good post
the spark plug seems to block the fireing path so it is normal to have less milage with this designe
رقم العضوية : 63
الاقامة : Dystopia , blashyrkh
السيارة: N/A
السيارة[2]: Subaru Impreza 2006
Don't count on E3 spark plugs to save you money on gas
Over the years, countless companies have come up with devices claimed to reduce fuel consumption. The claims have ranged from plausible to the ridiculous. For example, wrapping magnets around your fuel line will not double your mileage and the only way you will ever get 200 mpg with a carburetor is to make it so small that air and fuel flow are so restricted that it can't possibly use more fuel than that. Of course your engine would produce so little power in the process as to be useless.
Spark plugs have long been a popular area for "innovation" of this sort. One of the latest comes in the form of the E3 spark plug featuring its DiamondFire electrode. This one falls into the plausible-but-unlikely category. Writer Larry Edsall recently undertook the latest iteration of a 5,000 mile annual road trip and decided to try out the E3 plugs. While E3 claims a 3-5 percent improvement in mileage, Edsall found his dipped from 20.11/19.98 the previous two years to 19.18 with the E3 plugs. He did all the usual maintenance like oil changes and tire pressures before leaving. Of course the vehicle was a year older and more worn which may have contributed to the dip. But even a fully scientific test with two or more vehicles running side by side in the same conditions (aside from the spark plugs) would probably yield a negligible difference at best. The E3 plugs aren't that pricey ($6-7 each) so if you do choose to try them it won't cost a lot. Just don't be too disappointed if you don't see much improvement in mileage.
<!--EndFragment-->
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
good post
رقم العضوية : 761
الاقامة : Qatar
السيارة: Dodge Durango 2008
السيارة[2]: peugeot 508 allure 2014
يا سلام ؟؟؟
هو إنتوا يا جماعه مفترضين إن كلالأعضاء أجانب ولا لغتهم في المصطلحات الإنجليزية 100% ؟
أرجو من الأدمين سايت عمل قسم جديد للترجمة لكي يستفيد باقس الأعضاء من هذه المعلومات .
رقم العضوية : 1869
الاقامة : السعودية
السيارة: A11
السيارة[2]: TAHOE
+1000000000000المشاركة الأصلية كتبت بواسطة إسلام شاهين
الموضيع كتيرة والوقت ضيق مفيش - يعنى أحنا عايزين ننجز مش نقعد نترجم
[sor2]http://www2.0zz0.com/2012/03/20/06/448963560.jpg[/sor2]
TAHOE THE LEGEND
رقم العضوية : 72
الاقامة : البحرين
السيارة: سوزوكي ماروتي، مصر
وها هى الترجمة لمن يفضلون القراءة بالعربية:
على مدى السنوات قام عدد لا يحصى من الشركات بتقديم مبتكرات قيل عنها انها تخفض استهلاك الوقود، وكل هذة الادوات تم تقييمها بتقييمات تتراوح من "ابتكارات معقولة" الى "ابتكارات سخيفة عديمة الفائدة"، على سبيل المثال فإن وضع ملفات مغناطيسية على خطوط الوقود لن يضاعف المسافة المقطوعة بنفس كمية الوقود، والوسيلة الوحيدة لقطع 200 ميل بجالون بنزين واحد هى تصغير الكاربراتير حتى لا يسمح بمرور كمية هواء او وقود سوى كمية ضئيلة جدا، وبديهى اننا فى هذة الحالة سوف نحصل على طاقة من القلة انها قد لا تكفى لتحريك السيارة اصلا
شمعات الإحتراق(البوجيهات) كانت لمدى طويل هدفا شعبيا لتطويرات من هذا النوع،واحد من احدث هذة الانواع يأتى فى الشكل المسمى E3 ، وهو يشمل شمعة احتراق معدنية بشكل مربع مائل(سمبوكسة)، هذا النوع يقع فى ظمن الفئة المعقولة ، لكنها فى نفس الوقت لا يتوقع منها الكثير من الفائدة
الكاتب لارى ادسال قام مؤخرا بتكرار تجربة رحلة ال5000 ميل السنوية وقرر فى هذة المرة تجربة شمعات الإحتراق طراز E3 فيما تدعى الشركة المنتجة لE3توفيرا يتراوح من 3 الى 5 % وجد إدسال ارتفاعا فى الإستهلاك عن لعامين الماضيين من 20.11 ميل لكل جالون الى 19.18 ميل لكل جالون برغم قيامه بالصيانات العادية من تغيير زيوت ومراجعة الإطارات وخلافه
بالطبع فإن المركبة كانت اقدم بسنة كامة فيما يعنى نسبة تآكل اكبر مما ساهم فى ارتفاع استهلاك الوقود. ولكن حتى لو تم اختبار علمى تماما بمركبتين تسيران جنبا الى جنب و تشتركان فى كل الخواص فيما عدا شمعات الإحتراق غالبا سيؤدى الى نتيجة لا تذكر فيما يخص تحسين استهلاك الوقود. عموما فإن شمعات E3 ليست مكلفة، فلو انك قررت تجربتهم فلن تخسر الكثير، فقط لا تكن محبطا عندما لا تصادف تحسنا يذكر فى الإستهلاك
رقم العضوية : 1869
الاقامة : السعودية
السيارة: A11
السيارة[2]: TAHOE
سبعاوى - اللة عليك أنت بتنهى معايا فى أى موضوع مشششششششششششككككككككككككو وووووووووووررررررررررر ;) ;) ;) ;) ;) ;)
TAHOE THE LEGEND
رقم العضوية : 761
الاقامة : Qatar
يا باش مهندس سبعاوي كده كثير قوي والله .
جزاك الله كمل خير أهو كده أنا فهمت واستفدت ربنا يباركلك .
