cong.my dear friend
i would like to know your opinion when you install a rear strut and a lower front one ,cause by the time i guess you will like the good handling of your car and you will ask for more......stability and handling is addiction
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
i have got a front strut bar for the woo... actually it was a gift from my very good friend Ehab BOB (thank you very much Ehab for the great gift :D )
i have done the installation myself and it is easy as hell but that is not the important part.... the important part is the contribution of that this simple bar to the handling of the car
at the very first turn i have noticed that their is less body roll and that gave me the courage to push it hard on the next corners to see how well is this thing... the body roll was some 50% less than before... also the car felt like it is more ridged and "one piece" if you know what i mean. this gave me the confidence to push the car harder into corners and it seems the car does like that now... in the old days if i want hard in a corner i got horrible wheel squealing sounds and the passenger would end up on my lap (or me in his lap of it was a left corner).. now all that is gone
i still haven't done a really satisfactory test for this upgrade as i have on course in mind that will test the cornering performance indeed... it is a 2.5 down hill road full of tricky curves and represents the ultimate handling tester for us here.
i also felt it is going better over bumps in straight lines which seemed strange to me but after reading more about strut bars i realized it adds to the spring rates and thus gives the feel of stiffer suspension... also stability under straight line braking improved which was a bit strange for me too as i was under the impression that the strut brace will add to cornering performance only
actually i was a bit worried as the level of improvement this thing added to the car's handling made me think i got something wrong with the car and the strut bar cured it but from previous feedback i found on the internet i can see that this is almost the same experience every one else had with the strut brace... even Zorex my personal test driver was impressed with the handling performance of the Woo after the installation of the brace... he was giving me hard time because of the amount of body roll i have - he got a BMW E36 with adjustable Koni suspension and 225/40/17 tires so anything else rolls for him - but after a test drive in my car he was impressed with the improvement made by the bar.
in my opinion this thing should be an OEM part on all cars as it really adds to the handling of the car and i don't think it is too expensive to have so why not have it as standard???... since it is not a standard part then by all means i strongly recommends this upgrade for anyone seeping handling performance 8)
one last thing: i was stupid enough to install the bar backwards... yes the lanos bar is directional so that it clears the coolant reservoir... the coolant reservoir part of the bar is actually bent twice so their is two little angles to make the inclination of the bar a bit smooth at the reservoir area and make sufficient clearance around the reservoir.
when i had the bar the wrong way i was going "oh shit... this is going to be super tight fitment" and i actually had to tilt the coolant hose clamp to clear the bar... but yesterday i was looking at the bar and noticed the two bends on the opposite side - again i thought the bar was defective or so - but then realized the reason behind the two bends.
here are the pics for the "before" and "after":
رقم العضوية : 4385
الاقامة : Alexandria
السيارة: grande punto T-jet
السيارة[2]: خلاص بخ
دراجة بخارية: nope
cong.my dear friend
رقم العضوية : 45
الاقامة : المعادي..أخر الشارع
السيارة: Logan A/T-Yaris HB HL
السيارة[2]: Astra J Cosmo
دراجة بخارية: NO
looks perfect
custom or OEM?
رقم العضوية : 23065
الاقامة : Egyptian highways
السيارة: -------
السيارة[2]: Hyundai Verna 2007
All I got from the above is that this bar makes the car perform better at corners
correct me if I'm wrong
Any similar thing for the verna then?
رقم العضوية : 30094
الاقامة : EgYpTo
السيارة: Only One
السيارة[2]: Private
دراجة بخارية: RR
Gr8 job..
So that bar works like a dream for lanos
Congrats MMamdouh
Keep it up
We still wait for 2 things
1. Twin cam project
2. Turbo
[glow1=#7a3131]Dr.Ahmed AlSherif[/glow1]
رقم العضوية : 162
السيارة: Opel Corsa 1998
السيارة[2]: KIA Carens 2011
perfect
any idea where i can get the same stuff for my nubira ?
and how much it will cost?
رقم العضوية : 36989
السيارة: كروز 2014
السيارة[2]: Car Enthusiaset
دراجة بخارية: :))
i told you before that that bar gave my verna a rigid suspinsion and perfect handling specially under cover with the 195/50/15 tires
actullay am searching now how can i add a rear bar ???!!!!
as a dear member said before
Improving Handling is addiction !!
i tried it hard untill the car swayed ! it was 100km/h on nearly a 70 degrees curve !!
اللى حيضيع بلدنا : الفهلوة و كلمة باشا و معلش و أصل
رقم العضوية : 36989
السيارة: كروز 2014
دراجة بخارية: :))
رقم العضوية : 41164
الاقامة : El Minia
السيارة: Lancer2007
السيارة[2]: mazda323
طبعاً اللغة شىء جميل ياشباب بس بلاش كتير كده انا مش فاهم حاجة
وفى مواضيع كتيرة واقعة منى بسبب الوضوع ده
محمد عبد الرحمن
....المحامى.....
رقم العضوية : 23065
السيارة: -------
هاها ... صح هو كله بيكتب انجلش لية ؟i've installed the lancer bar in my verna >>> piece of cake :)))))
by the way ...why we are all writing in english right now
معلش سؤال.. اللي انا فهمته ان البار دا بيخلي العربية احسن في الملفات ؟؟ فعلاً ؟ يعنى انت حاسس بفرق مع الفيرنا بعد التركيب ؟
يا ريت تقوللي .. و مشكوووور ( عالبيس اوف كيك لول)
