الصور عمرها ما تبين المشكلة فين لأن ممكن الأسلاك تبقى فى مكانها و كل حاجة بس فى حاجة مش مظبوطة
لو حضرتك مصمم أنا هارفعلك صورها من بكرة
رقم العضوية : 30589
الاقامة : Giza
السيارة: Hyundai accent sport 2011 A/T
السيارة[2]: Punto MK2b 2009
والله مش عارف..... أنا طالب خدمة .... عايز حد يصور الموتور بتاع عربية بونتو علشان أشوف الكابلات كده أخبارها ايه عندى..
رقم العضوية : 42525
الاقامة : Tanta mainly
السيارة: Fiesta1.6, Punto
السيارة[2]: Peugeot 207
رقم العضوية : 30589
الاقامة : Giza
Hi,
Here's all the steps I went through,
1- I went to the BURQAN "Certified Agency for OMATRA": They told me the throttle body needs to be cleaned and that's what they have done!.
2- The car wasn't vibrating or stopping again, but the RPM was getting high in a crazy way with the AC compressor on.
3- I went to the BURQAN "Certified Agency for OMATRA": They cleaned the throttle body again, and they checked the car on the comupter.
4- The car is again, vibrating, stopping, with high RPM conditioned by having the AC working.
5- I went to the ACSA "Certified Agency for OMATRA": They told me that they didn't see the problem!
6- I went to the BURQAN "Certified Agency for OMATRA": They cleaned the throttle body again, and asked me to go to the main center for OMATRA.
Note: I paid in the 1st visit to BURQAN, and to ACSA…. While the car is still under warranty.
7- I went to the main center of OMATRA last Saturday "7th of August, 2010".
8- The main center of OMATRA has changed the throttle body, the manifold. They tried even changing the control unit!
9- The last infromation I got from OMATRA is that it's a problem with the injectors "2 of them" are leaking and not spraying.
10- The current Job_order number in OMATRA right now is"19989" (Model: punto 2009).
11- Tuesday "10th of August", OMATRA called me and told me that the car has been fixed and ready "after changing the injectors". I went to them to find the car is so dirty "interior and exterior", the fuel empty indicator was "on", the same problem is still there "the RPM was getting higher and didn't go to the steady state", and I started to hear sounds from the "front" in bumpy roads.
12- Wednesday "11th of August", OMATRA told me they changed the MAP sensor, and the car is still under testing!
تم تعديل المشاركة بناء على رغبة العضو
مشرف 18ب
رقم العضوية : 3614
السيارة: searching
السيارة[2]: punto 2004 speedgear
دراجة بخارية: nil
نهار زى بعده ايه ده و انا اللى زعلان عشان ما عرفوش يحلو المشكلة ديه فى عربيتى ده لو كانو غيرولى الحاجات ديه و الموضوع ما اتحلش كنت ما عرفش كنت هاعمل ايه اسمع انت لازم تتخانق عشان حركة النضافة ديه و لو العربية ما تظبطتش قولهم مش عايزها غيروهالى طب مين ها يفهم فى الفيات طيب؟
لو كانت عربيتك قديمة شوية كنت قلتلك وديها للنيل بس مادام فى الضمان تتغير كلها و ريح دماغك
رقم العضوية : 3614
السيارة: searching
دراجة بخارية: nil
ارجو انك تقوللى عملت ايه
رقم العضوية : 11661
السيارة: octavia A4 98 M/T
السيارة[2]: TOYOTA YARIS 2008 M/T
دراجة بخارية: لايوجد
المشكلة دى حاجة من ثلاثة
حساس tps
كنترول يونيت
حساس تكيف المتركب فى الفلتر الموازى للسربتينة التكيف
ولــــــــــــو تراني راكبا ....* علــــى حمار اهزلي
يمشي علــــــــــــى ثلاثة ....* كمـــــشية العرنجلي
والناس ترجــــــــم جملي ....* في الســوق بالقلقللي
والكـــــــــل كعكع كعِكَع ....* خلفي ومـــن حويللي
لكـــــــــــن مشيت هاربا ....* من خشـــية العقنقلي
"A lie gets halfway around the world before the truth has a chance to get its pants on."
Winston Churchill
رقم العضوية : 30589
الاقامة : Giza
After changing the MAP sensor.... the same situation.... problem is still there... the only difference it was clean with fuel :)
I escalated again to Fiat Italy in a very aggressive way. I found the support manager of OMATRA gesr el suez calling me and I met him monday night. he tested the car with me and saw the problem. He called me on Tuesday to go and take my car... as it's fixed..... again and again and again... it's not fixed
Mr. charming, they changed all these "throttle body, map sensor, injectors, manifold, and the control unit has been changed as a trial)... nothing helps
I told them... why don't u change the compressor... they said it's not related to your case.... :)))) and all what have been changed is related to my case?!?!?!?!
I reached my limit and dont know what to do more ......
my car is still there... and i am sure they will call me again to say it's fixed... and i will go there to see it having the same problem...
I spent almost 600 to 700 EGP for taxis to go to that really far gesr el suez .... spent my time... my health... my voice...
hope to fix it... then sell it on the same day... if any one is interested you can contact me here
رقم العضوية : 3614
السيارة: searching
دراجة بخارية: nil
و الله انا شايف انهم لو ماعرفوش يصلحوها يغيروهالك و ليه تبيعها و تخسر فيها انا عربيتى فيها نفس المشكلة و لسة مغير البوابة النهاردة و هاجرب بس شكلها مش فارقة قولهم كدة لو ماتصلحتش يا تتغير يا تكلملهم حماية المستهلك
رقم العضوية : 3614
السيارة: searching
دراجة بخارية: nil
ارجو انك تقوللى و صلت لايه لأنى غيرت البوابة و برده ما فيش فايدة !! يا رب حل
رقم العضوية : 3614
السيارة: searching
دراجة بخارية: nil
انا مشكلتى مختلفة شوية كانت بدأت بتنتيش مع التكييف و بعدين دلوقتى بتنتش على طول كأنها بتفصل مع rpm فوق ال5000 اللى حارق لى دمى ان عامل بنزينة امارات الى ما بيفهمش عمللى البحر طحينة و حطللى فلاش للموتور و انا بحط الباور سينث (زيت ال10000 بتاعهم) و من ساعتها العربية مش عايزة تتظبط شكلها كدة بساتم (حسبى الله و نعم الوكيل)
