النتائج 1 إلى 10 من 22
الموضوع: Koni FSD Review
    الصورة الرمزية HNaga
    رقم العضوية : 27
    السيارة: Opel Astra CD 1.6
    السيارة[2]: Peugeot
    الحالة : HNaga غير متواجد حالياً
    افتراضي Koni FSD Review - Facebook Twitter whatsapp انشر الموضوع فى :
    I fitted the FSD's and took the car for a short drive around the block just to make sure everything was as it should be. I'm not sure what I was expecting at first, I kind of thought it would be harsher than standard, but it wasn't. The ride was pretty much the same as before I put them on, which for some reason was slightly dissapointing.
    After this short drive, I checked everything over to make sure everything was still as it should be. All was OK so I thought I'd take it out on some more challenging roads to get a proper feel for the handling.
    The first challenge was some speed bumps, where as with OE shocks it was a little bouncy going over them, with the FSD's it was very smooth and not bouncy at all, yet at the same time it was in no way harsh. It's difficult to describe , it's neither firm nor soft, it's just right.
    I then headed off to some twisty, undulating roads around Bridgenorth and Ironbridge. I had been down the same roads last week and was bouncing all over the place. Now it was much better, body roll was minimal through the bends and they almost seemed to level out the road, where last week I was bouncing all over.
    I just kept on pushing more and more around the bends as I got a better feel for the handling. I wouldn't have dreamt taking some of the corners how I did, but the car just took them in its stride as though I was going 20mph around town. I'd hate to think how far you can push this setup, certainly beyond anything I am going to throw at it.
    In summary, these shocks provide a comfortable ride, no matter what you throw at it, and at no point will it feel harsh. Pretty much no chance of loosing any fillings, no matter how rough the road is.
    Would I reccommend them: Definately.
    منقول من أحد المنتديات الأجنبية
    الصورة الرمزية peter
    رقم العضوية : 1486
    الحالة : peter غير متواجد حالياً
    is it fits for any cars and how much did it cost here???
    If U cant Do It....Die Tryin
    رقم العضوية : 27
    السيارة[2]: Peugeot
    I don't know the exact price here
    but I asked Arabcom twice and the price was from 3000 to 3500 for the springs
    the whole kit , springs and shock absorbers may cost 5,000
    I don't know if some else sells That model of Koni
    ٌRegards
    Hisham Abul Naga
    Opel Astra CD 1.6i 16v Auto
    رقم العضوية : 1486
    front and rear, 3500 right????
    الصورة الرمزية Ahmed Selim
    رقم العضوية : 2316
    الاقامة : Nasr City - UAE
    السيارة: Accent 2006
    السيارة[2]: Megane II 2005/Megane II 2007
    الحالة : Ahmed Selim غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة peter
    Arabcom and car boys sell them
    I asked about them for a friend of mine at Arabcom the price for the FSD was 4200 for the shocks only
    it was 3800 for the Yellow Koni
    ( the car is BMW E46 2002)
    The guy I know at Arabcom told me that FSD is not as good as Yellows in our streets based on installations they did.
    He recomnded the Yellows although they are cheaper.
    I got my Yellows 2 years ago for Megane II 2005 for 3100 for the shocks only.
    the guy's name is Mamdouh call him to know the price of konis for your ride
    0101818328
    good luck
    يا بلادى يا بلادى.........أنا بحبك يا بلادى
    رقم العضوية : 27
    السيارة[2]: Peugeot
    yes you're right , a boy at arabcom said so , that manual adjust is better , but don't trust what he said.
    I baught Splitfire from them first they didn't know which part to fit to my car
    second when the mecanican didn't know if they fit I called them the answer was we don't know
    Finally I return them back
    That's why I search for that review and published it here once I found it
    ٌRegards
    Hisham Abul Naga
    رقم العضوية : 27
    السيارة[2]: Peugeot
    Yes 3000 to 3500 for both front and rear
    رقم العضوية : 2316
    اقتباس المشاركة الأصلية كتبت بواسطة HNaga
    may be you are right about this but I trust car boys very much, they're mechanical engineers
    Khaled Ghazi and someone else i can't recall his name, you can ask them whatever you want about the suspension and they will answer honestly.
    by the way they import Konis for their own
    and Arabcom requires you to install the Koni there to be able to keep the warranty.
    رقم العضوية : 1486
    thanks you tronky and i will call him and tell you the price by tom. but whats the difference between the yellow ones and the shocks? and what about the whole kit?what is it
    رقم العضوية : 27
    السيارة[2]: Peugeot
    اقتباس المشاركة الأصلية كتبت بواسطة Tronky
    Never heard about car boys , where can I find it?
    and how to contact them before??
    thanks for information
  1. Koni ,, Apex ,, Eibach !! انهي الاحسن في السوست ؟؟
    بواسطة Ahmod في المنتدى تعـــديل الســـيارات و الإضافات
    مشاركات: 21
    آخر مشاركة: 03-06-2012, 04:40 PM
  2. Koni Yellow vs Tein Super Street
    بواسطة 1.8Tee في المنتدى ميتـسوبيـشى
    مشاركات: 6
    آخر مشاركة: 31-07-2011, 09:34 PM
  3. عفشة Koni لسيارة هوندا سيفيك 96-2000
    بواسطة EK4 في المنتدى قســم خاص لبيع السيارات فقـــط
    مشاركات: 7
    آخر مشاركة: 29-03-2011, 04:33 PM
  4. استفسار هاااااااااااام زبخصوص koni
    بواسطة designer1 في المنتدى تعـــديل الســـيارات و الإضافات
    مشاركات: 21
    آخر مشاركة: 14-02-2010, 07:37 PM
  5. Koni FSD
    بواسطة HNaga في المنتدى تعـــديل الســـيارات و الإضافات
    آخر مشاركة: 03-07-2007, 02:52 PM
