ارقام الفيوزات دي ايبيزا كود الموديل 6k2
رقم العضوية : 130446
السيارة: Ibiza Or Golf
السيارة[2]: Ibiza 2000
الموضوع مفتوح للمناقشه لكل واحد عنده معلومه يحب يضفها وعارف ان فى كتير محتجلها
ديه صورة علبة الفيوزات لابيزا 2000-02
وديه نبزه عنها
Fuse Layout
Fuse number: Amp
1. Engine / Engine Electronics 15
2. Engine / Engine Electronics 15
3. Engine Valves 10
4. Ignition Transformer 15
5. Automatic gearbox/ reverse
light / heated jets 20
6. Automatic gearbox 5
7. Injectors / Fuel pump 15
8. Lambda sensor 10
9. "S" signal * (see footer) 5
10. Control panel / Diagnostics /
Central locking alarm electronics 5
11. Horn / Heated Seats 20
12. Right hand main beam and
pilot light. 7,5
13. Left hand main beam 7,5
14. Right hand dipped beam / right
hand lamp adjuster 7,5
15. Left hand dipped beam / left
16. Right hand parking light 5
17. Left hand parking light 5
18. ABS / TCS / ESP 5
19. Fog light / Rear fog light 15
20. Brake lights 7,5
21. Hazard lights 15
22. Indicators 7,5
23. Windscreen washer and
pump / rear windscreen washer 15
24. Head lamp washer 20
25. Heated rear window 20
26. Control panel lighting /Control
panel display / Electric mirrors/
Dashboard lighting 5
27. Inside, boot lighting / Alarm
Siren 7,5
28. Lighter 10
29. Radio / CD 15
30. Heater 25
31. Number plate light 5
32. Engines central locking 30
Fuses above relay switchboard:
33. Electronic front windows 30
34. Sunroof 15
35. Electric font and / or rear
windows 20
36. Canvas Roof 20
37.Power socket in luggage
compartment 15
Fuse Box in the engine compartment on the battery:
Radiator Fan, 1st gear 30
ABS engine relay 30
ABS main relay 30
....l fuses (These fuses should only be changed at a SEAT Official Service Centre)
Alternator 150
Onboard network 110
Radiator fan, 2nd, 3rd level 40
Engine distribution system 50
Glow plugs 50
Fuse colour code:
Beige 5amp
Brown 7.5amp
Red 10amp
Blue 15amp
Yellow 20amp
White 25amp
Green 30amp
Fuse 9 on the main strip:
The "S" signal is a system which incorporates steering wheel lock and ignition. Once the ignition is switched off and without removing the key from the ignition, this function allows you to switch on some of the electrical equipment such as the car radio, the courtesy light, etc.
This function is deactivated once the key is removed from the ignition
ماشاء الله كان وما لم يشأ لم يكن
SEAT IBIZA 2000 MK3 (6k2)ALD Engine 1.0 8v MPI
رقم العضوية : 22731
السيارة: الحمدلله حمداطيبا كثيرا مباركا فيه
السيارة[2]: Seat IBIZA 99 6K 1.6
" اللهم إنا نجعلك في نحورهم ، ونعوذ بك اللهم من شرورهم "
رقم العضوية : 94704
الاقامة : Haram - Giza
السيارة: OPEL VECTRA 2.0
السيارة[2]: Seat IBIZA 1999
دراجة بخارية: NO
تسلم ايدك
وشكراً علي المجهود
Eng. Mohamed Sayed | MS Networking TrainerIBIZA MK2 (Typ 6K) APQ 1.4 MPI R4 44KW - 60hp
صفحة القسم علي الفيس بوك
رقم العضوية : 125812
الاقامة : Dammam-KSA
السيارة: Lada 2105 1984 Sold
السيارة[2]: Ibiza 6K 101 HP
الله ينور ياحسام
بس ياريت تكمل جميلك وتترجم اسماء الفيوزات عشان الموضوع يبقى اسهل على الاعضاء
وبعدين يا عم ليه معدلتش توقيعك
Karim Samy - Business Development
Fiat 128 Model 1983 1100cc
Lada 2105 Model 1984 1200cc & 1300cc
Nissan Tiida Model 2007 1600cc
SEAT ibiza 6k Model 1998 1000cc AER , 1400cc AEX & 1600cc AFT
Toyota Corolla Model 2013 1600cc
رقم العضوية : 37023
الاقامة : 6 of October
السيارة: ٍ Seat Cordoba
السيارة[2]: VW bittel
الله ينور
SEAT CORDOBA 2001 Engine 1000CC 16V 6K5 AVZ
رقم العضوية : 62920
الاقامة : Egypt
السيارة: ربنا يسهل
السيارة[2]: سيات-إيبيزا
دراجة بخارية: دراجة نارية
حسام بك تسلم ايدك يا باشا الله ينور عليك والموضوع ده مفيد جدا جدا لكل الناس .
