OverDrive (D, OD, or a boxed [D])با شا انا مش معاك فى الكلام ده الاوفر درابف العربيه علىالرابع و عايس تشد او تاخد غرزه الاوفر درابف ده بينقل العربيه من الرابع للتالت و لو حتمشى عليه و حارق البنزين بيطير منك
This mode is used in some transmissions to allow early computer-controlled transmissions to engage the Automatic Overdrive. In these transmissions, Drive (D) locks the Automatic Overdrive off, but is identical otherwise. OD (Overdrive) in these cars is engaged under steady speeds or low acceleration at approximately 35–45 mph (56–72 km/h). Under hard acceleration or below 35–45 mph (56–72 km/h), the transmission will automatically downshift. Vehicles with this option should be driven in this mode unless circumstances require a lower gear.
Automatic transmission - Wikipedia, the free encyclopedia
