That's hard to find.
try going custom
Congratulations Mr. Mohamed, although I always feels it's just an engine jewelry, especially on a relatively modern car...l
i thought that too but real life experience says otherwise
Well did you notice any torsional improvement or just more of stiffening the mounting points of the front struts ?.l
Thanks.l
the feedback i got after the installation was good in all ways:
i got less body roll at corners in a way that even the passengers noticed that the car's handling has improved than before...so i recon the torsional improvement is their indeed
stability under heavy straight line braking improved... no more wandering when you are approaching a speed bump going from 120 to almost a complete halt while braking very late
the front of the car felt like it is more stiff than before... also bumps doesn't upset the car body as much as it used to do before the bar
ok ok
i cant understand anything
يا جماعه لو سمحتوا نجيب منين الحاجه دى فى مصر
لو حد شافهم فى مصر عند بياع يقولنا