حسيـــن الصـــواف
أبو باسل
رقم العضوية : 16065
الاقامة : 6 اكتوبر - الحي الثامن
السيارة: Grand Terios 2012
السيارة[2]: Seat Cordoba 2002
الله ينور يا حسام باشا و ربنا يباركلك و هي نفس اللي عندي بالضبط
م / إيهاب منصور
SEAT CORDOBA 2002 1.0 16V AVZ
ربنا يبارك فيكم جميعا
أنا لقتها فى مننتديات أجنبيه بس متفقه فى كذا منتدى وجمعتها مع بعض
حاضر ياكريم باشا هترجمها مع انى كنت معتمد بصراحه على عمدتنا البشمهندس أيهاب
عشان المصتلحات الهندسيه الكهربائيه ماهيا تخصصه ربنا يبركله
بس متزعقش هههه عدلت توقيعى زى ماطلبت بالظبط
تحياتى لكم جميعا
Fuse colour code: اكواد الفيوزات حسب اللون
Fuse Layout تخطيط الصمامات
Fuse number: Amp رقم الصمامات:الأمبير
1. Engine / Engine Electronics 15. المحرك / إلكترونيات المحرك 15
2. Engine / Engine Electronics 15. المحرك / إلكترونيات المحرك 15
3. Engine Valves 10. صمامات المحرك 10
4. Ignition Transformer 15 4. الموبينة 15
5. Automatic gearbox/ reverse علبة التروس الأوتوماتيكية / عكسي
light / heated jets 20 ضوء / ساخنة الطائرات 20
6. Automatic gearbox 5 علبة التروس أوتوماتيكية 5
7. Injectors / Fuel pump 15 الحقن (الرشاشات) / مضخة الوقود (طرمبة البنزين) 15
8. Lambda sensor 10 حساس الشكمان 10
9. "S" signal * (see footer) 5 "S" إشارة * (انظر تذييل الصفحة) 5
10. Control panel / Diagnostics / لوحة التحكم / التشخيص /
Central locking alarm electronics 5 ألكترونيات التنبيه للقفل المركزي ( السنتر ) 5
11. Horn / Heated Seats 20 القرن / مقاعد بتدفئة ( سخان الكراسى طبعا مش موجود فى أغلب الموديلات ) 20
12. Right hand main beam and الحق الشعاع الرئيسي يد و
pilot light. 7,5 ضوء التجريبية. 7،5
13. Left hand main beam 7,5 اليد اليسرى شعاع الرئيسي 7،5
14. Right hand dipped beam / right اليد اليمنى انخفض شعاع / يمين
hand lamp adjuster 7,5 ومن ناحية مصباح الضابط 7،5
15. Left hand dipped beam / left اليد اليسرى انخفض شعاع / يسار
16. Right hand parking light 5 اليد اليمنى ضوء وقوف السيارات يمين 5
17. Left hand parking light 5 اليد اليسار ضوء وقوف السيارات يسار 5
19. Fog light / Rear fog light 15 أضوء الضباب / أضوء الضباب الخلفية 15
20. Brake lights 7,5 أضواء الفرامل 7،5
21. Hazard lights 15 أضواء الخطر 15
22. Indicators 7,5 الإشارات 7،5
23. Windscreen washer and غسالة الزجاج الامامي للسيارة و
pump / rear windscreen washer 15 غسالة مضخة 15 / الزجاج الخلفي
24. Head lamp washer 20 رئيس مصباح غسالة 20
