تركيب زينون بالشرح و الصور
HID install
Having experienced HID lighting in all my cars for over 5 years, it was difficult to go back to regular halogen lighting. I drive a fair amount on the highway from Toronto to many parts of Michigan. Being able to spot any animals along the side of the highway at 4-5am is very important for me.
I chose to use AbsoluteHID due to the positive feedback I received from the local BMW community over the past years and the fact that I have local support is a plus.
I used an H11 AbsoluteHID kit. It uses 55W ballasts with 4300K bulbs. I wanted to achieve a stock appearance without any shade of blue.
It’s also recommended that you upgrade your 10amp headlight fuse with a 15amp fuse which I had no problem with.
Before removing the headlamp assemblies, I added some painters tape to the front bumper and grille below the lights to prevent any potential damage.
This image has been resized. Click this bar to view the full image.
Test fitting all the connections and plugged everything in the car.
I used a 1” hole saw and made a hole onto the cover as shown
I ran the wires through and used black caulking on the grommet to help seal the grommet once in-place
I added a few strips of double sided tape and adhered the ballasts to the top of the windshield washer reservoir and the body as shown.
The lighting is incredible. The cut-off is actually quite low for a headlamp assembly that’s not designed for HID lighting output.
