عادي
مش بعيد على تويوتا بالذات بعد ما جالها رئيس تصميمات مرسيدس اللي هو صمم ال Cl 2008 و ال S Class & C Class & B Class
رقم العضوية : 143
الاقامة : Nasr City
السيارة: Toyota Yaris 2007
السيارة[2]: Nissan Juke 2013
شكرا للجميع على الردود الجميلة
رقم العضوية : 1739
الاقامة : plainville , MA - USA
السيارة: Toyota Cressida
السيارة[2]: Toyota Hilux
عادي
my best words:
1)ωнαт ∂σєѕη'т кιℓℓѕ уσυ мαкєѕ уσυ ѕтяσηgєя-
2)ιт'ѕ ησт нσω мαηу тιмєѕ уσυ ∂σωη'ѕ вυт нσω мυ¢н уσυ єαяη ƒяσм уσυя ∂σωη'ѕ
http://img221.imageshack.us/img221/5...7525468us6.png
رقم العضوية : 97
الاقامة : ManSOuRa
السيارة: coRoLLa 06
السيارة[2]: siRiOn 07
دراجة بخارية: ان شاء الله
When SUVs were all the rage, companies dolled up station wagons and relabeled them as SUVs. (Look at the first-generation Subaru Forester and Honda CR-V.) Now that the SUV market has cooled, the industry is going in the opposite direction-crossovers are being marketed as sedan alternatives. The all-new Toyota Venza is wider and taller than the Infiniti EX, longer and wider than the RX 350, and nearly the same size as the Ford Edge, yet Toyota doesn't want it labeled as a crossover. The idea is that the Venza is 70-percent car, 30-percent SUV. Further complicating things, the EPA classifies it as a truck.
The platform comes from a mix of Toyota components. The floorpan involves elements of three platforms welded together: Highlander up front and beefed-up Camry in the middle, with the rearmost portion unique to the Venza. However, its suspension, MacPherson struts in front and dual link/struts in the rear, was lifted from the Highlander, with retuned springs and shocks to provide a more carlike ride. Ground clearance is identical to that of the Highlander, at 8.1 inches, but it's rumored Toyota is going to lower that by as much as 0.75 inch for 2010. Nineteen-inch wheels are standard with the four (tires on our tester are Toyo Open Countrys), 20s with the six (Michelin Latitudes); in both cases, the temporary spare is a 165/90D18 Bridgestone, stored under the cargo floor. Despite the high ground clearance and large wheels and tires, one thing that does push this vehicle closer to a car than an SUV is its height: The roofline is nearly six inches lower than the Highlander's and four to five inches lower than that of the Edge. It even sits lower than the RAV4.
Propelling the Venza is a choice of two engines: a new 2.7-liter, 182-horse inline-four and a 3.5-liter, 268-horse V-6, seen in the Camry, Highlander, and RAV4. Both are backed by a six-speed automatic transmission, but because Toyota made serious changes to it to reduce weight when backing the four, the automatic has a different model designation with each engine, and Toyota considers them different transmissions. Four- and six-cylinder models are available with FWD or AWD. Toyota wouldn't confirm that a hybrid option is coming, but it would make perfect sense (so would using this platform as the basis for the next-generation RX)
عن أبي هريرة قال :
قال رسول الله صلى الله عليه وسلم :
إذا قال الرجل لأخيه :جزاك الله خيرا ، فقد أبلغ في الثناء
رقم العضوية : 14840
الاقامة : Egypt
السيارة: Toyota Corolla
السيارة[2]: Skoda Octavia 2009
me3adyaaaaaaaaaaaaaaaaa
bas el fetis makano 3ageeb awy
bas bgd to7fa to7fa
a7la 3rbya shoftha le toyota
رقم العضوية : 143
الاقامة : Nasr City
الموضوع مكرر يا باشا فى اللينك دا
http://www.nilemotors.net/Nile/showt...ghlight=sharky
رقم العضوية : 97
الاقامة : ManSOuRa
السيارة: coRoLLa 06
ما انا عارف يا احمد بس الموضوع اللي انت بتقول عليه مفيش فيه مواصفات عن العربيه مفيش داتا عنها
وشكرا يا جميل على مرورك
عن أبي هريرة قال :
رقم العضوية : 1946
الاقامة : الامارات - أبوظبي
السيارة: بيجو 207 - 2009
السيارة[2]: نيسان باثفيندر 2014
دراجة بخارية: عمرى ما سقتها
شكرا يأبو عبدالله على الصور والمعلومات
عربيه حلوة
بس انا مضايق ان تويوتا خلت كل العربيات شبه بعض
انا عارف ان معظم الشركات الكبيره بتحب تثبت الدايزن بتاعها لكل العربيات
بس كده مش حلو
العربيه عبارة عن كامرى متعدله
رقم العضوية : 97
الاقامة : ManSOuRa
السيارة: coRoLLa 06
انا معاك يا بشمهندس
بس العربيه فعلا الأنسيابية بتاعتها جميلة بصراحه برضه
عن أبي هريرة قال :
رقم العضوية : 2539
الاقامة : جمهورية مصر العربية
السيارة: skoda fabia 1.6 sport
السيارة[2]: renault symbol 2010
دراجة بخارية: none
عربية جامدة جدا يا جماعة شكرا يا باشا علي الصور
Hear The Song Of Power
رقم العضوية : 19419
جااااااااااااااااااااامدة
Eng\ooso
اللهم انت ربي لا اله الا أنت خلقتني وانا عبدك وانا علي عهدك و وعدك ماستطعت اعوذ بك من شر ما صنعت و أبوء لك بنعمتك عليا وأبوء بذنبي فاغفر لي فانه لا يغفر الذنوب الا أنت
