بعض المعلومات عن وظيفة حساس الكرنك
A Crankshaft Sensor is a component used in an engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters. Before electronic crank sensors were available, the distributor would have to be manually adjusted to a timing mark on the engine.
The crankshaft sensor can be used in combination with a similar camshaft position sensor to monitor the relationship between the pistons and valves in the engine, which is particularly important in engines with variable valve timing. It is also commonly the primary source for the measurement of engine speed in its RPM.
Crankshaft sensors in engines usually consist of magnets and an inductive coil, or they may be based on magnetically triggered hall effect semiconductor devices. Common mounting locations include the main crank pulley, the flywheel, and occasionally on the crankshaft itself.
