هل لاحدكم ان يترجم لنا طريقة فحص ال IDLE
To check the IAC motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the IAC should move in or out. If the IAC motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the IAC motor is removed clean (use aerosol carburetor cleaner) the passages the IAC uses to control idle air speed, also inspect the IAC for a build-up on the seating (pointed) end and clean as necessary.
Common Problems
An IAC motor is highly susceptible to carbon and coking build up; if an IAC goes too long without cleaning it can cause stalling and poor idle quality. Some cars are designed with a large vacuum transfer hose that connects the intake manifold to the IAC (idle air control) motor. If a broken or dilapidated these vacuum lines can cause the engine to lose vacuum which will allow the engine to run rough and die. Inspect all engine and accessory vacuum lines to look for missing, torn or dilapidated lines and replace as needed. Any car that is designed with a magnetic non-motor operated IAC like Toyota/Lexus is subject to carbon and should be cleaned about every 40,000 miles to avoid stalling.
Basic Maintenance
