.2 inches)
Dry Weight tba
Fuel Capacity 18.2 litres
ColourRed/Black, Light Silver ....llic
ده الملك اللى شفته موجود لحد دلوقتى,
ياجماعة انا شوفت الrace دة وكان منقول على عربية نقل فى طريق مصر اسماعلية ,حاجة فوق الخيال وحجمه كبير عامل زى الحصان
بس كنت هاموت واسمع صوته فى التزويد
وبتمنى اشتريه
CBR 1000 RR
http://www.hondaegypt.com.eg/images/...r_003_1024.jpghttp://www.hondaegypt.com.eg/images/...r_005_1024.jpg http://www.hondaegypt.com.eg/images/...r_002_1024.jpghttp://www.hondaegypt.com.eg/images/...r_004_1024.jpghttp://www.hondaegypt.com.eg/images/...r_001_1024.jpg Engine Type Liquid-cooled inline-four
Displacement 998cc
Dry Weight tba
CBR 600RR
http://www.hondaegypt.com.eg/images/...r_001_1024.jpghttp://www.hondaegypt.com.eg/images/...r_002_1024.jpghttp://www.hondaegypt.com.eg/images/...r_003_1024.jpghttp://www.hondaegypt.com.eg/images/...r_004_1024.jpg Engine Type Liquid-cooled inline-four
Displacement 599cc
Bore & Stroke 67mm x 42.5mm
Front Suspension 41mm inverted HMAS cartridge fork with full adjustability; 119mm (4.7 inches) travel
Rear Suspension Unit Pro-Link HMAS single shock with full adjustability; 130mm (5.1 inches) travel
Tires 120/70ZR - 17 radial front; 180/55ZR - 17 radial rear
Brakes Front dual 310mm discs with radial-mounted four-piston calipers; rear single 220mm disc with single-piston caliper
Wheelbase 1,368mm (53.8 inches)
Dry Weight 156.5 kg (345 pounds)
Fuel Capacity 18.1 litres
Colour
Black, Red/Black, Ultra Blue ....llic/Silver
Contact Them At
للاستفسار عن الاسعار
Motorcycles :
26th July st., Tersana shopping center ,
Mohandesseen , P.O.BOX 59(11511)
tel:
33448340
+(202)
Motorcycles:
19 Sultan Hussiesn St., Mahatit El Raml
Alexandria
tel:+(203)
4851317 -4813743
Honda Hot Line:
19811