25. Heated rear window 20 ساخنة النافذة الخلفية 20
26. Control panel lighting /Control لوحة التحكم الإضاءة / التحكم
panel display / Electric mirrors/ عرض لوحة / المرايا الكهربائية /
Dashboard lighting 5 لوحة أجهزة القياس الإضاءة 5
27. Inside, boot lighting / Alarm في الداخل، التمهيد الإضاءة / انذار
Siren 7,5 صفارات الانذار 7،5
28. Lighter 10 أخف وزنا 10
29. Radio / CD 15 راديو / CD 15
30. Heater 25 سخان 25
31. Number plate light 5 عدد ضوء لوحة 5
32. Engines central locking 30 القفل المركزي للمحركات 30
Fuses above relay switchboard: الصمامات فوق لوحة التبديل التتابع:
33. Electronic front windows 30 الجبهة الإلكترونية ويندوز 30
34. Sunroof 15 فتحة السقف 15
35. Electric font and / or rear كهرباء الخط و / أو الخلفية ويندوز 20
windows 20
36. Canvas Roof 20 قماش السقف 20
37 .Power socket in luggage مقبس 37.Power في الأمتعة مقصورة (لمبة الشنطه) 15
compartment 15
Fuse Box in the engine compartment on the battery: Radiator Fan, 1st gear 30 دمج صندوق في حجرة المحرك على البطارية : مروحة المبرد، 1 والعتاد 30
ABS engine relay 30 محرك )نظام الفرامل الغير قابله للانزلاق ) 30
ABS main relay 30 الرئيسي نظام الفرامل الغير قابله للانزلاق 30
....l fuses (These fuses should only be changed at a SEAT Official Service Centre) الصمامات .... لتر (يجب فقط أن تتغير هذه الصمامات في مركز الخدمة الرسمية SEAT)
Alternator 150 المولد ( الدينمو) 150
Onboard network 110 شبكة على متن الطائرة 110
Radiator fan, 2nd, 3rd level 40 مروحة المبرد، 2، 3 مستوى 40
Engine distribution system 50 نظام التوزيع محرك 50
Glow plugs 50 توهج المقابس 50: فيوز الولاعة
فيوز 9 على قطاع الرئيسية:
و"S" إشارة هو النظام الذي يشتمل على توجيه قفل العجلات والاشتعال. مرة يتم فيها تشغيل الإشعال قبالة ودون إزالة المفتاح من الاشتعال، هذه الوظيفة تسمح لك لتشغيل بعض المعدات الكهربائية مثل راديو السيارة، ضوء ، الخ
يتم إلغاء تنشيط هذه الوظيفة مرة واحدة تتم إزالة المفتاح من الاشتعال ( الكونتكت )
Beige 5amp البيج 5amp – العدد 8
Brown 7.5ampالبني 7.5amp – العدد 6
Red 10amp الأحمر 0amp 1 – العدد 4
Blue 15amp الأزرق 15amp – العدد8
Yellow 20amp الصفراء 20 amp – العدد 4
White 25amp أبيض 25amp – العدد 1
Green 30amp الأخضر 30 amp – العدد1 المجموع : 32 فيوز
رقم العضوية : 45794
الاقامة : alexandria
السيارة: opel vectra
السيارة[2]: Seat Cordoba 6K ALM 1.6 75HP
هل تتطابق مع موتور alm code engine لوحه الفيوزات
