Hey mamin the car is designed to use 95 octane and i am sure that u use 92 just like me well don't worry about the message it's just telling you that u are hearting the .environment :d .well try to full the tank from another gas station i recommend total or emirates just full the the tank with 92 , the main problem is that the octane u r using is't clean so the ratio of the co2 is much higher ;).
